Question about Panasonic DVD-S27 DVD Player
Trying to connect dvd player
I cant get a picture...i have a cable box, and wires coming thru the wall from the plasma...i need to connect dvd to cable box, and i dont know how..or if i can
Connect cable from cable box (both Video and Audio out) the other terminals to dvd (both Video and Audio in). After this select from video the line, i.e. L1, L2, etc. if you don't know exactly what line you shou;d choose, try them starting with L1. you have to be sure you tuned the TV to the right chanel to be able to watch the DVD player.
Posted on Dec 06, 2007
  • 537 Answers
You will have to connect your DVD player to the plasma TV, not the cable box. The cable box (or most cable boxes) have video outputs only. The same is true for the DVD player: it outputs the video to the tv.
Look in your DVD manual for scenarios for connecting your player to the tv.
Mike
Fix tv picture
If the TV is receiving its signal from a cable TV box or DVR then you need to find out if the problem is in the TV or the cable box/DVR. Connect a different source to your TV such as a DVD or Blu-ray player and play a DVD movie. If the problem occurs again it suggests the TV needs repair. If the TV works OK when playing a DVD movie then that suggests that your cable box/DVR needs repair or replacement.
If your TV is receiving its signal directly from an antenna or cable outlet on the wall then you should try replacing the cable wire from the wall to the TV with a new wire. If that doesn't help then your TV probably needs repair or replacement.
Dec 29, 2015 | Sanyo Televison & Video
How to hook up a panosonic 50" Flat screen plasma
Try connecting TV to DVD with a scart lead or a hdmi cable now hdmi v cables are the next best thing from a scart lead
Dec 21, 2011 | Televison & Video
Just got a hitachi 42hdt50m model plasma and cant figure out how to hook up cable. we have no cords that came with it. what do we need
You're going to need a coax cable about the length of the distance from your TV to your cable source, either the wall outlet or your digital cable box provided by your cable provider.
For good measure, get yourself an HDMI cable if you have certain digital cable boxes, DVD or Blu-Ray players. check out cablestogo.com for inexpensive cables. Don't get suckered into the expensive cable.
Good luck.
Apr 13, 2011 | Hitachi 42PD3000 42 in. Plasma Television
How do i get a picture thru component 2 so i can get 1080i quality. i only get a picture thru component 1.
You would need to unplug the input cables in the TV and move them to component 2 on the back. Assuming your input is at 1080i in the first place (ie, the cable box or digital satelite signal is coming in at the proper resolution). One way to check is to connect an external DVD player to the component 1 input and see if the picture is higher quality than the signal from the Cable/Satelite. Not sure changing to component 2 is going to make a difference. Good luck and let me know what happens!
Nov 04, 2010 | Akai PDP5090 50 in. HDTV Plasma Television
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
The best way to connect a fujitsu PDS4233 42" plasma display screen without HD built in to a AWA DP602 5.1 DVD player .
sat/calbe coax from wall into box. hdmi(best) or component out from box to tv. change all settings (box and tv) to hdmi or not hdmi then select the correct input same with dvd hdmi again best cable no need for audio cables as well
Sep 19, 2008 | Televison & Video
Sound system
check your wire connections they could be faulty if you are doing the connection properly.
May 14, 2008 | LG 42PX5D 42 in. Plasma HDTV
No picture but sound
How did the cable person hook up the cable? Was it thru an rf connector and you need to put the tv on A channel . Or are there video and audio cables from the cable box to the tv? We need to have more info please. Thanks
Jun 12, 2006 | Philips 42PF9630A 42 in. Plasma Television
Panasonic DVD-S27 DVD Player Logo
355 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
