Question about Marantz SR-5200 Receiver
Shuts out after 10 minutes
I decided to umplug everything from the amp. I then pluged the amp to the wall to get power. I let the amp on for 10 minutes and it kept on turning off by itself
it would repower back u again when I pressed the power button. Any solutions?
  • 682 Answers
Please repeat your setting first- and then connect your speaker one by one until you find the bad one(after every connection you must test)-when you find the bad one change its cable first then change speaker itself.-if all above failed you must contact service center near you.
Posted on Jul 06, 2008
Technics scdv290 stuck in standby
umplug at the wall n leave for a few minutes
Apr 20, 2014 | Technics SC-DV290 System
1c2c is on controls of jenn air wall oven. not working m#JMW8530DAS
We've had a Jenn-Air wall oven & microwave, Model #JMW9530DAS for 9 years. We never had any problems with it except for the irritating dust that collects between the oven glass. After returning from a 10 day vacation, we got a 1c2c error code when pressing "Bake." The oven worked fine before we left so we were baffled. We tried other settings like "Broil" "Convect" to no avail. It kept telling us to call for assistance. We tried shutting off the power to the unit for a few minutes but got the same 1c2c error again. So we called a local appliance repair shop (associated to the appliance store we purchased the unit from) and paid a fee to have him assess the problem. He really couldn't pinpoint the problem but suggested it "could be the membrane or the controller." And, to top that, he said Jenn-Air stopped making the membrane but they are going to start making them again and we could get one in 6-8 months at a cost of $500. So now we were looking at a $300 controller & possible $500 labor. We were so frustrated that we decided to tackle the problem ourselves before going out and buying a new oven. We shut the power off and tried pulling the oven out of the wall. Too heavy. After about 20 minutes of the power off, we turned it back on and decided to use the "SetUp" feature as if we were using the oven for the first time, following the directions in the instruction manual. We stepped through the process (clock, auto convect, language, C/F, etc...) then pressed the "Convect" button (instead of "Bake") and voila! It worked! After the Convection Bake Preheat worked successfully, we pressed "Bake" and it worked, too. We just saved ourselves over a thousand dollars as we were going to get rid of the piece of junk. So, before you give up, try turning the power off for a half hour & use the SetUp key and walk through the process.
Feb 13, 2013 | Jenn-Air 27 in. Electric Single Wall Oven...
Marantz amp freezes... What could be the problem?
From the description you have a microprocessor control problem, the only thing I can suggest is unplug everything from the amp, including speaker wires, and anything that is hooked to it, remove plug from wall receptical and let the amp sit for 30 minutes in a effort to get the processor ic to reset. If there is no change you will need a professional to resolve this issue and I recommend a estimate.
Apr 01, 2012 | Marantz NR1501
When pluged into the wall for power only internet globe on router lights up and flashes also all four light for ethernet ports are flashing though only one is conected and isnt sending any signal through...
Try powering down everything (pc, router, modem), for a few minutes (unplug the router and modem). The power back up again and try re-establishing a connection.
If that doesn't work ask for a paid expert or try your ISP
Good luck
Nov 20, 2010 | Computers & Internet
We pluged it in and it worked and now it dont
If you changed the settings or unplugged it or the power to the house went out, then you have to wait a few minutes before the compressor can start up again. There is a sticker on the fridge that warns about that.
If it still hasn't started up when you read this, then:
1. Set the temperatures where you want them for the freezer & refrig.
2. UNPLUG power cord for 10 minutes (don't open either fridge or freezer).
3. Wait a full 10 minutes! Nothing will melt... check breaker to outlet, just in case...
4. Plug in power cord... It will start now..
Hope this helps!
Sep 15, 2009 | Amana Refrigerators
My netbook wont boot, i turn it on and i will hear the fan but nothing else, i was using it everything was going well, the batery ran out and it went into sleep mode, i pluged it in and since then i canot...
Leave it plugged in for about 10 minutes. The battery just needs to charge a little more. Then you can come out of sleep mode.
If it is locked in sleep mode. Just hold the power button down to shut off the computer. Let it charge, you can now reboot, and keep charging after about ten minutes.
Jun 28, 2009 | Acer Aspire 5100 Notebook
Olevia 332h comes on for a few minutes then turns off
I have the same problem with my Olevia 332h. The TV shuts off after 10 seconds. I decided to wedge a desk fan in between the wall and the back of the TV. It worked! The TV doesnt shut off anymore. This problem is obviously heat related. I hope this information helps you.
Jun 03, 2009 | Olevia LT23HVX 23 in. LCD Television
Player shutting down after 10 seconds
Shutting down completely like power is gone or just DVD stopping with power on? If completely shutting down the look in power supply and find bad capacitor and replace. If DVD stops with power then look at laser, clean or maybe damaged.
Sep 14, 2007 | Polaroid PDV-1002A Portable DVD Player
10 minutes of background processing when coming out of stand-by...What is going on
Click Start, Run, type msconfig. Click the startup tab. There will be a list of all the programs that start up when your computer starts. You should uncheck everything you don't need. Pretty much everything except antivirus.
Sep 11, 2007 | IBM ThinkPad T23 2647 Notebook
Marantz SR-5200 Receiver Logo
199 people viewed this question
Top Marantz Audio Players & Recorders Experts
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
