Question about Apple eMac G4 Desktop
Print Explosion Error #116
Just went to Leopard and tried to print a card I created from Print Explosion. Received Error code 116.  Is there anything I can do to fix this problem?
  • Fehrstunkenr Dec 06, 2007
    Tried saving to pdf first, still received Error 116. Saved to JPEG and indeed I was able to print the graphic on the face of the Greeting Card, however it did not place the printing in the correct part of the card. The card has 4 sections. How am I to print each of the four parts in their correct position. All this worked perfectly when I used OS X 10.3.9 I received Leopard as a Christmas gift, but I think it sucks.
  • 749 Answers
Try saving your picture with a different format. example as JPEG or pdf first! then print it!
Posted on Dec 06, 2007
  • Rommel Balcita Dec 06, 2007
    you could try also to reduce the picture size. it might be too large for your printer memory capacity!
My canon mg5220 printer is not printing anything. It just says error when the pop screen pops up. It doesn't give me an error code.
Hi Savannah,
Try deleting the printer entry completely and add it from scratch.
Here's how:
  • Go to System Preferences
  • Print & Fax.
  • Select the printer you want to remove,
  • Click the - (minus) button at the bottom of the panel.
  • Reboot the system.
  • Run Software Update to check for the latest third-party printer software and updates.
  • Make sure the printer is powered on, has paper, and doesn't have any issues such as a paper jam or low ink.
  • Adding, managing, or removing print queues may require an administrator account name and password--make sure you know one for your Mac.
How to add a printer
To add a USB printer
Mac OS X v10.6 comes with software for many third-party printers, so simply connect a USB printer and the print queue will be automatically created. If you do not see your printer in the "Printer:" pop-up menu after connecting it, go to the "To add a printer via the Print & Fax preference pane" section below.
To add "Nearby Printers"
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on a Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
To add a Nearby Printer, all you have to do is select the Nearby printer you want from the "Printer:" pop-up menu:
Snow Leopard will automatically create the Print Queue.
To add a printer via the Print & Fax preferences pane
Control-click the System Preferences icon in your Dock and choose "Print & Fax" from the Dock menu. If the Print & Fax lock icon appears locked, click the lock icon and enter an administrator name and password when prompted. Click the + (plus) icon below the Printers pane on the left to open the Add Printer application.
From the Add Printer toolbar you have these default tools:
  1. Default - Used to get a list of all printers that your Mac can see via USB, Bonjour, and so forth. Tip: If you have a long list of printers, use the search field to find the printer you are looking for. Just click the printer in the list that you would like to add and Snow Leopard will add the printer driver for you.
    • Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. If you do not see your printer listed in the "Print Using:" pop-up menu or a Generic printer driver is selected, then the printing software may not be available from Apple. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
    • Once the driver is set, click the "Add" button to create your Print Queue.
  2. Fax - Used to add a queue for the Fax device connected to your Mac.
  3. IP - Used to add your printer network printers that don't use Bonjour or are on a different network subnet from your computer. Printers that support the Internet Printing Protocol (IPP), Line Printer Daemon (LPD), and HP Jetdirect (Socket) can be added in this manner. See your printer's manual or support documentation for information about how to setup the printer to use an IP-based printing protocol.
  4. Windows- Used to add your printer being shared via the Windows printer sharing protocol (CIFS). Tip: See Mac 101: File Sharing for details about how to add your Mac to a Windows Workgroup. This is often needed to see Windows printer shares.
Note: Any applications that are open before you add a printer will need to be quit and re-opened, in order to see all the features of the new printer.
Feb 19, 2014 | Canon Pixma Mg5220 Inkjet Multifunction...
I am running Mac OS X on an iMAC. Printer is a Canon MX310. On all prints, I am getting a vertical line running from top to bottom about 1" from the left margin. It is half blue and half pink and is...
Were you able to do a Test Print, after the Print Head clean?
Did the test print create the same line?
If the test print was normal (meaning everything printed in the test page as it should) then it is not the print heads. (It will have to be something to do with software.) Like the wrong Drivers for the Printer (for use with your operating system).
If the test print created the same line as when you are printing, then that would indicate it is more likely to be a problem with the Printer Heads, faulty print cartridges or print drums.
Canon have a website, with an Online Support enquiry form you can fill out.
In addition they have a Download section for updating drivers. It would be a good idea to check that the Drivers for your Cannon are infact the ones that are applicable for your Operating System.
(i.e., if you are running Snow Leopard, check that the drivers are for Snow Leopard).
Canons Australian website is:
http://www.canon.com.au/en-AU/Support-Services/Online-Support
If you reside in a different country, then change from the Australian website to your countries website.
I hope this information is helpful. Please rate. Regards,
Feb 12, 2010 | Office Equipment & Supplies
Is there an update for Print explosion deluxe 2.0.2. not listed here! I have an Apple Mac OSX 10.4.11 and am finding my programme very slow when changing anything. Please help me. Frustrated user
For users of Print Explosion Deluxe 3 on a Mac, Nova Development has acknowledged that the software has bugs running on Leopard or Snow Leopard. The software does crash after each operation if you do not save. I filed a complaint with the NYS Attorney General's office, to which Nova's reply was not honest Contact your state's Attorney General and let them know that Nova is selling software that has basically been sitting on store shelves for two + years, and they never tested it with Leopard and Snow Leopard. They should be required to accurately tell us what OS a software product runs on.
Sep 05, 2009 | Nova Development Print Explosion Deluxe...
Xerox Phaser 8400 error code 37,004.40:27697
The majority of the time that code means the print head has failed.
That is a print head heater error.
You can find some places that sell print heads for about $150 , you would have to google the model number for that.
Xerox would charge $750 for a new print head, uninstalled.
Apr 24, 2009 | Xerox Phaser 8400 Laser Printer
Xerox docucolor 3535 116-321 error
Unplug the ethernet cable, If it does not come up with the code then.
Search for something like internet printing turned on somewhere.
That's a freaky code that normally is associated with some odd ball print job being sent to the printer, or something trying to access the network address. It is a pain sometimes to diagnose.
Mar 16, 2009 | Xerox DocuColor 3535 Copier
Can't print to 1410 after I upgraded to Leopard
I believe I had a similar problem. Try this:
Go to System Preferences > Print & Fax > '+'
Select the Epson 1410 and then under Print Using go to Select a driver to use the Epson Styls Phot 1410 - Gutenprint v5.1.3
I hope it helps.
Jul 25, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Installing hp 3550 printer driver on new OSX leopard system
When I try to print from an access data base to the laserjet color 3500 usb printer.
Tried diff. drivers, diff usb cable, it works for a while but after several test runs the error reapears.
PCL XL error
Subsystem: KERNEL
Error: ColorSpaceMismatch
Operator: VendorUnique
Position: 9
Mar 09, 2008 | HP Color LaserJet 3500 Printer
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
Apple eMac G4 Desktop Logo
57 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
