Question about Samsung WF203ANW Front Load Washer
Not enough water in the drum during the washing cycle
Recently i bought a new front load washer Samsung WF203ANW ,( i am used to top load washer), so i don't know how much water it supposed to have in the drum during the washing cycle, because i noticed there isn't enough water during the wash, the clothes are only wet. is it supposed to fill with a lot of water or not? thank you for your help
  • Anonymous Mar 26, 2014
    water pools in drum
  • 574 Answers
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers
Posted on Aug 30, 2009
SOURCE:
Is there any way to adjust my front loader Samsung to have more water during the wash cycle? I was washing one light blanket and during the wash cycle I had to add a dish towel, when I put my hand into...
Hello
Remember this washer is a water saver.I have the same question on my new washer.What i do is increase the size of the load.
Instead of running it on light load, ill put it on heavy this will allow more water to fill.
May 04, 2011 | Samsung WF203ANW Front Load Washer
My front loading Samsung washing machine does not seem to have enough water in it during the wash cycle. In fact, you can not see any water at all. The clothing only appears to be moderately wet.
run the unit with no clothes in once it has stopped check the water level. in the rear of the tub the water hould be 3 1/2 inches deep and 14 inches wide.and will taper off towards the front of the drum.
Nov 28, 2010 | Samsung WF203ANW Front Load Washer
I just bought a samsung front load washer and when I starts the spin cycle the drum sounds like it is hitting the side if the washer. Once the cycle is in full motion it is smooth with out the knocking...
you are putting an uneven load into it ,ie a couple of towels and a pair of socks if you get what i mean,try waiting until you have a good load before starting a cycle you will see the problem is not there anymore.adrian,,,,
Sep 12, 2010 | Samsung WF203ANW Front Load Washer
We just bought a front loading machine and it seems to have hardly any water while washing. How much water should there be? Right now it looks like only the clothes are wet but no other water sitting in...
Front load washing machins are very water conservative. In fact a lot of moldern F/L washers use so little water that it doesn't even come up to the bottom of the door.
If the machine completes it's cycle, it obviously 'thinks' it's getting enough water to continue..
IMPORTANT...Do not overuse detergent!! This can seriously shorten the life of a F/L...! You're treating the amount of water...NOT the amount of clothes...Happy Washing
Good luck....Nomess
Aug 04, 2010 | Samsung WF203ANW Front Load Washer
The washer leaves water remaining in drum after the entire wash cycle, it becomes stale and makes my clothes that I was smell. My father's front loader, GE, does not leave any water in the drum
Hello
Check the drain tube,it needs to be 30 inches above the floor.
Also if the drain tube from the washer is too far into the drain the washer will not drain completly.The drain tube should be 1 inch into the wall drain.
Also check for kinks or obstructions in the washer drain tube.
May 13, 2010 | Samsung WF203ANW Front Load Washer
Water in drum
The swish water sound that you hear in the drum is normal. There is some liquid in the drum for balancing. The washer doesnt use that liquid for laundry. The odor smell - you can get rid of it by cleaning your washer. Run empty cycle with bleach and hot water at least once a month. Also use washer cleaner - Tide recommended for a nice cleaner smell. You can get it from any supermarket.
Sep 29, 2009 | Samsung WF203ANW Front Load Washer
I have a samsung energy effecient front load washer machine ...I was wondering about the wash cycle ...is there always just a few cups of water in the drum to wash my clothing??...is this normal ..how can...
If its a High efficiency washer it doesn't use much water. Usually the front load washers are HE washers.. and you should use a HE detergent , it doesn't produce a lot of suds but it does clean( my clothes are very clean )
Sep 01, 2009 | Samsung WF203ANW Front Load Washer
Samsung Front Load washer has odour
IMPORTANT: Read thoroughly. DO NOT add detergent or other laundry products to this cycle.
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. If the bad odour persists, repeat the procedure 1 or 2 more times. This may be necessary if this is the first time you have run this cycle.
7. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
8. Repeat the cleaning procedure monthly.
To maintain the washer freshness:
1. Use only HE High Efficiency detergent.
2. Leave the door open after each cycle to for better ventilation and drying of the washer interior.
3. Use warm / hot water in your machine unless the fabric you are washing requires cold.
4. Use the correct amount of fabric softener.
5. If your laundry room is damp, use a dehumidifier.
6. Clean the door seal of visible residue.
Smell in washer SAMSUNG WF203ANW
NO is the outlet pipe fitted properly so that water cannot drain back into washer after use
Jun 30, 2009 | Samsung WF203ANW Front Load Washer
Samsung WF203ANW Front Load Washer Logo
1,741 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
Paul
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
