Question about Proscan PS32500 32" TV
No power i checked powercord it has power but unit has none is there a breaker or somthing else inside
  • strng Dec 06, 2007
    i looked at fuse the bar inside is still connected to both sides
    the fuse is only about 1/2 inch
  • John Dec 31, 2007
    Power comes on and before you get screen power goes off. It does this twice.
What size is the fuse, do you know? I cant read it
Posted on Jan 01, 2008
  • 749 Answers
There is a fuse inside your set! but might not just be problem of it!
check for it!
Posted on Dec 06, 2007
Where is the fuse located at on acer computer
There is none.
If it is a Desktop Computer (case) you will need a new power supply or a different one to test if that is really the problem.
on a laptop, try holding the power button for ~40secs with all power diconnected (no battery and no powercord).
then re-plug the powercord to see if it will turn on. Try a different powercord if it still wont turn on, or have it tested at an electronics store.
Aug 30, 2014 | Acer Aspire Computers & Internet
Hobart k45 won't run
the K45 was introduced in 1962 and ran until 1978 when the K45SS was introduced. You have an open circuit inside, you need to open the machine from the rear and look to the power cord connections. make sure that the wires are connected and none are floating loose. the next step would be to replace the speed control switch. then check your carbon brushes if either one of the brushes are down to the nubs then it would cause a short when you turned it on, if that is the case then be glad that you have breakers and not fuses because you would have fried your motor. the speed control switch has no power attached to it. ifg the problem still exist after checking power cord, speed control plate and brushes then you have a fried armature or stator either can short the system if they have a burned wire inside especially the stator.
let us know how you fare on this after you check out the first easy steps, we can help with the harder fix also.
Mar 23, 2013 | Food Mixers
Crown XLS 602 power amp: Where inside is the fuse so I can replace it?
Hi Tom,
The fuse you may be referring from the power supply is not
used(none) instead a CB1 or circuit breaker is installed.
These breaker is in series with the power transformer ( trace it).
Disconnect the AC outputs of the power transformer when trying to
reset.( of course with the unit unplugged ).
Measure the output AC voltages, if it is OK
Be happy partially!
Next would be.....
Check for possible shorts on the Positive and Negative Supply
rails to ground or speaker out, for what might have caused the
breaker to tripped.
And these wont be easy troubleshooting , Good luck!!
thanks for choosing Fixya for assistance.
Dec 01, 2012 | Crown XLS 602 2-Channel Amplifier
I have a T5 treadmill (same as the T3, essentially) and the belt stops suddenly and the white button "push to re-cik-it" is popped out. I'm assuming this is a circuit breaker. There is a...
somthing is tripping the fuse.take hood off and check all connections with power off maybe somthing is loose or touching to trip the fuse and the red led is normal. also always plug your tread in to a surge protector. most likely the controller board
Feb 26, 2011 | Life Fitness T3 Treadmill with Advanced...
Honeywell T8411R 1028No power to the thermostat; breakers are not
site shows this thermostat is a non programmable unit and has been discontinued. none of the info sheets including a pdf shows a replacement battery. this thermostat operates off line voltage only. check for a control fuse or breaker on your heating unit.
Oct 17, 2009 | Honeywell Programmable Thermostat Heater
No power to the unit at all
recheck the breaker first put off and on if still same status then there is a fuse inside but check again the breaker or switch before
Sep 02, 2009 | Heating & Cooling
Unit Turns Off
Have you checked the breaker in the breaker box to see if it's tripped? Also check the amp rating on the air conditioner and the amp rating on the breaker the unit is plugged into, the breaker may be weak or not a high enough amps or rating for the unit it's trying to power.
Jul 01, 2009 | Friedrich QuietMaster RS10J10 Air...
Inside unit running outside want come on temp on
check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Proscan PS32500 32" TV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
