Question about Intel D101GGC Motherboard
Amd ms6378 motherboard / windows xp
I have a amd msi 6378 motherboard and when i try to install windows xp it always comes up with it cant find or read the cd, ive tryed at least 3 different hard drives,cd roms but only have one 256mb ram stick...also have reformatted the hard drives loaded the fail safe devics on the bios system...and no matter what i do it just keeps coming up with windows cant find the cd...plus i know my xp cd and xp professional cd is Genuine but still it wont read or find them, can u please offer some assistance if at all possible
Waspro n720 how i chang windows xp
Posted on Jul 08, 2011
Quero saber qual é o Tipo de Hd e o Cache De Disco Da Placa Mãe Msi Ms-6378
Posted on Oct 22, 2008
Drivers de Placa Mãe MSI MS 6378
Posted on Jul 12, 2008
  • 56 Answers
This may be a silly question, but have you set your BIOS to boot from CD first?
When you get to the post screen press any key to boot from cd.
The you can folow the prompts to go through the rest of the setup.
If this is what you are doing can you go into more depth of where you get up to?
Posted on Dec 06, 2007
4 Suggested Answers
Emperor Hari
  • 42 Answers
SOURCE: PC400 Motherboard, M930 Series
upgrade you drivers and it should work fine... you got loads of them on the intel site for free... http://downloadcenter.intel.com/
download the most appropriate of drivers and then try
hope this hels... good luck
Posted on Sep 26, 2008
  • 2567 Answers
SOURCE: SM Bus Controller and Video Controller (VGA Compatible) drivers
You can download all Windows XP Home Edition drivers for the Intel D101GGC motherboard from Intel's web site at the following link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2229&OSFullName=Windows*+XP+Home+Edition&lang=eng&strOSs=45&submit=Go!
Posted on May 15, 2009
SOURCE: Intel 845 GVSR drivers for windows vista
Fix for older motherboards like Intel 845GVSR etc.,
HERE IS THE SOLUTION FOR FIXING DISPLAY PROBLEMS....
(This solution works for any Intel Motherboard)
No need to donwload or install any drivers.
Vista has everything built in.
Only thing is it needs atleast 128 Mb of Video Memory, but for older motherboards like Inter 845 by default the Video Memory is configured to 64 Mb which is resulting in your problem.
So what you have to do is...
SOLUTION:
Restart your computer > Press DEL Key
and
Go to BIOS Settings > Advanced > Video Configuration
1. Change "AGP Aperture Size" from 64 Mb to "128 Mb or Higher"
2. Leave "Primary Video Adapter" as "Integrated"
3. Change "Frame Buffer Size" from 1 Mb to "8 Mb"
and then press F10(i.e., Save changes and continue).
Sometimes, for the first time you may see screen not aligned properly, in that case just restart once more and Vista will automatically adjust the alignment for you.
Also, you can change the resolution to your desired one manually as follows...
1. Click "Start Button"
2. Right click on "Computer"
3. Select "Properties" option from the context menu.
4. Scroll down and find "Disply Settings" option and click it.
5. Adjust Resolution Size and Mode.
NOW, ENJOY USING VISTA.....
Posted on Dec 07, 2009
Hello ! I have motherboard MS6378 (Microstar) and SATA disk 500 GB. I want to install win xp on it. But I can not. It seems that I need some SATA drivers but can not find it. Do anybody has any...
Ludvik,
The motherboard model that you listed doesn't have support for SATA drives. Are you sure that's the correct model? If so, that's your problem, unless you are using a third-party SATA PCI controller. Then I would need to know the model of that to find the driver you are requesting.
I know this doesn't answer your question, but if it helps please rate positively.
Jul 01, 2011 | MSI MS-6378 Motherboard
So i just installed a MSI 785GM-e65 and started up my comp and it wont boot windows now any ideas ? yes its detecting my harddrive and ram, right now im running a repair on windows and if that doesnt work...
when you change motherboards, you almost always have to reinstall windows. windows installs are not meant to be swapped among motherboards, and it is in fact against the windows EULA.
Dec 25, 2009 | MSI 785GM-E65 AM3 AMD 785G HDMI Micro ATX...
Hi dont have the board drivers for this can anyone help please Cant get any graphics on this running windows xp with 512 mb ram and 40gb hdd Eddie
Please go to the manufacturer's web address below and download the video driver for your motherboard.
MS-6378 video driver
This should be free of cost.
Thanks,
Lolita
Sep 25, 2009 | MSI MS-6378 Motherboard
Front panel connector
please give more details on the prob or see the manual
downloadable at:
http://www.motherboards.org/mobot/manuals/MSI/MS-6378/
or:http://www.msi.com.tw/program/support/manual/mnu/spt_mnu_detail.php?UID=22&kind=1
the .exe file turns into a pdf / make sure you have adobe reader instaled to read it!
it should tell
you where to put in the plugs...
good luck
Aug 08, 2009 | MSI MS-6378 Motherboard
Using a 1point 5G CPU.
From Spikeg
Went to a swap meet & obtained a 1.3 G CPU as the 1.5 G cpu I had was A INTEL
Unit with my motherboard a Socket A for Athlon {AMD} type units.
This solved my problem.
Thanks for all the help.
Sep 28, 2008 | MSI Computers & Internet
Intel D101GGC Motherboard Logo
580 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
