Question about Pioneer CDJ-100S CD Player
The cd player will not load cds.
When I am trying to load a cd the player will not suck the cd in. It is as if the player is stuck in eject mode? is there any solution to this problem. Maybe there is a way to reset the cd player. Thanks for you help. My email address is
    Problem Solver:
  • 14 Answers
Re: The cd player will not load cds.
I've had cdj-100s for a while and i am familiar with cd loading issues... flip the turntable, on the underside there's a sort of key, it's ur CD eject pin, u take that and poke it in the hole in the front... that should take care of the stcuk cd, now the problem i'm having is, IMO, a derailement in the ejection system.... basically what's happening to us is that the 100s is in CD in mode... I've tried the key method, i think mine is totally all over the place, i've pressed eject and kinda pushed the cd in, i got it to run, play music (so lazer's not broke) and it would eject fine but then automatically go back to CD in mode and lock the drive.
i'm gonna take it completely apart and rebuild it... i'll post back with answers, if any!
Posted on Oct 12, 2008
0 characters
3 Points
The cd player in my car is A56820, JBL, it will load and eject cf's but not read. any fixes?
Did you get all of the CDs out of the player or are any still
stuck inside the stereo? Its the part about everything working
OK until a disc changed that makes me ask.
If a disc is jammed because it didn't load properly, you won't
be able to get all your discs out.
Oct 23, 2014 | CD Players
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
Cds play but won't eject
Try pressing eject repeatedly while you power up the unit. Procedure described here: When a disk is stuck inside the player ..
If that does not work, then the cover must be removed to take out the disk. This must be done with power off. Even if operation is quite simple, there is chance to damage the unit.
Aug 12, 2010 | Fisher CD-RW1000 2-Disc CD Recorder
Two CDs stuck inside Cambridge Soundworks 765i
I have the same problem. Did you find a solution? Thanks.
Feb 08, 2010 | Cambridge Soundworks 740I CD Player
Discs stuck inside CD Player. Screen says ''Reading.''
Try resetting the CD (Cambridge soundworks) by unplugging, then repluging. Then hold down the eject button while you turn on the power.
Nov 15, 2008 | Cambridge Soundworks 740I CD Player
Cdj mk1
sounds like a laser pick-up fault,if you havent had it repaired you can send it to us.
Oct 21, 2008 | Pioneer CDJ-1000 CD Player
Cdj 1000 mk 1 ejecting cd's
sounds like a laser fault, if you havent had it repaired you can send it to us.
Cdj 1000 mk 2 cd won't go in front load tray
sounds like a cd slot mech problem,if you havent had it repaired you can send it to us.
Oct 05, 2008 | Pioneer CDJ-1000MKII CD Player
Stuck CDs
If you don't care about the disc player and want to get the cd's out you can easily take it apart yourself[make sure you unplug it]
Dec 26, 2007 | Fisher CD-RW1000 2-Disc CD Recorder
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Pioneer CDJ-100S CD Player Logo
487 people viewed this question
Top Pioneer CD Players Experts
T-Comtech Repairs
T-Comtech Repairs
Ben Armstrong
Are you a Pioneer CD Player Expert? Answer questions, earn points and help others
