Question about HP DeskJet F380 All-In-One Printer
Won"t print- will copy:
I took my computor and had it reprogramed.I've teaching my self for about the last 5mo.sign will pop up and says add printer I don"t know what to do.
  • Anonymous Dec 11, 2007
    I changed the black ink cartridge as directed .The machine will copy but will not print if I tried to print an article from the net
  • katkttnwlf Nov 22, 2008
    tryed the solution and still will not print add new ubs connection get an error in status printng box tryed setting different ports also re-installed
    printers saying its ready and 2 jobs waiting its a hp business inkjet 2200/2500 computer still not seeing connection to printer and rechecking all conection
    Scholar:
  • 103 Answers
You need to reinstall your printer driver. If you have the installation cd,
1. unplug your printer from the computer,
2. install the driver from the cd,
3. plug your printer back into the computer
4. turn the printer on
5. print your document.
If you do not have the installation cd, try the printer manufacturer's web site for the print driver. Before installing the driver, disconnect the printer from the pc to make sure installation goes smoothly.
Once the driver is installed, when you plug the printer into the computer and power it on, the computer will find it and finish the installation process automatically.
This will not help the problem posted by guest. His problem is totally unrelated.
Posted on Dec 15, 2007
  • jstcorp Mar 09, 2011
    I INSTALLED HP DESKJET ALL IN ONE 2050, J510 SERIES. BUT SCANNER NOT WORKING. IT KEEPS SAYING "SCANNER NOT READY" AND GIVES AN ERROR MESSAGE 0X00000051. WHAT IS THIS????
HP C6280 will not print self test diagnostic
Do you have an Anti-Virus program installed on your PC? If so, can you try and disable it before you print.
for more help visit CBR Tech Solutions
Mar 13, 2013 | HP C6280 All-in-One Printer
Tip
How to make your printer print again on a MAC OS X
If you can’t print and you’ve tried other solutions, reset the print system. The process deletes all printers from your Printer list, deletes information about all completed print jobs, and deletes all printer presets.
1.) Select Apple menu > System Preferences and click Print & Fax.
2.) Hold down the Control key as you click in the Printer list, and choose “Reset printing system” from the pop-up menu that appears.
3.) then, Add the printers you use.
on Dec 22, 2009 | Computers & Internet
I replaced both ink cartridges for the printer, won' print.
Please follow the procedure your printer has which forces it printer to clean the print heads.
I have experience of other epson stylus models.  I have previously spoken to epson about this exact problem.  Repeating the head cleaning process a minimum 5 times cleared the problem.
Running head clean multiple times in succession builds up pressure in the print heads - causing (usually new) cartridges to work correctly.
kind regards
Jan 27, 2009 | Epson Stylus 880 InkJet Color Printer
My Hp Officejet 6300 All-In-One printer will not copy
printer is offline yet cables are connected and printer was working a day or so ago!
Jan 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
Konica minolta c252 how to sharing pc....
If you are just adding your PC to the network first go to control panel click network set-up wizard.
to add your PC to print add printer from the control panel and look for the network printer. last you want to scan go the internet web browser input the ip address of the scanner or copier click public or administrator enter password 12345678 and click scan tab and add your PC host name or your email address if scan to email.
HH
Jan 10, 2009 | Konica Minolta bizhub C250 All-In-One...
Kodak all in one printer
Oct 23, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
HP All-In-One Printer
I think that the Drivers have failed to communicate.Just try the steps below.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HP Photosmart c4100)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
Mar 12, 2008 | HP Photosmart C4180 All-In-One InkJet...
Lexmark 2500 wont upload on computor
Go to your control panel (found via start and then settings) and then go to add/remove programs make sure everything to do with your lexmark is gone. If not then remove it via this area. Then go to Start/settings and then printers make sure your lexmark is not in there either. If it is remove it from there. Start your install again after a reset of the computer and you should be in business.
Dec 24, 2007 | Lexmark All-in-One Printer with PictBridge
Dell Photo 964 - unsupported cartridge
How is it plugged first of all, did you set it up as a dell printer in add printer? try adding it as a HP printer since they are HP printers with the Dell name.
Oct 04, 2007 | Dell Photo 964 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
91 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
