Question about Fisher and Paykel GWL11 Top Load Washer
Fisheer & paykel smart drive LO8
I washed my car mats (overloaded?). It kept stopping. I took them out and did not do the spin cycle. since then did 3 loads. 4th load, stopped the machine to answer a phone call @ the spin cycle; could not re-start the machine do the final spin. unplugged, re-powered, unit would not power-on at all. Is there a fuse or circuit-breaker? How do I open the panel to check? is there a re-set switch?
    Problem Solver:
  • 11 Answers
This one sounds like a simple one. Try the following in this order:
  1. Close the lid and start.
  2. Advance the timer. (Rotate the dial forward a bit)
If none of these work, let me know and I will give you some other things to check, however I bet this will get you going.
Good Luck!
Posted on Dec 06, 2007
Smart drive 085
It won't spin until all the water is drained out. The drain pump may be blocked or faulty. Fix the drain pump fault first then deal with the filling issue. They will not be related.
Jun 21, 2017 | Fisher and Paykel (IWL12)
Continues to go out of balance
The stainless steel bowl has lost its ballast water & goes out of balance,Replace faulty bowl.
Oct 03, 2012 | Fisher Paykel Fisher & Paykel AquaSmart...
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel GW709 fill valve problem
the rods have nothing to do with the water level switch. I say check ur water switch with a meter. you may have defective coils, also check the water pressure switch
Mar 21, 2017 | Fisher Washing Machines
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Fisher Paykel GWL10US Washer won't spin
Look at my issue on "eco smart won't drain, smells hot". You could have same issue and your motor just hasn't burned up yet.
Oct 16, 2008 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel eco smart is GWL11 not GWL15
Press "end of cycle" for 5 seconds or more to clear the screen. Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 02, 2007 | Fisher Paykel EcoSmart GWL15
Water wont empty
We had the same problem with ours. I took out the steel tub and found there was a lot of lint blocking the pump (at the bottom of the plastic tub). There is a screw holding the pump cover. Once you remove this you can check it properly for blockages.
May 25, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
79 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
