Question about ViewSonic VX900 19" LCD Monitor
Viewsonic VX900 blank screen
My Viewsonic VX900 gave up the ghost the other day. The screen went completely blank. After reading this site for a while, I tried a few things and found that there is an image that I can see if I turn the room lights off and shine a flashlight on the screen. This leads me to suspect either a bad inverter or a bad CCFL/backlight. So the next thing I did was partially disassemble the beast. I found that there are 2 CCFLs mounted in a single reflector. The bulbs look okay to me (not that I would know what they'd look like if there weren't okay). The inverter also looks okay (same disclaimer).
Individual CCFL bulbs cost maybe $15 and I'd need 2, but to be honest, disassembling them from the reflector looks tricky and I don't really want to be messing with mercury vapor either. The assembly (2 bulbs in reflector) costs $70. New inverter also costs $70.
My question is, is there any way to try and figure out whether it's the backlight or the inverter? I don't have any sophisticated testing equipment like an oscilloscope but I do have a volt/ohmmeter. I'd like to only spend $70 once, not twice on a new inverter AND a new backlight if only one is broken.
  • 1 more comment
  • washboat Mar 04, 2008
    yes I have the same problem and another. fortunately, I used my ohm/volt meter. I found out that one fuse on the inverter was busted and the resistor connected to the 12v end supply to the main board with no continuity. My problem now is to find a schematic, the correct part # and a supply store.
    Can any one help me? thanks.
  • techmiller Mar 22, 2009
    i have a viewsonic vx900 and the screen is blank, with a signal going to the screen and push the power button the image will apear
    for a few seconds then disappear, it will do this over and over. is there a capacitor issue in keeping the bulbs energized. or are the bulbs gone.
  • Anonymous May 01, 2009
    Same problem, Fuse 1 is cooked. Anyone know what size to replace it with. I want to go to a local supply store and pick up a new one to attempt a solder job on it.
  • 7 Answers
Here is a pic of the fuses on the inverter board for a Viewsonic vx900, you can visually inspect them as well if you do not have a volt meter. While visual inspection is not 100% reliable, usually when these are popped you will see the red line across them is black or broken.
Posted on Jan 03, 2009
    Problem Solver:
  • 7 Answers
There are 2 fuses on the inverter board. your meter will be able to check which is the bad one, My guess is that is the one that does not have the capacitor next to it. the fuses are small suface mount style.
Posted on Feb 10, 2008
Hey fuzzytek, can u take a picture of which fuses ur talking about? also is it always the fuses when the infamous vx900 turns on then off? could it be the capacitor?
Posted on Feb 15, 2008
Trouble shooting
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Apr 05, 2013 | ViewSonic Computers & Internet
My ViewSonic VX900 works great for several days and then the screen turns black I have to unplug it to reset it. It will not respond from the mouse to restore the screen. When you move the mouse you see a...
Often problems with LCD monitors can be traced to bad capacitors. The following sites will help you identify if your monitor has bad capacitors, and how to replace them.
www.fixyourmonitor.com and http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Feb 07, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
Have an old view sonic vx900 (~5yrs old). When you
Check the fuse on the inverter board and also verify it does have have 12vdc feeding the fuse. Worst case will be the lamps, power supply caps look OK?
Jan 18, 2010 | ViewSonic VX900 19" LCD Monitor
View sonic VX900 how do I install monitor
Home ViewSonic Monitor VX900. Download ViewSonic Monitor Driver ... Install Windows Driver How to install a Windows Driver properly and avoid possible problems? ...www.nodevice.com/driver/VX900/get36587.html
Dec 04, 2009 | ViewSonic VX900 19" Flat Panel LCD Monitor
The power light is red and blinking rapidly, screen blank
is it plugged into wall or a surge? may make a difference. Some screens require certain amount of KV and some surge protectors have less KV than needed to run some things. good luck
Oct 01, 2009 | ViewSonic VX900 19" LCD Monitor
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Viewsonic VX900 LCD Monitor No Display.Bcklt and Screen Menu Work
It looks like you have to replace mainboard (it doesn't take input signals)
Mar 26, 2017 | ViewSonic VX910 19" LCD Monitor
Vx900 dispays for a second and goes blank.
is the vx922 worth fixing? my neighbour found it now i trying to fix it. wheres the capacitor, or the other thing to look at, as the screen goes black but button stays green..... i need diagram or simple play by play.
Apr 17, 2008 | ViewSonic VX900 19" LCD Monitor
ViewSonic VX900 19" LCD Monitor Logo
2,364 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
