Question about SanDisk Sansa e260 MP3 Player
Ok so recently my Sansa e260s blue scroll wheel is sticking, REALLY bad. I think theres somthing stuck inside it (a liquid or somthing) is there anything i can do/buy to get it to stop sticking without totally ruining it?
  • 1 more comment
  • A l l e n May 05, 2008
    blue button is sticking and wont turn.
  • Anonymous Aug 12, 2008
    The scroll wheel is stuck on my Sansa View which i bought only one week ago.
  • Peyton
    Peyton Mar 12, 2014
    Mine as well! I've had mine for a year and a half and it won't budge an inch!! VERY frustrating for working out purposes! :|
  • 8,596 Answers
May have been exposed to too much heat. sorry.
Posted on May 23, 2008
How install a driver for Sansa e260
Download the software after you run the link below ....Put check next to converter/firmware update/Manual the programs follow instructions.......( here is the link After installation connect your sansa......
Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
Feb 17, 2011 | SanDisk Sansa e260 MP3 Player
Volume control
Spin the scroll wheel while music is playing.
Jan 27, 2010 | SanDisk Sansa e260 MP3 Player
Black screen, lit up blue wheel ,Cant see screen
try detaching the back by taking off the tiny screws (dont lose them!) taking out the battery + putting it back in.
May 31, 2009 | SanDisk Sansa e260 MP3 Player
Black screen, lit up blue wheel ,won't turn off or on
Goto >
There is a FAQ page here that might help you.
May 29, 2009 | SanDisk Sansa e260 MP3 Player
Sansa e260 and e270
the scroll wheel on the front of the device controls the volume. clockwise for volume up, counterclockwise for volume down.
Oct 20, 2008 | SanDisk Sansa e270 MP3 Player
No USB mode in settings / Coverter says no available player
First of all. For the video issue. You may not be putting the vidoes in the right spot, where the player searches for them. Or if you are, in the right format. The e260 comes with a CD which contains a PDF manual and a utility for putting vidoes on the e260. If you arent using the utility that came with the e260 you wont get the vidoes to work because they will either be in the wrong format or spot. As the folder which they are supposed to go into is hidden, you must ask windows or your os to show hidden files/folders to manually insert the videos. As for your USB problem, Turn on the player and press the power button breifly to return the the modesd/welcome screen. Scroll through until you see settings and hit the enter button [The button inbetween the scroller] Then use the blue scroller to scroll down through the entire list until you see a setting called USB Mode. Hit enter again and in most cases select MSC. This should fix your problem. If it doesnt, attempt at updating the frimware of the player.
Dec 31, 2007 | SanDisk Sansa e260 MP3 Player
Blue screen
Remove your back plate and slip the battery out for a second. Should clear it right up no problem. Next time make sure to close programs that might be using the device before unplugging it.
Dec 30, 2007 | SanDisk Sansa e260 MP3 Player
Power goes out
easy fix my friend its temporary firmware problem . ok now to fix it plug the sansa in your pc ,just doing so can fix the problem if not ,unplug it from the pc the unit should have stayed on (the blue LED's of the wheel r on but no screen backlight) push the ON button on the side and hold it push for a good 20 secon then releass it that will make the unit do a soft reset and then turn it back on again it may chow the low bat simbol just plug it back in your pc the screen will show the turning arrow the backlight of the screen will work, let it recharge and there you go fix.
Dec 29, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Black screen and blue scroll only please help????????
something is seriously wrong then. try sending it to a repair shop.
Feb 03, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
352 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
