Question about JVC AV-27820 27" TV
JVC AV-27820 27
When you first turn it on, the red light in front flashes, you hear a clicking noise on the board, than once that is down for a few seconds, then you hear static in the speakers. Any ideas, and if it requires a shop visit is it really worth it?
  • ixprunner Dec 06, 2007
    corrections: down=done*, also there is no picture or anything comes up on the screen.
  • 749 Answers
Shorted components causes continuous ticking/clicking sound from inside the set! it would really need a shop visit since you have no picture display! if you could trust the service person then it could be worth sending it to a shop!
Posted on Dec 06, 2007
Hi there TV is a JVC AV-36F713. Turned TV on a few days ago and nothing. Red flashing light on bottom of TV. Looked it up and manual said needs repair etc. Any ideas? Thanks Tim Also...
Hello Jim O'Connell,
Welcome and thank you for using FixYa!
To answer your question: I would suggest having a television repair professional pull out the power supply board.
They will need to remove the board and check it for bad (cold) soldier joints, bad capacitors, and lastly, to use an Osilliscope to test the +5v and -5V transistors on the board. If they can't diagnose the board, they can use the part number to order and install a replacement for you. That should fix your issue.
Have a great day!
Oct 15, 2011 | JVC AV-36D502 36" TV
JVC TV has flashing red light in front. TV won't turn on when red light starts flashing. After unplugging tv for a while, TV sometimes turns on but screen is shaking violently. Any flashing lights...
sometimes a leaky filter capacitor in the power supply primary section could caused this problem,or a loose solder connection in the power supply section
Jul 18, 2011 | JVC AV-32230 32" TV
Whenever i plug the unit in i hear a clicking sound from the back of the television it is for about 3 seconds and it usually takes 2-5 seconds before it starts the noise. The power light only comes on for...
Ur tv turn on now,hear alot of clicking?The tv LED light "lamp" on front panel flashes or light up?The tv projection lamp is dead.The Ballast board dead too,if hear alot of clicking?The ballast board help to ignite the projection lamp.
Jul 16, 2010 | JVC AV-56P575 56" Rear Projection...
Clicking on the power supply board(no picture or sound)
If you hear a buzzing, humming or rapid clicking noises this could be a problem with your ballast.Might be a good idea though to pull out your lamp just ensure its not damaged.You can find these at
Apr 01, 2010 | JVC AV-48P575 48" Rear Projection...
My 1080p Mitsubishi television suddenly stared to switch itself off and then a red light would flash for a minute. When I turn it back on I am geeting sound for a few minutes and then it switches itself...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it : But if you don't hear any strange noises,tv is around 4000 hrs,1-3 yrs it could be time to replace the lamp.The lamp you need is 915b403001 .Have a blessed one!
Mar 29, 2010 | Mitsubishi WD-60735 Projection Television
When powered on, automatically shuts off with red flashing light.
you can claim the repair on your home insurance policy as FUSION
Sep 13, 2009 | JVC AV-27920 27" TV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
No picture, clicking sound coming from speakers, power light blinks
visit for an immediate solution to this problem.
Jun 30, 2008 | JVC AV-56WP30 56" Rear Projection...
TV wont power on, clicking noise and flashing standby led
Sounds pretty bad to me, I had a computer monitor that did a similar thing when plugged in after blowing, it's not a good thing. I didn't even bother to mess with it. You may have to replace the whole power board or at least have a whole handful of pieces to re-solder. It most likely isn't worth it unless your other tv's are under 30" and you don't have a lot of money ;)
- Dave
Dec 28, 2007 | JVC AV-32D305 32" TV
JVC AV-27820 27" TV
probably some cold solder joints. take your time and check over whole circuit board and re-solder what looks bad.
Jun 10, 2006 | JVC AV-27820 27" TV
Televison & Video Logo
211 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
