Home | Epson | DFX 8000 Matrix Printer | Alpha seting of dfx 800...
Epson DFX 8000 Matrix Printer
Problem for Epson DFX 8000 Matrix Printer
Alpha seting of dfx 8000 printer
By barkya on Dec 06, 2007
alpha seting of dfx 8000 printer
Solution #1
posted on Aug 22, 2009
Not Rated)
negritoV
Rank: Master
Rating: 89%, 4 votes
The purpose of this adjustment is to set the PG offset value in accordance with the nose dimension
of the printhead. (For details, refer to Chapter 2.)
The offset for the nose dimension is represented by the adjustment value “ALPHA.” The “ALPHA” value
is stored in the memory on the main board, so the PG adjustment mechanism can read the value as
needed. Be sure to perform the adjustment when required. If this adjustment is not performed correctly,
the platen gap will be incorrect, the paper could be caught by a head pin, or, in the worst case, a head
pin could break.
NOTE: The printhead adjustment value is written on the front of the head unit (refer to Figure 4-2). After
the printhead is attached, the value cannot be seen. Be sure to write down the value before
attaching the printhead.
Step 1: Connect the AC cable. Mount the ribbon cassette, and load paper into the front tractor.
Step 2: Turn the printer power on while pressing the LINE FEED, MICRO FEED (V), and PAPER SELECT
switches (Be sure that the top cover is closed. Do not open it until you turn the printer power
off.), then wait until the buzzer rings five times.
REV.-A
Step 3:
Step 4:
Step 5:
Step 6:
Load the paper by pressing either the LINE FEED or PAPER SELECT switch, then wait until
the PAPER OUT lamp goes off (approximately 15 seconds).
Press the ON LINE switch.
Press the MICRO FEED (A) switch the number of times indicated by the value written on the
front of the printhead.
l The buzzer rings each time the MICRO FEED switch is pressed.
l Press the MICRO FEED (A) switch to increment the value.
l Press the MICRO FEED (V) switch to decrement the value.
l The value range is O to 10.
To confirm the value stored, press the FORM FEED switch so that the value is printed.
l If the value is incorrect, return to Step 5.
. When the value is correct, go to Step 7.
Step 7: Press the ON LINE switch and confirm that the buzzer rings five times. The printer prints the
final value stored. If the value is correct, turn the printer power off.
Was this helpful?
Yes
No
Popular Solutions for Epson DFX 8000 Matrix Printer
Questions and Unsolved Problems for Epson DFX 8000 Matrix Printer
Do you recommend Epson DFX 8000 Matrix Printer?
Answer
Answer
I got got this new Gateway PC with 64-bit Windows Vista OS & as I was trying to connect it... (More)
Answer
the cut paper option does not wirk in Windows XP - is there a fix for that
Answer
I am trying to get the printer to be online I used it yesterday and everything worked I need help
Answer
Divers for Epson DFX8000 OS - WinXP I use DOS (clipper) program to print some reports. this report... (More)
Answer
we have windows xp, but hav'nt driver of epson dfx 8000 for windows xp so that the printout of draft... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Epson DFX 8000 Matrix Printer:
Top Printer Experts
Rank: Guru Guru
Solutions: 480
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
