Question about Samsung HCL4715W 47" Rear Projection Television
RED CURVED LINES COMING ACROSS TOP 1/2 OF PICTURE.
HAS BEEN SUGESTED TO BE A CONVERGENCE PROBLEM .HOW DO I REPLACE MODULE AND OR REPAIR .
  • Anonymous Feb 11, 2008
    my green light is off focus, green line curves at th top and bottom.
  • aufanincinci May 11, 2010
    I had the same problem. I replaced both convergence ICs, and still the same problem remains. When manually adjusting the color grid, I am unable to adjust the red grid, and can only adjust the green grid in the "y" direction. And when I turn the red grid off for adjustment, there is still a wavy red line on the top of the screen. I did notice that "RR402S" and "RR471S" look like they are both fried, but I assumed since they are SEMI variable resistors, they were part of the volume control circuit? Any help would be much appreciated, this sorry tv has got me at my wit's end.
  • Samsung Master
  • 8,617 Answers
Replace the convergence ap ICs. You need 2 of them about 10.00 each compared to 300 for a new module. I am enclosing a link where you can purchase the Cs get some heat sink compound while your there. Also they have a picture on the page i posted with what they look like just get th numbers off your and enter it in the search box. Its an easy repair if yo can solder.
http://www.electronix.com/catalog/
Posted on Jan 22, 2008
50H82 red wavy convergence (stks didn't fix)
If the tin can module you are referring to is the hyper module, it is common to replace all 11 caps because the factory caps ****. Check for bridged solder connections at STK's search the forum at electromaniacs for 50h81 :)
Sep 15, 2009 | Toshiba 57H82 57" Rear Projection...
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
Red and blue streaks across the screen top and bottom
The Convergence Amp IC's are bad. You should call a good TV Tech for this repair.
Jul 11, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Curved red lies at top/bottom with some double vision in lines
This is from another fixya article but its relevant to your problem.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos aroundimages.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 25, 2008 | Samsung HCM5525W 55" Rear Projection...
Hitachi 65SWX20B 65 in. Rear... Problem
  • Screen looks 3D
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Jan 15, 2008 | Hitachi 65SWX20B 65" Rear Projection...
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
Red Lines on Screen
Dave, HMMMM Dual pictures This is a problem that every projection TV runs into at least once or twice in its lifetime. Its the old convergence IC falure thingy. These IC's go bad and should be replace all at once. These are not consumer replaceable unless you have had training in the electronics or TV repair fields. Please call out a pro to assist you with this repair as A TV is not the place to experiment in because of the HI voltage and saftey issues. Good Luck
Jul 29, 2006 | Hitachi 53SDX89B 53" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
