Question about BenQ PB6110 Multimedia Projector
White light displayed.....
Just a white light when turned on...no menu or displays, just white light?
Nudge
Posted on Feb 17, 2008
LCD screen is white, dim picture and sound works fine
seems the white balance is set inccorectly and the brightness is set wrong check your TV's menu and set them back to normal or reset the display controls in the tv menu if it turns all back white and dim then the display panel of your tv is needing repair
Mar 02, 2017 | Televison & Video
Tip
ERROR CODE AND POWER SUPPLY CIRCUIT
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
Tip
SERVICE MODE AND ERROR CODES CHECK
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
My washing machine just turns white light on display but nothing to display and white background light also comes when i turn it 2 times on n off
Good Morning Friend,
I understand you are having trouble with the display on your Electrolux washer, model# EWX14450W. In researching your model number, I have determined that it was manufactured in the UK. I suggest contacting the manufacturer for further assistance. They should be able to point you in the right direction for having your display repaired. Hope this is helpful.
-Best Regards-
WP
Jul 06, 2014 | Electrolux Washing Machines
No data to macbook screen
For computers with Mac OS X 10.8 or later, if you have trouble getting your display to work with the computer, access the System Preferences menu and selection the Displays option. Then, press and hold the Option key. In the bottom right corner of the Displays window, you should see a Detect Displays button. Click that button to force the Mac OS to show all the displays, including the macbook's own display.
Otherwise, try resetting the PRAM:
by holding down the Command+Option+P+R keys on your keybord when you turn it on untill you hear the startup chime.
Happy New Year!
Kerry
May 19, 2014 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Sony VPL-CS5 menu will not display
Give input signal to the projector and see that if the menu appears or not on the screen.
if menu comes on the screen then put the backgroung color to blue, instaed of black.
if nothing comes on the screen, then the LCD panels are faulty.
Viren
RAVE SERVICES
Mar 04, 2009 | Sony VPL CS5 Multimedia Projector
Settings/backround colour
Heres how you do it
Press Menu
Settings
Display and light settings
Display settings
Main menu style
Click on black
Save
Go back to main menu and see the change
Hope this works
Plz let me know
JonnieC
Feb 19, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
W300i phone displays white screen
Try taking out the battery overnight and replace and try to turn on. If this doesn't help, then try updating your phone's firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/w300i?cc=gb&lc=en
Jun 16, 2008 | Sony Ericsson W300 Cellular Phone
PB6100:No picture display
The projector needs to be turned on first, then connect it to the laptop. If the picture still does not show at that point, press the FN and the LCD keys on your laptop at the same time. This should work.
Feb 10, 2008 | BenQ PB6100 Multimedia Projector
BenQ PB6110 Multimedia Projector Logo
83 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
