Question about Airlink (AWLC3025) Wireless Adapter
Installing a 32 bit air link wireless cardbus adapter AWL C3025
Hi, i am having problems getting my internet connection up and running.
I am running a DL-624 air plus extreme router with encryption.
The problem is getting it to connect to the router with encryption, i am always getting yellow limited connectivity signal on the wirless status bar icon.
I am using windows xp pro.
  • marjibug Feb 24, 2008
    i have a wireless b card and getting limited connection or nothing showing
  • 556 Answers
First have you tested a wired computer to assure all but the wireless section is configured correctly?
Second have you tested a wireless unencrypted connection to assure it works?
When choosing an encryption strategy did you assure the router and adapter supported the same choice. Generally there is WEP and WPA -- most people prefer WPA now however both the adapter and the router must support it to make it a viable choice.
To provide further assistance please check the model number of the router and provide either the manufacturer and model for the wireless adapter or the computer with a built-in wireless adapter you are attempting to connect.
Posted on Dec 08, 2007
Does this devise pick up internet on laptop or desk top either one
Hi cfisherman8
This is a PCMCIA Wireless Adapter Card.
It slots into the large PCMCIA Port that almost all larger laptops and notebooks have.
This device can also work in a Desktop computer but requires a PCMCIA Cardbus Adapter to be installed in the Desktop Computer for it to slot into. There are different types of Desktop PCMCIA Cardbus Adapter. Some types internally connect a PCMCIA Wireless Adapter Cardbus to an empty Motherboard PCI Slot and others externally connect a PCMCIA Cardbus to the computer via its USB or Serial Ports. See here for examples:
http://www.amazon.com/StarTech-com-Port-CardBus-PCMCIA-Adapter/dp/B000BMMN7K/ref=sr_1_21?s=electronics&ie=UTF8&qid=1316320335&sr=1-21
http://www.amazon.com/Startech-Cardbus-Adapter-Transfer-115-2kbps/dp/B004WGR6YG/ref=sr_1_12?ie=UTF8&qid=1316320098&sr=8-12
http://www.amazon.com/Quatech-PCD-X-U142--CardBus-adapter/dp/B001BEF3YC/ref=sr_1_28?s=electronics&ie=UTF8&qid=1316321566&sr=1-28
Other alternative internal wireless networking devices for Desktop computers include a PCI Wireless Network Card. See example here:
http://www.amazon.com/Sabrent-Wireless-802-11n-Network-Adapter/dp/B002DYIZ2Q/ref=sr_1_14?s=electronics&ie=UTF8&qid=1316320278&sr=1-14
Once installed, it is able to send and receive data wirelessly between the computer and any Wireless Router/Modem to which the computer is configured to connect.
This device is most easily used with a Laptop. An easier solution for a Desktop PC would be a USB Wireless Adapter.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. Doing so helps Solution Providers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can. If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa
Sep 18, 2011 | D-Link Air DWL 650 802.11b Wireless...
I hace dual boot on a drive xp and vista 32 bits. i get correcr maaac address in xp but mac address in vista is different. i have LAN internet connection. therefore i cannot get connected to internet in...
MAC address need not be changed to connect to internet, unless the cable modem you have is configured in such a way that it only connects to a particular MAC address.
The solution is to change the settings in the cable modem or the router you have.
Please specify the following details
1. if you have windows click on start and click on run(for xp) and type cmd and hit enter
2. type ipconfig and hit enter
3. Find out what is the IP address specified there it should be in the format - 192.x.x.x
4. Note down the address against default gateway
Do the same thing for both the computer and then let us know so that we can narrow down the issue and suggest a better solution
Feb 04, 2011 | 3Com : 32-bit 10/100 LAN CardBus PC Card,...
How to turn on wifi
hi
the T42 does not have WiFi, instead it facilitates internet connection via 16 BIT & 32 Bit PCMCIA slot to install a WiFi card , in order to go on the internet.
The ThinkPad uses the following adapters: v 360, 365X, 380, 600: 16-Bit PCMCIA v T20, T22, T23: 32-Bit CardBus and MiniPCI v T23: 32-Bit CardBus and MiniPCI Daughter Card v T30: 32-Bit CardBus and LAN on Planar Board (LOB) v T4x: 32-Bit CardBus and LAN on Planar Board (LOB). 16- and 32-Bit PC Card adapters are configured during ThinkPad initialization. Network Interface Controller data rates are: v For Token Ring: 4/16 MBps v For Ethernet: 10 Mbps...........16 bit PCMCIA 10/100 Mbps.......32 bit CardBus 10/100 Mbps.......MiniPCI and Daughter Card 10/100 Mbps.......T3x and T40 LOB 10/100/1000 Mbps..T42 LOB The MiniPCI Ethernet adapter is accessed behind a removable plate located on the bottom of the ThinkPad directly above the Model/Type S/N sticker. For T20 and T22, the MiniPCI adapter may be an Ethernet/Modem combination card. The Daughter Card (T23) is secured with two screws and is located next to the MiniPCI modem adapter.
please go to this link to read the manual -- it will explain the features for this ThinkPad of various series T42 model-type .
http://www-01.ibm.com/support/docview.wss?uid=isg2ffa39ae31a2f590e85256ced00828893&aid=1
please rate my service
Nov 22, 2010 | IBM ThinkPad T42 Notebook
Wi-fi card on Win98SE laptop not allowing internet to connect.
I really believe this is some kind of driver error. You must first remove the existing driver and then install the following driver.
http://download.cnet.com/D-Link-AirPlus-Xtreme-G-DWL-G650-Adapter/3000-2112_4-67890.html
If that doesn't work we're gonna have to try messing with the wireless router settings.
May 26, 2009 | D-Link AirPlus Xtreme G DWL-G650 108Mbps...
Can't connect wirelessly, "link light" not blinking
Please check,,Are you able to go online with Modem,If yes Then re-configure your router and restart your comp and check...i hope you can connect to internet..
May 21, 2009 | D-Link DWL-650+ AirPlus Enhanced 2.4GHz...
Software to install wg511 32 bit cardbus
Netgear of course!! www.netgear.com/downloads_support.asp
Mar 21, 2008 | NetGear WG511 Wireless Adapter
Installing pc card: 32 bit cardbus WG511
If your laptop is running on XP, sometimes WINDOWS installs the drivers for the wireless card automatically. If WINDOWS do not install the drivers, you need to load or install the drivers of your wireless adapter. You can use the disc that came with the wireless adapter or downloiad the drivers from the website of your wireless adapter
Mar 13, 2008 | NetGear WG511 802.11g/b Wireless Adapter
Airlink (AWLC3025) Wireless Adapter Logo
332 people viewed this question
Top Airlink Computers & Internet Experts
Prashant M
Prashant M
Mohammed Ebrahim M
Mohammed Ebrahim M
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Airlink Computer and Internet Expert? Answer questions, earn points and help others
