Question about HP Pavilion dv1000 Notebook
USB ports not working DV 1000
Hi, I have an HP DV1000, and amoung other issues, the usb ports (all 3!) are now pretty much dead. 2 are totally loose and moving off the motherboard, 1 will work when held in one way or another. Called tech support and was told maybe 300+ to fix, if fixable. Is there another way to get a usb port via adapter through another port? thanks, appreciate any help - ready to take a hammer to it!
  • pcfan Dec 06, 2007
    Thanks for the info, but I don't have a reliable usb port to connect a hub to. I think my only option is getting them soddered to the motherboard, which is too expensive. I tried a pcmcia card with 2 ports, but they are either too slow or the card slot isn't working properly either. I could end up getting nickle and dimed trying to salvage my laptop, or give up and buy new (never again an HP!) Thanks, if you have more ideas I'd love to hear them!
  • 4 Answers
I just fixed this problem on my dv1000. The problem I found was apparently the USB ports on lower right and left side only mounted on the mobo with light soldering and no soldering on the other side of mobo. Due to heat I guessed, they came loose. I opened the mobo (using guide from a pdf file on the net, sorry i forgot the exact guide but you can ask uncle google).
I took the mobo out and resolder those two ports with plenty of solder from the top surface only of the mobo as I unable to access the other side. Now they work again like charm.
The top right USB is different beast. It is on different card along with S-Video port and apparently in permanent damage.
Posted on Aug 31, 2009
  • 383 Answers
How can I connect more USB devices to my computer? Answer: The USB specification supports up to 127 devices, which means you could theoretically connect up to 127 different USB devices up to your computer. If you needed more than 127 devices, you could even install another USB card to connect additional USB devices to the computer. Some users may be under the impression that because the computer only has two or four USB connections that the computer only supports that many devices. However, you can purchase USB hubs, which are USB devices that connect to the USB port on your computer and has several additional ports that other devices can be connected to. Click here to search for available USB hubs
Additional information:
Dont for get to vote, Merry Christmas..Good Luck
Posted on Dec 06, 2007
Can i charge my hp pavillion dv1000 from my desktop through a usb port?
NO! You will damage one or both computers. You really need to repair the laptop or ac adapter to correct the charging problem. The HP dv 1000 as well as the other HP entertainment laptops have had a lot of problems. Not charging just one of them. I would strongly suggest a professional repair of this laptop.
Apr 01, 2011 | Computers & Internet
Hp pavilion dv1000. All 3 USB ports not recognising any device
go to device manager and from there try updating the usb drive from there
Feb 28, 2008 | HP Pavilion dv1000 Notebook
How cain i connect my laptop Hp pavillion dv 1000 to TV
you can purchase a usb device with TV outputs. look on ebay or purchase one from your local PC retail shop.
Apr 16, 2010 | HP Pavilion dv1000 Notebook
3USB ports not working
Get a new USB driver from HP website. Yours may have been corrupted.
Jun 13, 2009 | HP Pavilion dv1000 Notebook
Need to replace usb ports dv1000
If the problem is with the ports themselves, you may not be able to or be willing to resolder them. How about just adding a USB card to get by?
Jan 24, 2009 | HP Pavilion dv1000 Notebook
RE: HP laptop no power
Give this a try -
1. Unplug all usb devices.(Printers, MP3 players, webcams, etc etc)
2. Remove the battery and power cable.
3. Press and hold the power button for 30sec.
4. Plug in just the cable (no battery)
If this doesnt work then it most likely needs a repair.
Also check the USB & power port for damage or if the charger jack is loose when you plug it in.
Jan 07, 2009 | HP Pavilion dv1000 Notebook
HP PAV DV1000
I see that dv1000 Notebook is pretty old(3 Years) and it is too late to complain that it was not working from the day it was purchased.
I donot think this is eligible for esclation.
Dec 22, 2008 | HP Pavilion dv6000z Notebook
USB Ports are not working
A USB device, such as a camera, scanner, or printer, loses its connection and stops working unexpectedly. The device may appear to work fine when Windows first starts up but later stops working. Use the steps in this document to resolve this issue. Disable power management on the USB hub To preserve power, Microsoft Window XP tries to disable USB when a device is not used. Under certain circumstances this function does not work and may cause USB devices to fail to respond when called. To resolve this issue, disable power management on the USB hub by doing the following:
  1. Click Start , and right-click My Computer .
  2. Click Properties , then click Hardware .
  3. Click Device Manager .
  4. Double-click the Universal Serial Bus Controllers branch to expand it.
  5. Right-click USB Root Hub , and then click Properties .
  6. Click Power Management .
  7. Deselect Allow the computer to turn off this device to save power .
  8. Repeat Steps 5 through 7 for each USB Root Hub.
  9. Click OK , and close Device Manager .
If this doesn't help download everesthome. Run the program click on the chipsets and google the northbridge for updates.
May 01, 2008 | HP Pavilion dv1000 Notebook
i need more details cuz i can not understand what the problem really is, is it with the hardware or software... please rewrite your problem
thank you for your corporation
Dec 16, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
HP Pavilion dv1000 Notebook Logo
1,245 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
