Question about Kirby Generation 3 Bagged Upright Vacuum
How to put the belt on ?
I took the front off to use the hoses, and can not get my belt back on ? help ?
    An expert whose answer gotĀ voted for 100 times.
  • 112 Answers
First things first...take the powerhead off of the front of the kirby. If you look at where the powerhead connects to the front of the kirby and you'll see a large hook...turn the hook using the crank on the front of the powerhead so that the belt is pulled up and away from the brushes. (OFF position) The hook stretches the belt so that it can fit over the fan driveshaft (its the finger looking thing that sticks out of the front of the kirby when the powerhead is removed.)
Next, place the two "feet" of the powerhead onto the "perch" located on the front of the kirby (under the driveshaft opening)....lock it on by turning the silver lever on the top of the kirby (the one under the hood/light)
Now spin the knob on the front of the kirby from off to on. This releases the belt from that hook in the powerhead so it can rest on the driveshaft. Off means the belt is off of the drive shaft and the brushes won't spin. On means the belt is on the driveshaft and the brushes will be spinning. But remember, the belt has to be stretched open on that hook inside the power head BEFORE the powerhead is placed on the front of the kirby. Otherwise the belt won't be connected to the spinning driveshaft, and the brushes won't spin
Posted on Jan 04, 2008
I have a kirby sentria. vacuumed up my son's headphones and immediately shut if off. took brush off, unwound headphones, put it back together. when i turned it back on, the belt snapped. so i went to...
Take the front off the vacuum and check inside both the front portion and the canister for additonal clogs. Sometimes something will get caught in the impellor, causing the motor to overheat. Since there's little suction and the smell, I'd guess this is what happened.
Jan 30, 2011 | Kirby Generation 3 Bagged Upright Vacuum
How do I get this darn belt back on my Kirby?
We've actually shot a very helpful video repair on how to change the belt on your Kirby. Also, at the end of the video it shows you how to put the head of the vacuum back on properly. This video also gives you instructions on how to do routine maintenance on the roller brush to prolong the life of the belt. If you fast forward the video to the end though, you'll get an easy to follow answer on how to put the head of your Kirby back on.
Here's the video:
I hope this video was helpful to you. If this helped you fix your Kirby, please be sure to rate the repair as helpful by clicking the thumbs up icon on the top right hand corner.
Thank you!
Chris J.
Apr 05, 2010 | Kirby G4 Bagged Upright Vacuum
I can't turn the belt off of my Kirby vacuum. I had the front off of it earlier to attach the hose, but now when I put the front back on, I can't get the belt to turn off. The lever twists about 3/4 of the...
turn the front part to the green so it is level and then twist the front to the red make sure the belt catch the hook as you twist it then if the belt is hooked just put it back on the vac like normal and lock it in place then twist it back to the green go postion
Aug 12, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Need help putting my bissell carpet shampooer back together
the side that is dragging needs the roller that the brushes are on ,to be precisly pushed back up in it's place,it will take a few minutes and it will not slide back in place easily just use a little force as for the hose diagram,,enter model number and go to hoses.
May 31, 2009 | Bissell 7901-1 ProHeat Scotchgard Upright...
Belt not locking
With the nozzle off of the vac., turn the big knob on the front until it locks. (will only turn one direction) Put the nozzle back on the vac, lock it down, turn the knob again and the belt will be on the spindle and you should be set to go. I hope tho that you put on a new belt, they stretch after a short time and will start slipping under load.
Jun 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
My belt broke on my kirby upright, I took the roller off and put the new belt on, but I cant get the hook to hook on the belt.
On the front of the nozzle is a big knob that you turn to load the belt. Take the nozzle of of the vac, turn the knob to catch the belt, keep turning it until it stops. You will know if the it caught the belt, it will be hard to turn. Put the nozzle back on, lock, then turn the knob in the other direction releasing the belt unto the pulley.
May 01, 2008 | Vacuums
Kirby sofa cleaner
Hi, my name is Jon and I have an Ultimate G Kirby and have sold Kirby and the solution to this problem it is very simple. All you have to do is first disengage the belt by lifting the hood and twisting the plastic thing that says Kirby. Twist it all the way till the red arrows meet up then you will know that the belt is disengaged. Next you're going to disconnect the front by pushing the small metal lever/lock under the hood to the right and the front end should come right off. REMEMBER put the vacuum on the highest setting so this will be much easier to do. Then what you want to do is connect to hose and you will do so by connecting the hose in the same manner in which you would connect the front. There is a perch for the hose or any of the other attachments to rest their "feet" on as you will see the end of the hose is contoured to fit the Kirby in the same way the front end does. Lock the hose in place with the metal lever/lock by putting it over to the left. REMEMBER to disconnect the belt when you take off the front end and ALSO to reengage it when you put the front back on. I hope to have solved your problem, and I'll talk to you later!
Nov 18, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
454 people viewed this question
Top Kirby Vacuums Experts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
