Question about Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener
Go down only if I maintain the button pressed until it is close
When I pressed and release the button to close the door, the light start blinking, and I need to mantain the button pressed until the door has been closed. If I release the button when the door is being closed, it opens again automatically and the light start blinking.
  • Anonymous Mar 30, 2008
    My door only does down when I hold the botton....If I relaes it while its closing, It will open on its own.
    One sensor light is Yellow and one is Green.
Very helpful! thank you
Posted on Aug 06, 2008
You must have hit the sensor by mistake,the sensors have to be both green,just move the one with the yellow light untill it sees the other sensor and the light will change to green
Posted on Apr 21, 2008
The problem is with the sensor at the bottom of the railing. We had to replace the photosensor on one of them.
Posted on Jan 30, 2008
Hp f30 has new ink cartidge and paper but ink button still flashing and not printing alignment page.
Here are some steps that can help you resolve the problem.
Close the cartridge access door securely, if cartridge access door is open even slightly, the print cartridge light will blink.
1. Open the cartridge access door, once carriage moves to the center of the printer.
2. Check inside the printer and make sure that there are no obstructions that are preventing the cartridge access door from closing , if there's any obstruction remove it.
3. Close the cartridge access door completely.
Do the Print Self Test
Press and hold the Cancel button, and then press the Start Copy Color button
Release both buttons at the same time
If the issue persists, Make sure that the cartridges are installed
2. Wait until the carriage is idle and silent
3. Check the cartridge slots in the carriage to make sure that the cartridges are installed.
4. Try to reinstall it again.
5. Lightly press down on a cartridge to release it, and then pull the cartridge toward you out of its slot.
6. Check the nozzles on the cartridges to see if the protective tape is still attached
Note: Do not touch the copper-colored contacts or ink nozzles
7. Hold the cartridge by its sides
8. Slide the cartridge into its designated slot at a slightly upward angle.
9. Press the cartridge inward until it snaps into place
10.Close the cartridge access door
If still the problem persist contact HP for the service.
I hope this will be able to help you.
Thank you for choosing Fixya
Mar 10, 2011 | HP DeskJet F380 All-In-One Printer
How do i program my lexus 2001 rx300 for a gate opener
You should see three buttons on the driver sun shade. Let's name them from left to right 1,2, and 3. Start by clearing any old codes. To clear codes press buttons 1 and 3 simultaneously until the light starts blinking. Release the buttons simultaneously. Before starting to program the car remotes you must have your gate hand held remote ready with a good charged battery. Now, to program your first gate car remote let's choose button 1. Press button 1 until it start blinking (about 20 seconds). Keeping button 1 pressed, activate your hand held remote close (about an inch) from the car button 1, until the light blinks faster than before. Release both remotes simultaneously. You are done programming your car remote button 1. For two additional gates remote controls programming repeat the procedure with button 2 and then with button 3.
Nov 13, 2010 | 2001 Lexus RX 300
Can open with remote, or wall-mounted button, but cannot use remote to close, and have to hold wall button down continuously (unit blinks when button is pressed and released, and stops closing until button...
If the main light is flashing 10 times when the door reverses you have a door sensor problem. Make sure they are pointed at each other and the small light on each one is lit and not flickering. Tweak them if necessary. If you cannot get the small lights to both come on you have bad sensors.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Reset the drum counter only when you replaced the drum unit with a new one.
Aug 03, 2009 | Brother HL-2040 Laser Printer
My Craftsman 139.53879 remote won't learn the code of my 1/2 HP craftsman receiver type 132C2105-3B. I followed the directions to push the transmitter button and hold the receiver button down until the...
I have no idea what a 132C2105-3B is but try this. Hold the button down on the remote and then press and immediately release the smart/learn button. If the remote is the correct one for your opener it should work.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door remote
First you have to clear any codes in there.
Hold down the outer 2 buttons until the red light blinks, could take a minute or less.
Then release the buttons, hold your garage door opener close to the button you want to program.
hold down the button on the garage door opener and the programing button until you get a blink from the little red light. That's it
Oct 10, 2008 | 2004 Jeep Grand Cherokee
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
How do you program the garage door remote?
Turn the key to the "ON" position; do not start the vehicle.
Press on the button of the 3 available to you on the vehicle and hold it until advised to release it.
Take your garage door remote transmitter, and press the button that you use to make the garage door operate, hold it down until advised to release.
With the vehicle button being depressed, and the remote button depressed, hold the remote up against the area where the 3 buttons are located. It needs to touch the area wher the buttons are.
Keep moving the remote around slowly, back & forth, spin the remote, until the red light starts to blink slow.
After the light begins to blink slow, hold the remote in that exact position until the lamp blinks real fast.
Relase both buttons.
Repeat for a second remote on another button.
Jun 29, 2008 | 2001 Toyota Sequoia
Brother printer Hl 2070. Toner light is on , changed the toner , still yellow light is on and I can't print
From Brother.com: Description:
  1. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  1. Close the front cover.
Caution
Apr 06, 2008 | Office Equipment & Supplies
Chamberlain Powerdrive PD422D 1/2 HP Security Plus Screw Drive Garage Door Opener Logo
262 people viewed this question
Top Chamberlain Car Audio & Video Experts
Glenn Mayer
Glenn Mayer
Marvin
Marvin
richie46
Are you a Chamberlain Car Audio and Video Expert? Answer questions, earn points and help others
