Home | Mitsubishi | VS-50707 50 in. Rear Projection Television | I HAVE A MITSU VS5...
Mitsubishi VS-50707 50 in. Rear Projection Television
Problem for Mitsubishi VS-50707 50 in. Rear Projection Television
I HAVE A MITSU VS50707 PROJECTION. THE PICTURE
By IMABLEBK525 on Aug 30, 2009
I HAVE A MITSU VS50707 PROJECTION. THE PICTURE BOWES TO THE CENTER OF THE SCREEN AND PICTURE HAS THREE DIFFERENT COLOR HALLOWS. IS THIS A REPAIR THAT CAN BE DONE AT HOME? WHERE CAN I PURCHASE THE PARTS?
Solution #1
posted on Aug 30, 2009
Somewhat Helpful)
olekam
Rank: Master
Rating: 75%, 14 votes
Here is some great PRINTER solution by Some FIXYA EXPERT.
Get any kinds of PRINTER solution from bellow.
» Lexmark Printer Solution
» Epson Printer Solution
» Brother Printer Solution
» Dell Printer Solution
» Canon Printer Solution
» HP Printer Solution
» Kodak Printer Solution
7
Was this helpful?
Yes
No
Solution #2
Not Rated)
flents
Rank: Guru
Rating: 89%, 48 votes
This is not a diy repair, unless you have a service manual, can follow a schematic or have circuit repair skills. The main cause is bad convergence ICs (large black ICs mounted to large heatsinks). The ICs go bad and usually take out micro fuses/fusible resistors when they short out. Another problem is they can take out the voltage regulators that feed the ICs. If you don't know where the fuses or the regulators are ( or how to test them) you can cause more damage then good, and turn a inexpensive repair into a very expensive one.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi VS-50707 50 in.
Questions and Unsolved Problems for Mitsubishi VS-50707 50 in.
Do you recommend Mitsubishi VS-50707 50 in. Rear Projection Television?
Answer
Answer
Images have a "solar wind " effect to the right side
Answer
when tv is turned on it has a black screen and distorted volume. After warming up (10-30 minutes) it... (More)
Answer
I have a Mitsubishi VS-50707 rear projection TV. When it is first turned on I get various horizonal... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi VS-50707 50 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
