Question about Microsoft Windows XP Home Edition
Unable to load
My windows XP will not load, at all.
what it will do, it will start with a normal boot sequence, and then it either says, disk boot failure, or it takes me to the safe mode options screen, which after every option, either freezes, or goes through a list of things it starts loading- AND THEN freezes.
before this happened i usually had to restart once because it wouldn't boot correctly, but after hitting the restart button it loads correctly, but now nothing works. i have not installed any new hardware. other people i have asked says it's a corrupted registry file or something, i have already tried a boot disk another option i have not tried yet, is using an install disk to access the recovery console. but as i do not own such disks, i was wondering if there were another way. please reply quickly.
  • 383 Answers
How to get to a MS-DOS prompt.
Reason: If Windows or the computer is not operating properly, it may be necessary to get to a MS-DOS prompt to diagnose and to perform additional troubleshooting on the computer.
Solution: MS-DOS users
Windows 3.x users
Windows 95, 98 and ME users
Windows NT, 2000 and XP users
Windows Vista users
Other PC Operating System users
MS-DOS users If you are running MS-DOS with no other operating systems, the computer should be booting into a MS-DOS prompt automatically unless you have a shell or other program loading automatically. If the computer is not getting you to a MS-DOS prompt, reboot the computer and as the computer is booting, press the F5 key when you see the message "Starting MS-DOS" or the MS-DOS version. This will load the default standard MS-DOS. If you successfully get to a MS-DOS prompt and would like to prevent the computer from loading the program that is preventing you from getting to a MS-DOS prompt, or if you would like to fix possible error messages you may be receiving when booting the computer, edit the autoexec.bat and/or the config.sys files.
Windows 95, 98, and ME users If you are able to get into Windows 95, 98 or ME, you can get to a MS-DOS prompt by following the below steps.
  1. Click Start
  2. Click Run
  3. Type "command" and press enter.
This will open a MS-DOS shell. However, if you are attempting to troubleshoot an issue with the computer and are using Microsoft Windows 95 or Windows 98we suggest you restart the computer into MS-DOS. To do this follow the below steps.
  1. Click Start
  2. Click Shutdown
  3. Choose the option to restart the computer into a MS-DOS prompt.
If you are unable to get into Windows 95 or Windows 98 to get into a MS-DOS prompt, follow the below instructions (Windows ME does not have this option).
  1. Reboot the computer
  2. As the computer is booting, press the F8 key when you hear a beep or when you see "Starting Windows 95" or "Starting Windows 98". Windows 98 users sometimes may find it easier to press and hold the left CTRL key as the computer is booting.
  3. If done properly the user should get to a screen similar to the below screen.
Microsoft Windows 95 Startup Menu
============================= 1. Normal
2. Logged (\BOOTLOG.TXT)
3. Safe mode
4. Step-by-step confirmation
5. Command prompt only
6. Safe mode command prompt only
Enter a choice: 1
F5=Safe Mode Shift+F5=Command prompt Shift+F8= Step-by-step confirmation [N]
4. Select the option for Safe mode command prompt only.
Windows NT, 2000, XP, and Vista users If you're running Windows NT, 2000, or Windows XP and need to get to MS-DOS prompt follow the below steps.
  1. Click Start
  2. Click Run or click in the "Start Search" field if you're running Vista
  3. Type "cmd" or "command" and press enter.
Additional information about the difference between "cmd" and "command" can be found on document CH000395. If you're attempting to get into a MS-DOS prompt to troubleshoot the computer boot the computer into safe mode. Additional information about how to get into safe mode can be found on document CHSAFE. Windows 2000, XP, and Vista users who are unable to boot the computer into Normal Windows mode or Safe mode can also enter the recovery console to manage their computer from a prompt. Additional information about how to do this can be found on document CH000627. Finally, if you are experiencing issues getting into Windows NT, 2000, or XP, it may be necessary to run troubleshooting steps from a MS-DOS prompt. It is recommended that the Network Administrator get into the MS-DOS prompt by using either a standard MS-DOS boot diskette (note: will not be able to access data using a standard MS-DOS bootable diskette) or the ERD diskettes created after the installation of Windows NT, or boot from the Windows XP CD.
Index
Category:
MS-DOS Q&A
Companies:
Microsoft
Related Pages:
MS-DOS
Safe Mode
Resolved
Were you able to locate the answer to your questions?
Posted on Dec 06, 2007
    Habit-Forming:
  • 188 Answers
Dear sabre
i was having same problem as u have...
now u would like to know that what did i do then.well- i would be very happy to tell u that i just re installed my window xp---and my problem was solved..
i m sure re instollation of win-xp will solve u r problem..
Regards & best of luck
for more information on this topic u can mail me too
sigma_shiva1@yahoo.com
sir
if u r problemis solved then let me know by VOTING me.....
-Was this solution helpful? Show your Appreciation by rating it:AS FIXYA
I am unable to get windows xp to load onto my ASUS A2500H anymore. Everything was working fine for a long time, even with an external HDD attached until today. All of a sudden the laptop died and when...
The best you can try is to remove the external HDD and see if computer boots..
If it does, you know where the problem is..
If it doenst, reboot computer, start tapping F8, if you get advance boot options, try to boot computer with Save Mode, Perform system restore from save mode.
If the above doesnt work, you need to perform repair installtion of Windows XP.
Apr 11, 2011 | Computers & Internet
How do u get to the repair your pc on the start up disk. My pc just went down one day with out warning it says registry corrupt or missing insert installation disk n restart your ps I insert the disk...
Mr. Randee, you need a bootable disc or should i say cd installer like windows xp professional. Turn on your computer and tap DEL key or F2 key, it will enter you to cmos/bios setup. When already in cmos/bios look for the bios features setup using arrow keys and when highlighted it press enter. Then look for the boot sequence and make the cd or dvdrom drive first boot by pressing - or + or pageup or pagedown to modify. When you already changed the boot sequence press F10 key to save the settings then press Y. While restarting insert the Microsoft CD installer and when ask you for press any key, press any key to boot or start booting from cd or dvdrom drive. Let the cd installer run and when the computer ask for enter, repair or skip press R for repair. Then it will load to repair setup, type 1 for c:\windows and press enter. Type fixboot and enter and press Y for yes after that type fixmbr and enter and press Y for yes then type exit. After that wait to restart your computer and eject the cd installer and the computer will automatically load to windows. Have a good day!
Jan 03, 2011 | ASUS Computers & Internet
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
Cannot boot from hard disk CD. An error occured that your BIOs would be updated and it is not fully ACPI compliant
Windows normally does not update system Bios. If your having trouble booting from CD, start the computer and enter the Bios setup. Change the boot sequence to CD then Hard Driveand save the change. Restart the computer with the CD in the drive and it should work fine.
Jun 28, 2010 | Microsoft Windows XP Professional
Windows xp boots but the desktop will not come on
well there is a couple of thing you could try 1) power on your computer press F8 rapidly and select "last known good configuration" 2) power on your computer press F8 rapidly and select safe mode login with your account and press yes to restore you computer to an earlier time select a date tah the computer worked ok and click on restore
try it and please if you have any problem please comment
Apr 01, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
DELL DIMENSION 2400 ERROR STOP: 0x00000024, (0x00100203,0X82F898
You seem to have an error in the boot sequence of the Operating system. If you are unable to access the safte mode of the OS, then you will have to do a hard boot (boot from disk). My suggestion is seeing that you have a Dell, many times they will give you a boot disk or charge you $10 for one to be sent to you. Boot disks are not expensive at all.
Once you recieve the boot disk, go into the BIOS and change the boot sequence that it boots from your CD/DVD drive first instead of your hard drive (C). Then restart the computer with the disk in the disk drive and it will load from the disk.
If that does not work, you will have to do a reimage. For that you will need a Windows OS CD (XP, Vista - whatever OS you use). From there you can either have your data slaved over to another drive prior to reimaging, or if you dont mind loosing the data, just push in the Windows OS CD and it will ask if you want to over write or reimage, answer yes, and it will begin to wipe your computer and place a brand new copy of the OS on there.
Jan 02, 2010 | Dell Dimension 2400 PC Desktop
My computer only boots successfully after a forced shutdown.
Is it possible that you have installed winxp twice? You say that you installed XP Pro sp3 was that an upgrade from xp home? if so then you will need to uninstall one or both versions of XP then install only one.. Make sure you backup any important files first though
May 22, 2009 | Microsoft Windows XP Professional SP3 Full...
On boot computer does not see Hard drives
Chose boot sequence to boot directly from the HDD . Also check if the Hard Disk is OK by connecting it to another PC. Check too that the power cables are snug tight and none of the pins are bent in the IDE slot. Now try booting first in safe mode & if successful go ahead and boot normally....sodeep
Apr 19, 2009 | Microsoft Windows® XP Professional Full...
I recive\system 32\hal.dll
The first thing to check is your boot order.. do this when the pc starts up by pressing which ever key is indicated to enter 'setup' usually f2, f12, or delete. and look through for boot devices or boot sequence. make sure it's floppy, cdrom, hdd drive which may be listed or hard drive, internal drive, etc).
Do you have your windows disk? If so try this... put in the cd and restart the computer and when prompted to "pressany key to boot from cd' do so. Enter Windows XP Recovery Console by click on R. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
  1. When you reach the command prompt type the following command and then press Enter.
  2. bootcfg /rebuild
    The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
  3. The first prompt asks Add installation to boot list? (Yes/No/All).
  4. Type Y in response to this question and press Enter.
  5. The next prompt asks you to Enter Load Identifier:.
  6. This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
  7. The final prompt asks you to Enter OS Load options:.
  8. Type /Fastdetect here and press Enter.
  9. Take out the Windows XP CD, type exit and then press Enter to restart your PC.
  10. Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Dec 02, 2008 | Microsoft Windows XP Professional With...
Windows wont load
is your computer set to boot from cd?
Jun 01, 2008 | Computers & Internet
Microsoft Windows XP Home Edition Logo
520 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
