Question about Panasonic TH-42PX60U Television
No picture on hdmi2
I have a panasonic th-42px60u set with directv connected to hdmi1 and a dvd player connected to hdmi2. Everything was working just fine until i press a wrong button on the remote (don't remember which one) no i get no picture from the hdmi2 input. The input from hdmi1 works just fine. Any idea as to what I did and how to fix it?
  • kjhussey Jan 07, 2009
    I cannot get my TV to see HDMI2.  My Direct TV box and my Roku-Netflix player work fine in HDMI1.  When either is plugged into HDMI2 I get no signal.
    I've try to switch inputs to HDMI2 and it just gets "skipped-over" on the list.  If I input the number directly it doesn't do anything.  On the input list the only inputs I can "see" are those that show up in blue.  The others, including HDMI2 are "grayed-out."  Any suggestions?
    Thanks,
    kevin
    President:
  • 1,284 Answers
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Posted on Dec 06, 2007
Can't keep the HDMI2 setting for watching streaming channels - TV automatically reverts to HDMI1
That's because you have connected another device in HDMI1, the TV detects it as power on, and then change HDMI2 to HDMI1.
Try to power off the device in hdmi1, or you can even try to change HDMI2 to HDMI1 port ;)
Jan 15, 2018 | Televison & Video
Panasonic plazma tv th-42pd50u. Red light automatically turns on when connected to power and stays on. No clicks, No blinks and No picture. Is this a faulty power supply board?
possible reasons, its in standby, hold in the proper ON button on the tv for up to 20 seconds gently. or try disconnect power(pull plug out) wait 10 seconds, plug back in and turn on using the actual button(holding for up to 20 seconds) NOT THE REMOTE if that does not work, make sure your INPUT is CORRECTLY selected eg you are viewing HDMI1 and NOT HDMI2 for example. there may be different procedures for flashing lights
Dec 12, 2017 | Panasonic Televison & Video
No inputs
Feed the TV an external signal. That is, connect a DVD player to it, select the appropriate input selection to AV, and see whether there is picture and sound or not. If yes, check and replace the tuner. If not, check and replace the video IF stage.
Jun 08, 2012 | Panasonic TH-42PX60U Television
I am having problem setting up my hdmi connection with my panasonic viera model TH-L32C10X2. i cant get it connected to my sony ps3. all cable connections are connected. set the tv to either hdmi1 or...
I do not own a PS/3, but I will try to help just in case you dont get another expert at this late hour....
It sounds like you need to save the changes on your PS/3. It is timing out and going back to default because the changes were not saved.
Hope I helped!
VA
Feb 11, 2011 | Televison & Video
Panasonic DMR-EZ48V. Video is in black and white. No Color. This is brand new.
Go to Menu/Settings and highlight your source --ie. Component, HDMI1, HDMI2 or whatever the source is. Black and White becomes color.
Feb 12, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Hdmi connection blueray to sony tv bravia.sony bd. pluged to hdmi2 unable to get picture. hdmi1 being utilize by cablebox. should i change hdmi setting on tv, how is that done.
there should be a imput button on original remote. just push it then scroll to hdmi2, then enter should give you picture if not they will be an imput option under your menu options
Feb 09, 2010 | Sony Blu-ray/dvd player BDP-S1
No picture when tv powered on
When power on and input set to hdmi1, there is no image appears
Dec 31, 2009 | Toshiba 32AV502R LCD TV
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Can't get the Samsung HT-z310 Home Theater to stay on AUX2
you need a fibre optical cable for this, simply you connect that from your dvd to tv and then set the input on the dvd to digi in. i have exactly same home cinema system.
Nov 27, 2008 | Samsung HT-Z310T Theater System
Panasonic TH-42PX60U Television Logo
717 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
