Question about Sony KP-53HS10 TV
53HS10 The text is blurry. I tried focus button and did not help. All the color seem alright. Do I need to adjust lenses? if so how I can I adjust?
  • 1,284 Answers
You probably just have dust build up on the lenses. You can remove the lower back (with the set unplugged) and once you have that done you now have access to clean the lenses using a soft cloth and wipe them down. Don't adjust the lenses as you will spend more time correcting a problem that you create by doing so. Good luck..
Posted on Dec 06, 2007
Problem with viewfinder - focus?! I've been using my Nikon d3000 for over a year now. Few days ago I tried to take a photo but when looking through the viewfinder, the photo wasn't focused. It was...
There's a diopter control near the viewfinder to adjust the viewfinder to your eye. Try adjusting that while peering into the viewfinder and try to get the focus brackets and the data at the bottom of the viewfinder into focus.
Jun 20, 2011 | Nikon D3000 Digital Camera
Does it take some type of gel under the lights, the colors are a little blurry
i also have this tv. i removed backcleaned mirrior, back of screen and lenses VERY GOOD. Then turned on tv go to convergence, sepaerate cross hairs then adjust focus on lenses. Then lenses rotate maybe about a 1/3 turn total by hand. Grab ring that houses lenses and turn until cross hairs are as clear as possible. This can be done with out help by watching inside of screen. red and green are adjustable, the blue is adjustablealso but i couldnt find blue cross hairs, maybe by covering red and green lenses the blue will show on screen. anyway when done and cross hairs are clear,lenses, mirror and screen are clean, you can adjust covergence and get a very clear screencleaning will also brighten pic. Pete
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
Projection tv is Blurry and offset
You have a focus and screen control box it has 3 controls on top 3on bottom these are the controls for Red-Green-Blue screen drives and for focus to each tube. IT should have Focus /Screen on it.
Dec 19, 2008 | Philips 50P8341 50" Rear Projection...
Blurry photos
good day,
have you tried adjusting the focusing of your lense? what i mean with this is by manually rotating the lense of your camera.
try readjusting your lense until you achieve your desired focus.
i hope this helps
Sep 20, 2008 | Nikon D50 Digital Camera
Blurry screen KP61hs10
Yes, Convergence settings should be tried first before any color adjustment or any fluid changes are done. Remember that there are 3 colors to notice. Red, Green, Blue. The Green is the only one that you can not move with an adjustment The Red and Blue is ligned up on green. Some cases it does matter how linear the Green color is across the board, just how close you get the blue and red on top of green is what matters.
Mar 25, 2008 | Sony KP-61HS10 61" Rear Projection...
Needs convergence circuit repair...........
Requires replacement of soldered-in parts..............T.
Please rate this solution.......................
Sep 24, 2007 | Sony KP-53HS10 TV
No....needs convergence circuit repair.Usually several hundred
dollars to change out convergence IC's..................T.
Sony TV with blurry picture
blurry picture is mainly due to focusing voltage is not proper. solution 1 check & adjust focus control on flyback. 2 check crt base for loose. 3 wire going to focus control on crt base got disconnected due to foreign materials deposit on it. 4 if tv is old possibility of crt getting weak.
Sep 20, 2007 | Akai CF2791 27" TV
New PCB SUB - But blurry and color off.
have you tried to also adjust the lenses to fine tune the focus .
Aug 28, 2007 | Samsung HCL4715W 47" Rear Projection...
Sony KP-53HS10 TV Logo
137 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
