Question about Sony VPL CS5 Multimedia Projector
Vpl cs5 dusty lens from the inside
When you mute the pic on the projector, you can see speckles of dust and its cast and magnified on the screen. How do I safely clean the lens inside?
  • 27 Answers
Not too difficult to do.
requires cover off and minor strip down.
if unsure consult a tech.
Posted on Feb 26, 2008
Sony vpl cs5
Original lamp for cs5 USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Jan 16, 2014 | Sony Lamp Module for Sony VPL-CS5/CX5...
Sony VPL-CS5
you must change the lens. the cost is high. see the sony site for replace the parts.
Sergio
Mar 27, 2008 | Sony VPL CS5 Multimedia Projector
DIRTY LAMP FOR VPL-CS5 SONY PROJECTOR (USED)
to clean the lamp: no chemicals, nothing abrasive. you can touch the outer glass (not with your fingers), but do not touch anythjing inside the bell. best thing to use is a microfiber cloth. your lamp is nearing or has passed 2000 hours of use. the projector is telling you to replace it before it blows (and sometimes shatters). after you replace it, reset the lamp timer (through the menu).
Dec 17, 2009 | Sony VPL CS5 Multimedia Projector
Sony vpl cs5 projector - after lampchange
Having same problem without lamp change. Did you ever find a solution?
Your response would be GREATLY appreciated. :)
Mar 28, 2009 | Sony VPL CS5 Multimedia Projector
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Sony VPL CS5
You need to clean the filter , the unit is shutting down so it doesnt over heat..look for online manual on how to remove filter and blow off dust.. Good Luck
Jun 30, 2008 | Sony VPL CS5 Multimedia Projector
Blue glare
HI there
This might only be a dusty lens on the inside. But it could also be a faulty Mainboard or LCD's.
Take it to a Service Centre and ask them to check it out for you. They normally quote first and then repair if you give them a go-ahead , you've got nothing to lose.
Apr 15, 2008 | Sony VPL PX40 Multimedia Projector
YELLOW SPOT ON SCREEN
There may be a dust fleck on one of the LCD screens inside your projector. I had a similar problem and managed to clean it. But it requires you to dissassemble the entire projector !!!. If you are not technical, don't do this yourself. !!!
Feb 16, 2008 | Sony VPL CS5 Multimedia Projector
Problem: Green colour cast
Problem resolved by swapping the video cable, simple really!
Feb 13, 2008 | Sony VPL CS5 Multimedia Projector
My projector Benq pb6200 needs cleaning from the inside how???
I have an Optoma EzPro 737 DLP projector that accumulated dust inside the lens and for ages I couldn't figure out how to get rid of it. It cast shadows onto the picture and scattered light outside the edges of the picture. I thought I'd have to dismantle the whole lens assembly (then realised that this is virtually impossible without being an expert). I then stumbled upon a little black rubbery plastic panel on the side of the light path, which unclips. I then realised that the dust had built up on the lens that sits in front of the DMD chip (the thing that makes the picture).
Here's what I did, with the case open and having vaccuumed out all the dusty parts of the projector to avoid making the situation worse:
- Took off the little rubbery panel,
- Removed the lamp from the projector and placed a flashlight inside, shining into the light path (or a mirror directing light from a table lamp above)
- Looking directly into the lens from close up, you should be able to see the particles of dust stuck to the inner lens (with a nice magnified view)
- First tried blowing air into the gap on the side of the light path (I used a balloon pump).
- Next, I poked a piece of thick nylon fishing line into the hole so that it could touch the surface of the inner lens.
- While looking into the lens, I could see the tip of the nylon, then directed it to the largest dust particles and used it to scrape them off (nylon is much softer than glass, so won't scratch the lens).
- This was quite time consuming but I got rid of the most obvious bits.
I'm not sure how different this would be for another model of projector - but I hope it helps!
Dec 16, 2007 | BenQ (200NSH-LAMP) Projector Lamp for...
Sony VPL CS5 Multimedia Projector Logo
171 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
