Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer only heats randomly
OK,
I have completely took this thing apar for a good cleaning to start with, the glow type ignitor starts and glows red hot for 10-13 seconds, the flame will only randomly light. Just when the the ignitor shuts off ther is a clicking noise from 1 of the 2 solenoids (appears to be the 2 wire solenoid), gas supply line is good, vent is free and clear. There is two sensors on the tube (heat stove) The one on the lower left (looking from the gas burner end into stove pipe) looks to be some sort of photo cell as it looks to have a clear glass piece aimed at the flame thrower (burner?), the senond is mounted to the upper right and looks to be some sort of transistor, when this does light it is after it sets for a while then it only stays lighty for a sort time 10 minutes or less that is. Ypu can respond her and now or write me back @ t.morelock@yahoo.com, hurry I have two teage girls !!!!!!!!!
  • 1 more comment
  • tmorelock Dec 07, 2007
    WOW !!!!!! A #1 rapid response and problem solved,
    I bought a pair of coils locally and installed them (less than 5 minutes) dryer perfroms like new.
    Thank you, watugot.
    Tim
  • gmurph Dec 10, 2007
    I have a 14 year old hotpoint gas dryer. It heats up when first started
    if the timer is turned to the full 90 minute spot. Doesn't heat up
    any more after that but continues to run. ?
    George
    gmurphy@ket.org
  • paulak Dec 14, 2007
    I have replaced my thermal fuse twice in two months. I replaced the last one yesterday, the dryer heats for a moment and then it blows cold air. I have a Kenmore 80 series. Do you have any advice?
    Thanks,
    Kel
    New Friend:
Hi my name is moostafa .iam 23 yors old i live in iran
Posted on Jan 17, 2014
  • 290 Answers
The most common cause for your problem are the two coils on the gas valve. It is normal for the burner to cycle on and off while the clothes are drying. One of the coils is getting weak after it gets hot and not opening the valve.
Replace both of them.
You can order the set from repairclinic.com for $18.95.
If you need further help, please post the complete model and serial numbers.
Thanks/Mike
Posted on Dec 06, 2007
My gas dryer wont ignite. where do I start trouble shooting
Model number would help but I'll give some general info. Most Kenmore dryers are usually made by Whirlpool so I'll give info for that type dryer. The 1st thing to check on a no heat is if the glow bar ignitor is coming on. At the cycle start it should glow red hot or orange. If no glow the glowbar may be burned out and needs replaced. This is the most common problem in a gas dryer. If you see the orange glow for about 15 seconds and it goes out ---that is normal. That usually means you may have a bad magnetic coil on the top of the gas valve. There are actually 2 coils on the valve and if either one goes bad the valve will not open and let gas through to ignite. They need tested with a multimeter. Thats the 2 most common problems with gas dryers.
Jun 24, 2015 | Kenmore Dryers
Its a gas dryer. Starts up but no heat. Ignitor doesnt glow therefore no flame. Checked with ohm meter , seems good . Also checked coils for gas valve,checked out good . When you start up there is no power...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Gas valves works off of amps pulled by the ignitor...ohms doesn't matter..
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | Dryers
Dryer runs....no heat
Make sure the lint filter and the exhaust vent pipe are not clogged.
If electric then the thermostat or the heating element has failed.
If gas: First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
See also: http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Dec 21, 2009 | Refrigerators
Gas dryer 4 yrs young and won't heat. Drum turns.
Dec 04, 2009 | Televison & Video
My dryer is spinning, but not getting hot at all. Help!
Nov 09, 2009 | GPS
This is the closest model # I could find but I have a gas dryer model TGDX640EQO and it doesn't heat up but does tumble. My husband thinks it is the ignitor, how would you determine that?
First clean all the dust and lint from around the burner and its components, including the sensor which 'tells' the dryer that the ignitor is on or the burner is lit.
There are two different types of ignitors. The most common glows a bright red to light the burner. The other gives off a series of sparks.
In either case, a visual examination should tell you whether the ignitor is working. Before you start the dryer, remove the burner access panel. Have someone start the dryer while you look into the burner unit to see if you see the 'glow plug' or the 'sparker' trying to light the burner. If not, the ignitor is probably bad.
If the ignitor is not the problem, look for dirty or defective sensors that will keep the burner from coming on. If these sensors do not sense the light given off by the ignitor, for safety reasons the burner will not come on.
Hope this was helpful.
Oct 10, 2009 | Estate TGDX640JQ Gas Dryer
Mdg 4000aww turns on and heats when started. runs for 5 five minutes then flame goes out. ignitor glows but no flame. one minute later dryer still running ignitor glows, no flame. this repaets until turned...
Either the venting needs cleaned or the coils on the gas valve are bad. Unhook the venting from the back of the unit and run. If works ok then clean venting. If you still have the problem, replace the two coils on top of the gas valve.
Sep 29, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Not heating up to dry the clothes dryer is coming on and off fine its just not getting hot
Make sure the lint filter is clean and the vent duct is not clogged. Check all the way to the vent outlet. Then: Check the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the flame sensor may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
If everything above is OK then the thermostat or the auto sensor is not working correctly.
Sep 15, 2009 | Dryers
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Dryer won't get hot
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
Maytag Neptune MDG5500AW Gas Dryer Logo
175 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
