Question about Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook
Computer turn-on problem
Computer turns on but soon goes to a darker gray screen with a window that reads: "You need to restart your computer. Hold down the Power button for several seconds or press the Restart button." This is repeated in several additional languages. Of course, restarting the computer just leads to the same screen. Sometimes I get a light blue screen with nothing on it instead of the window described above.
  • 1 more comment
  • Soss Feb 26, 2008
    My wife has a new mac from her school district and is having the exact same problems!
  • MacBk1080p Mar 04, 2008
    I'm getting this same message on my MacBook Pro. by going to a Safe Boot mode I get a usable standard Desktop for a short while. Then the screen goes dark gray and this statement appears, "You need to restart your computer. Hold down the Power button for several seconds or press the Restart button." This is repeated in several additional languages. Of course, restarting the computer just leads to the same screen.
  • Anonymous Mar 09, 2008
    My MacBook Pro states the following,  "You need to restart your computer. Hold down the Power button for several seconds or press the Restart button." This is repeated in several additional languages. restarting the computer repeats the 'startup request" I've restarted in the safe mode, but after a short while the goes back to requesting a restart.
What you are experiencing is simply a kernel panic. (for more information read http://support.apple.com/kb/HT1392?viewlocale=en_US ) more often than not it's just a bad instruction coming from one program to your computer. if you aren't running any applications when it happens it may be related to recent hardware installations. if it's happening close to start up i'd suggest you begin by looking at what applications you have set as start up items.
Posted on Jun 03, 2008
  • 383 Answers
dot.gif POST troubleshooting steps. Question: Post troubleshooting steps.
Additional information: This document is intended to help users who are experiencing issues with the POST and may have any of the below symptoms.
  1. Computer beeps irregularly when the computer is turned on.
  2. Computer turns on but does not boot.
Note: Not all computers have beep codes, some of the newer computers have LED's that light up that indicate the error or have a sound file to indicate the error.
Cause: This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Answer: Warning: Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards. Information about ESD and proper grounding techniques are found on our ESD help page. Note: Make sure your computer is turning on, if you press the power button and nothing happens (no lights, no sound, no fans, etc.) then this issue is not a NO POST but is an power related issue see document CH000312. Remove new hardware If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.
Disconnect external devices Remove everything from the back of the computer except the power cable. Turn on the computer and see if it beeps normally. If the computer has never beeped keep the monitor or display connected to see if any change occurs.
Identify beep code If you are receiving a sequence of beeps see our beep code page for a listing of different beep codes and their explanation and/or your motherboard or computer documentation. These beep codes are meant as a method of quickly identifying what computer component is failing or bad.
Check all fans Make sure all fans are running in the computer. If a fan has failed (especially the heat sink fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
Check all cables Verify that all the cables are properly connected at that there are no loose cables by firmly pressing in each cable.
  • All disk drives should have a data cable and power cable connected to them.
  • Your power supply should have at least one cable going to the motherboard. Many motherboards may also have additional cables connected to them to supply power to the fans.
Disconnect all expansion cards If the above recommendations still have not resolved the irregular POST attempt to disconnect the Riser board (if applicable) and/or each of the expansion cards. If this resolves the issue or allows the computer to post connect one card at a time until you determine which card is causing the issue.
Disconnect all drives If you were unable to determine by the beep code what is failing or do not have a beep code disconnect the IDE, SATA, SCSI, or other data cables from the CD-ROM, hard drive, and floppy drive from the Motherboard.
If this resolves your irregular post or you now get an error message attempt to re-connect each device one at a time to determine which device and or cable is causing the issue. In some situations it can also be simply a loose cable connection that causes the issue.
Remove the RAM If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
Power cycle the computer In some situations a computer may have power related issues often caused by either the power supply and/or the motherboard. To help determine if this is the cause of your issue try turning the computer on, off, and back on as fast as possible, making sure the computer power light goes on and off each time. In some situations you may be able to temporarily get the computer to boot.
This should only be used as a temporary workaround if you're able to get this to work. Often this is good for users who may have not done a backup and need to get the computer up one more time to copy files before starting to replace hardware.
Disconnect and reconnect the CPU For users who are more comfortable working with the inside of their computer or who have built their computer one last recommendation before assuming hardware is bad is to reseat the CPU by removing it and putting it back into the computer.
Bad motherboard, CPU, RAM, and/or power supply If after doing all of the above recommendations you continue to have the same issue unfortunately it is likely that you have bad Motherboard, CPU, and or RAM. The next step would be either to replace these components and/or have the computer serviced. If you plan on doing the repairs yourself or you are a repair shop it is suggested that you replace the Motherboard first, RAM, CPU, and then power supply in that order and/or try swappable parts from other computers.
Posted on Dec 06, 2007
  • 749 Answers
Your computer was definitely been infected with a certain type of virus triggering your system to initiate undesirable programs enabling like the one's you're encountering!
Cant reboot after failed Windows 10 update. Tried to restart with Gateway Recovery Mgt.program.
Try this:
Start the computer. As soon as the "Starting Windows" screen comes up (not the Gateway/eMachines screen), hold down the Power Button to shut off the computer. This might force the computer to go in to Windows recovery mode when you restart. Now, turn on the computer, and it should go to a "Windows Diagnostics and Recovery" page. Choose Diagnose the Problem or whatever it says, follow the instructions.
Good luck.
Jan 14, 2018 | Gateway Computers & Internet
Aspire 5336-2524 will not boot up
Try this:
Start the computer. As soon as the "Starting Windows" screen comes up (not the Acer screen), hold down the Power Button to shut off the computer. This might force the computer to go in to Windows recovery mode when you restart. Now, turn on the computer, and it should go to a "Windows Diagnostics and Recovery" page. Choose Diagnose the Problem or whatever it says, follow the instructions.
Good luck.
Jan 16, 2018 | Acer Aspire 53362752 Notebook
Mercury mother bord not loding satup manu with all f key and 'del' stop in start screen
1) Look at the bottom of the Mercury logo screen when it comes up.
2) Memorize or write down the -> enter BIOS Setup, or enter CMOS Setup key.
3) Restart the computer.
Let it go to Windows, then Start > Turn Off Computer > Restart.
Won't go to Windows? Hold down the CTRL and ALT and DELete keys AT THE SAME TIME. This will restart your computer.
AS SOON AS the monitor screen goes blank, (Windows is restarting), tap on the enter BIOS Setup key repeatedly.
Tap in 2 second intervals.
Hear a series of beeps? They are Stuck Key Error Code beeps, and you are causing them. Ignore the beeps.
Computer is off?
AS SOON AS you press the Power On button, start tapping on the enter BIOS Setup (CMOS Setup) key.
The enter BIOS Setup window goes by F-A-S-T. The above method/s will get you into BIOS Setup.
Regards, joecoolvette
Nov 05, 2012 | Computers & Internet
Is there a way to change windows xp bios settings after boot up, particularily using the command line?
My knowledge of using the command line is equal to my knowledge about astrophysics. Zero.
You can change BIOS settings in the BIOS Setup utility. After the computer manufacturer's splash screen, (Logo screen), and at the bottom of the screen, are shown the key/s to press to enter BIOS Setup.
Goes by real F-A-S-T. Try to write it down. Let Windows load all the way, then restart the computer.
As SOON as you see the manufacturer's splash screen, start tapping on the key/s to enter BIOS Setup. If you miss this window of opportunity, let Windows load all the way. Turn the computer off normally. (Wait at least 20 seconds) This time as Soon as you press the Power On button, start tapping on the appropriate key/s. (In 2 second intervals) You don't get as far as the splash screen? Then unplug the computer from power. Observe Anti-Static Precautions. Remove the CMOS battery, (CR2032), for 1 minute. Press the Power On button in, and hold it in. Hold it in for a count of 5 seconds. Let go of the Power On button. Do this procedure two more times. Install the CMOS battery. Plug into power. WAIT 1 minute, turn the computer on. This procedure will set the BIOS Settings back to the factory default settings, and clear CMOS Error Codes. Post back as to your findings.
Sep 14, 2011 | Computers & Internet
I need to reset my WD800UE Scorpio 80 gb hard drive. how do i do it?
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT. Click Restart when prompted. Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps don
Feb 27, 2011 | Computers & Internet
Startup computer and all of desktop is there. then the screen goes to blue and then back to normal. This continues to repeat over and over. Any ideas? Warren
You may need to restart the PRAM and NVRAM:
Resetting PRAM and NVRAM
  1. Shut down the computer.
  2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
  3. Turn on the computer.
  4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
  5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
  6. Release the keys.
Nov 13, 2010 | Apple 24" iMac Desktop
I have a HP Compaq dc5700, and i want to set it to default settings. I do not have any passwords for it. It has windows vista. i tried going to setting(f10) and it asks for a password. I removed the...
Password Security
Establishing a Setup password:
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down >
Restart.
2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter
Computer Setup. Press Enter to bypass the title screen, if necessary. If you do not press F10
when prompted, a restart will be necessary.
3. Select Security > Setup Password and follow the instructions on the screen.
4. Before exiting, click File > Save Changes and Exit.
Restart.
3. Select Security > Power-On Password and follow the instructions on the screen.
Changing a password:
1. Turn on or restart the computer. If you are in Windows, click Start> Shut Down > Restart.
To change the Setup password, go to step 2.
To change the Power-on password, go to step 3.
2. To change the Setup password, as soon as the computer is turned on, press F10 when the
monitor light turns green to enter Computer Setup. Press Enter to bypass the title screen, if
necessary.
3. When the key icon appears, type your current password, a slash (/) or alternate de-limiter
character, your new password, another slash (/) or alternate delimiter character, and your new
password again as shown:
current password/new password/new password.
NOTE: Type the new password carefully since the actual characters do not appear on the
screen.
4. Press ENTER.
The new password will take effect the next time the computer is restarted.
Deleting a password
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down > Restart.
To delete the Setup password, go to step 2.
To delete the Power-On password, go to step 3.
necessary.
3. When the key icon appears, type your current password followed by a slash (/) or alternate
delimiter character as shown. Example: currentpassword/
4. Press Enter.
from
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00794304/c007943
04.pdf
Feb 09, 2010 | Computers & Internet
Stuck on the restart your computer screen.
You may have installed something in the startup items folder that your mac isn't liking.
When you turn the iBook on, press the shift key as soon as you hear the startup tone. hold it down until you see the gray apple screen. This will get you into safe mode, hopefully then you'll be able to fix whatever you did from there. If you are still at a loss, get in touch.
Dec 11, 2008 | Apple iBook G4 Mac Notebook
I have a shap lcd computer monitor and when i plug it into my computer and turn the power on, the little green power light comes on, screens back. and after 5-10 seconds the light turns orange and blinks...
It could be your monitor is fine. It simply goes to a cycle when its turned on and does not detect any signal coming from your CPU, it simply goes on standby mode (hence the darker image and orange/blinking light.) have you checked the computer (CPU) part?
Dec 04, 2008 | Computers & Internet
Gray Screen
I had a very similar problem where my Sansa would turn on show the initial logo then fade to a white/grey screen and restart. To fix it started in recovery mode (Start in hold mode with rec button held down) then used the firmware updater to update the software and it seems to had fixed the problem hope this also works for you
Jun 01, 2007 | SanDisk Sansa e250 MP3 Player
Apple MacBook Pro Laptop Computer with Intel Duo Core 15.4 Inch PC Notebook Logo
144 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
