Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Device menu does not appear
When I press device menu, it does not appear and after 30 seconds or so, it resets with blink green light and no picture.
If I go to the device menu and select audio/video setup, the same thing happens.
Any ideas>
  • 1 more comment
  • sstans Dec 12, 2007
    I'm having the same problem. Any solutions yet?
  • jimpruden Dec 18, 2007
    Here's what fixed it for me. Too bad it is not documented!
    Initialize settings by pressing "menu, 2, 4, 7, 0 enter".
    Select Initialize settings fom menu.
    After settings have been initialized press the system reset button on the front
    Once the LED stops blinking, reprogram the netcommand and tuner settings.
  • Anonymous Mar 11, 2008
    I had the same problem.
    Thanks to jimpruden's advice. Everything is back to normal now.
    SK
    President:
  • 4,402 Answers
Hold the MENU and DEVICE buttons when turning on the TV and get error code
Posted on Dec 18, 2007
Nexus 7 won't turn on
Pop the back off, unplug the battery for about 30 seconds, plug the battery back in, put the back cover back on. You will find it will start no problem.
May 19, 2014 | Google Nexus 7
Samsung
Hi Anubhav,
Please try the ff:
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
May 06, 2014 | Cell Phones
Reset phone password
Hi Oliver,
May 04, 2014 | Samsung Star GT-S5233 Cell Phone
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
The green power light would come on, with no picture, for 3-5 seconds and then the power and the green light would turn off. I have reset the TV by unplugging for a little while but that has not helped.
When power light goes out on front of set press both the menu and input (device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
SD TECH
Sep 30, 2010 | Mitsubishi WS-55311 55" Rear Projection...
needs to be reinitialized press menu 8970 to reset
Oct 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi big screen tv model #WS-65857 and the picture went out as though the tv was turned off and when you turn it back the green light comes one for about 5 seconds the goes of there is no...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if your set does not have a device button press Menu and Input together for 5 seconds and release. there will be a pause between blinks---2 blinks, a pause and two more blinks etc.
If you need help: etower.766@netzero.net
I do this here for free so if this has helped you give me a vote here.
Aug 18, 2009 | Televison & Video
2Wire Gateway seems to be stuck in a reset loop
there is most likely a burnout on the system board. you will most likely have to buy another one
Aug 11, 2009 | 2wire (1000-000057-000) Modem
Mitsubishi WS-55909 dm board repair
I have the same TV and the error light code on my set is 22
May 31, 2009 | Mitsubishi WS-55809 55" Rear Projection...
The DM is fine if the led isnt blinking. Your set is going into protective shutdown. Try pressing the menu and the device/input buttons on the set both in together for 5 seconds to see if the set will blink a series of blinks pause then blink another series of blinks. Such as 2 blinks pause then 2 blinks, Then let me know what the blinks were and I will assist you with whats wrong
May 28, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
