JVC HD-52G886 52" Rear Projection HDTV Logo
Posted on Aug 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
White blur in center of television. It shows up when televison is off and there is a very slight discoloration in same area when television is on.
Anonymous
Level 3:
President:
  • Master 511 Answers
  • Posted on Aug 30, 2009
Anonymous
Master
Level 3:
President:
Answers
511
Questions
0
Helped
153294
Points
1430
Try to defoss it remove the power connection for atleast for 20 to 30 mins the patches will disapper
5helpful
Big white blur, cloud like, Center of LCD TV
I have seen similar effects like this & it is usually due to a flaw in the screen. A replacement screen is the only cure.
The lower left 1/4 of my screen is discolored slightly. It shows red highlights in peoples faces. The area is shaped a a square or rectangle and seems to be exactly a quarter of the screen. The TV was...
it need to demagnetize using a demagnetizer or permanent magnet (PM). move the PM to the center of the tv then rotate it ccw make a round small circle to bigger circle as you move the PM away from the screen. But do not put speaker near the tv. You can also switch off the tv for a night then turn on again this process will demanetize the screen automatically but be sure no speaker put near the tv. If this will not solve the problem. it might be the technician forgot to refix the degausing coil or Thermostat.
2answers
Troubles with phillips projection tv. It is showing about a 6 Inch blurring color at the bottom of the screen and blurred color streaks throughout the screen, what could be the problem?
you need the DPTV305 - Dptv345 Convergence repair kit available at the following link. Its listed under the convergence repair kits category, comes with all parts and step by step instructions with pictures so you can do the repair yourself.
Here is the link.
http://servicemanuals.vstore.ca/
2answers
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Sony KV-32FV27 Picture Discoloration
It appears that the greenish discolored area could be cause by the Yoke or it could also be some magnetization on the screen as well.
If it's the yoke that moved slightly out of position, it can be adjusted, but i would suggest to let a repair tech do it due a high voltage around the area.
Try unplugging the TV for some time and plug it back in and hopefully the demagnetizer circuitry might be able to clear the greenish spot.
Let me know if you need further assistance.
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Screen discoloratiom area
It's definitely your VCR that is causing the problem. Move your VCR, if you don't get any results you need to send it to repair.
Pixel color fade
You are about reade to have a scan ic failure.Try to get it to a repair center asap.Have them replace the top 2 scan ic's
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
