Question about IBM NetVista PC Desktop
Adding RAM I bought a stick of RAM to upgrade an older computer, and it does not seem to be working. When I turn the power back on windows does not even boot up. I thought I ordered the right one. Is there something I could be doing wrong. I did have one 64mg and one 128mg. I re-installed those and it's back to normal. I am trying to add KVR133X64C3/256. Thank you. Nathan my computer is a netvisa 2276
    Habit-Forming:
  • 188 Answers
Hi dear..
i m sure u r new ram/256 is not supporting u r pc or ram may be ded...
1 st of all check u r ram frequency of 128 mb...then buy a same frequency 256 ram and install it to u r pc properly..
i m sure it will fix u r problem.
Regards & best of luck
for more information on this topic u can mail me too
sigma_shiva1@yahoo.com
sir
if u r problemis solved then let me know by VOTING me.....
-Was this solution helpful? Show your Appreciation by rating it:AS FIXYA
Posted on Dec 06, 2007
    Champion:
  • 209 Answers
Before you buy this memory stick (ram) you should have check the specifications of this ram memory, they should be the same specs, the cast latency might be different and with different brand. how about if you remove all this ram memory and use only this KVR133X64C3/256, if this works then do not install the other 2
Hp a1340 new ram windows freezes
I would recommend a fresh install of Windows. Back everything up with the 1GB installed, turn off PC, install the second stick of RAM and then go straight to installing Windows.
Feb 27, 2014 | HP Pavilion a1340n PC Desktop
Upgrade BIOS to see if it will resolve hardware issue with new stick of RAM
Hi Szusza,
The new RAM module you purchased may be faulty, it is definitely possible that either due to a fault of the new RAM or on the slot you are trying to install it to cause the computer to not fully boot.
Have you tried to boot the computer with the new module only?
If not please try this:
Replace the original RAM module with the new one (make sure you insert the new RAM in the same slot you took the old one out)
If the PC boots you know the new RAM is fine.
If this does not work I would suggest getting your new RAM tested.
If it does work, put the original RAM back in the computer (in a new slot) if it does not boot after that then, there is possibly a problem with the RAM slot on the motherboard.
Dec 16, 2013 | HEWLETT-PACKARD Compaq Presario CQ5302F...
I own a compaq presario 6450nx and I would like to upgrade it. like adding more ram and replace the cpu if its posible, what could be the suggestion?
This is info on your motherboard:
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07843
Your system comes with Intel P4 2.53 GHz processor and 512MB ram. total ram could be 1GB, bt adding another 512MD stick. You have Socket 478 and processor would be up to you. The system comes with a 200w power supply so, in an upgrade, you should up the power supply. You have an AGP expansoin slot and, you could upgrade to a graphics card but again, power supply is only 200w. The system as it stands is not Windows 7 compatible. If you incraesed your ram and got a graphics card, you would get better performance.
Jun 13, 2011 | Compaq Presario 6450NX (DA238A#ABA-BDL1)...
I have a Dell GX620 that I rescycled.It wouldn't power up so I put in a different power source and put in 1 - 512 stick of memory. It then started up and I reformatted the hard drive and re-installed...
just leave in one of the new 1gb stick of memory
if stable memory was the issue so add the back one at a time each time shut down install turn on test
if still unstable coould be the hard drive
May 29, 2011 | Dell OptiPlex GX620 PC Desktop
My compaq dx2450 wont register ram and its only about 8 months old i bought direct from hp but they wont help i really need to upgrade my ram
try adding one ram stick upgrade at a time, while leaving one original in the system till it boots and recognises the increase. repeat until finished adding all the new ram. if these measures dont work, its possible you have purchased ram that is not matching to the upgradable standards of your board. its important when adding ram to insure you match the ram speed with your replacements upgrade.
Jan 18, 2011 | HP Compaq DX2450 PC Desktop
How do you open a compaq presario sr1630nx computer to install memory upgrades
Viewing the back of your computer, you will see a large thumb screw, on the right side of the computer case.
It's to the right of that round ventilation opening. (Round shape with multiple holes in it)
Unscrew the thumb screw to the Left, to loosen it.
The side panel that the thumb screw is in, pulls back towards the rear of the computer.
If you look, there is a place to put your fingers at the end of the side panel.
(Raised 'Hump' in the sheet metal of the panel)
Hold the top of the computer case with one hand, pull the side panel back with the other hand.
NOTE*
The computer MUST be unplugged from power before proceeding!
Not only is there a possible issue for Your safety, but also the computer's!
You will fry out the Ram Memory stick/s if you remove, or install with the computer plugged into power.
Also,......there is an Anti-Static issue that needs to be addressed, BEFORE you reach inside your computer
Your body carries Static electricity.
Static will fry out the hardware components inside a computer.
(In a Flash!)
Work on a table. Computer unplugged from power, computer case open. TOUCH the metal frame of the computer case BEFORE you reach inside.
TOUCH the metal frame Before, you take those ram sticks out of their protective antistatic bags.
Should you get up for any reason, walk away, then return, Touch the metal frame again.
Refrain from touching the gold plated contact pins, on the bottom of the ram stick.
You can handle the ram stick anywhere, but on those contact pins.
The ram stick is coated with a see-through plastic.
The contact pins are not.
Should you need advice on how to remove, and install ram memory, please state so in a comment. (Top right of page)
This is HP Support, and the download page for the -
Upgrading and Servicing Guide, for the Compaq Presario SR1630NX,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=1122478&
On this page scroll down to - Upgrading and Servicing Guide.
Left-click right on the name.
This is a PDF file download. Give it a few seconds.
After you see the first page, you will note there is a download progress bar.
Let the file download all the way Before looking through it.
Should you wish to save this file to your computer, please come back, and state so in a comment.
The Upgrading and Servicing Guide has illustrations, and instructions for;
1) Opening the computer case. (Side panel)
2) Removing the Front Panel
3) Locating hardware components inside the computer
4) Removing and Adding a Drive. (Harddrive and Optical Drive)
5) Adding Memory
And a host of other information you may find useful.
Jan 06, 2010 | HP Compaq Presario SR1630NX PC Desktop
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
RAM sticks
Hi Runninthe8,
Please go to my site www.pc-fix.us and call the number there I'll answer and I can help you much more. If we proceed anyway we would have to call because you will need to turn off your PC when upgrading or adding RAM into your computer.
Look forward to speaking with you, Cameron Bradford
Sep 30, 2008 | Dell Dimension 8100 PC Desktop
PC turns on then quickly turns off
Does it boot fine if you remove the memory you just added? If it does then try switching the memory that was in it before with the memory you just added. You want to first determine if the ram you bought is bad or incompatible.
Dec 06, 2007 | Computers & Internet
My First RAM Upgrade-Any Tips
Ah you have found out one of the great things about confusing naming standards. Often times, 200Mhz memory is called 400Mhz if it is DDR because DDR stands for "Double Data Rate".
It still operates at 200Mhz speed, but since it doubles the data it is sometimes refered to (wrongly) as 400Mhz.
On the upside, all DDR-I ram is backwards compatible. So there should be no problems. However sometimes different memory sticks dont play well together.
What I would do is this:
1) Shutdown computer, UNPLUG computer - wait 5 minutes
2) Open computer
3) Remove old Ram stick and replace with the new stick
4) Replace cover, plug in and boot to windows.
If everything works fine, then do step 1-2 again, but this time add the old stick you removed before, and place it in the unused slot.
Again check that the computer functions properly. If it does not, remove the old stick.
Nov 22, 2007 | Gigabyte GA-8IGX Motherboard
IBM NetVista PC Desktop Logo
115 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
