Question about Sony Dual Shock 3 Controller for PlayStation 3
All lights on Dualshock 3 blink 5 times, then do nothing.
My Dualshock 3 controller will not work. When I press the PS button (connected or unconnected with USB cable, doesnt matter) all 4 lights will blink 5 times, then do nothing. I have tried reseting it, bought a new USB cable, and nothing works.
  • RealDanMan Nov 13, 2009
    thanks twinsdaddy!! it worked, however I would suggest holding the reset button as i spent a while just pressing it quickly, with no results ;) holding it down worked tho, cheers
  • Nathan Murphy May 11, 2010
    i have the same problem does any body know how to fix it
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Posted on Oct 05, 2009
    New Friend:
Had the same problem, all i did was plug in the usb cable press ps button and unplug the usb cable and press the ps button again
Posted on Oct 27, 2009
2 Suggested Answers
SOURCE:
SOURCE: My Dualshock 3 controller will not work. When I
playstation 3 controller will not work all the lights are on but no go
Posted on Jan 07, 2010
If i press the ps button on dualshock 3 controller all four lights on it are supposed to flash but it doesn't therefore the ps3 system cannot be turned on using it
Have you charged it? If you have plugged it in and no lights blink you may have a defective controller. If so check with Sony support/
Oct 05, 2012 | Sony Ps3 Sixaxis Wireless Dual Shock...
I dripped a bit of water on my dualshock 3 and its buttons started acting up. i left the pad for a while. when i press the ps button i get nothing and when i connect via usb the lights just flash. help...
Water on electronics is extremely problematic. In almost all cases, unless properly and promptly taken care of, the device is usually ruined. When you spilled the water on it and then pressed buttons, the electricity that is normally sent was intensified by having a conductive material present, and the internal components were probably fried. This is why the controller can't correctly interpret the buttons that you are pushing. The PS3 controller is problematic in that to turn off the controller, you actually have to press buttons. In the future, whenever you spill water on any electronic item, immediately turn it off and allow to air dry for at least 2 days before even attempting to turn it on again. Unfortunately, in this case, I think you are just out a controller.
May 12, 2011 | Sony PS3 Dualshock 3 Controller GamePad
Dualshock 3 just blinks with all four lights when i plug it into ps3 slim. reset button does nothing but delay blinking. no way of connecting so i dont know if it is charged or charging
Hello and welcome to Fixya. From what your describing it sounds as if your DualShock3 Controller lost it's bluetooth connection with the PS3. Make sure you plug the controller to the PS3 using the USB to miniUSB cable and hold down the PS button for three seconds to see if this resyncs it. If it does not turn your controller around and you will see a small hole. You will need a paperclip or other small long object and insert it into the hole to reset the controller. Next after pressing the reset button on the controller try the same steps that I provided above again. I can tell you that the four lights blinking slowly means the controller is actively charging. I hope you found this helpful and good luck.
Apr 24, 2011 | Video Game Consoles & Games
I have a ps3 dualshock 3 controller that wont connect. i have taken it apart to check and see if anything was wrong with the inside, but i saw nothing. When i put it back together, i tried pressing the ps...
Welcome to Fixya. Heres how you can connect your controller to your PS3.
1. Press the tiny Reset Button on the back of the controller
2. Plug in the USB Connection wire
3. Restart Console
4. When loaded, Press the PS Button
5. Disconnect the USB wire
Then it should have recognised the controller and auto-assigned, hope this works for you
Rate me if it works so that i can help other people like you!
Thanks for using Fixya
Feb 13, 2011 | Sony Dual Shock 3 Controller for...
My ps3 dualshock controllers won't turn on. Even when I try hit the ps button nothing happens. Itried the rest button but that didn't work. The ps3 itself works fine I just can't play it without the...
ok number 1 try a friends controller with your ps3 if that works then get a dart or pin and press in the reset button on the controller while having it connected to the ps3 at the same time and then that should work
Jan 30, 2011 | Video Game Consoles & Games
I just got a new ps3 which is a 320 gig, upgraded from a 60 gig. The dualshock controller is not responding or connecting to the new ps3? Any idea?
3. Restart Console
Jan 27, 2011 | Sony Dual Shock 3 Controller for...
Dualshock 3 sixaxis why does it always need to be plugged in
Once the controller is plugged in and connected to the console, hold down the PS button to select "turn off the system." Once the system has completed shutting down, unplug the controller and press the PS button. The console should turn on. If so, the controller will connect wirelessly. Unfortunately you'll have to do this with each controller but it works every time.
Feb 19, 2009 | Sony Dual Shock 3 Controller for...
Sony Dual Shock 3 Controller for PlayStation 3 Logo
1,845 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
