Question about HP Pavilion dv4000 Notebook
Hp lap top will not reboot, restart nor retore
My pavillian will not restart nor reboot. an error shows problems when shutting down, now I can't even put it in the safe mode
  • Anonymous Mar 08, 2008
    We just had the same issue after a power outtage. Now we can not get a restart, reboot, restore or safe mode. Any suggestions
  • 520 Answers
If bios starts you can install new copy os.
you may not be able to restart you may not be able to get into safe mode but if you can get to the point where u have an option then u can reinstall os.
need more info let me know
Posted on Mar 10, 2008
  • 383 Answers
No power or computer does not turn on. Issue: No power or computer does not turn on.
Cause: No power from the computer can be caused by any of the below possibilities.
  1. Connections not connected properly.
  2. Third-party hardware.
  3. Bad power cable.
  4. Incorrect power supply.
  5. Bad battery.
  6. Bad power supply, power button, and/or power board or inverter.
Solution: Connections not connected properly Verify that the power connection is connected properly to the wall and the back of the computer. If the connections appear to be connected properly, attempt to disconnect and reconnection both ends of the cable. If you have a power strip (surge protector) or switch used to turn everything on at once, temporarily disconnect the computer from that switch and connect that cable directly to the wall. This will help verify that the strip or switch is not bad. Verify that the outlet works by connecting a different component to that switch.
Third-party hardware If additional hardware has been recently added to the computer it is recommend that you temporarily disconnect that device or devices from the computer to verify they are not preventing your computer from turning on. Note: If the computer was working fine before you added the new hardware, removing the third-party hardware did not resolve the issue, and the computer is not beeping but is turning on, please see our POST troubleshooting document CH000607.
Bad Power cable Verify that the cable supplying your computer is not bad or damaged by using another power cable. If you have a standard CRT monitor, this cable can be used in place of the computer power cable. If you have a portable computer or laptop, when the cables are plugged into the laptop you should see a power light or battery charge light. If this light is seen, this is a good indication that the power cable is good.
Incorrect power supply If you are building your own computer or if the computer has never turned on since you purchased it, it is possible you are using a power supply that does not supply enough power and/or the incorrect type of power supply. Verify your power supply meets the requirements of your motherboard and processor.
Bad battery If your computer is a laptop or portable computer that utilizes a battery for mobility it is possible that the battery may be causing your issue.
  • If your computer powers on when the cable is connected to the portable computer but not when it is disconnected, we recommend you purchase a new battery.
  • If your computer does not power on when the battery is connected and when the power cable / charger cable is connected, try removing the battery and seeing if the computer can power on with only the power cable connected. If no power is still received, skip to the final section.
Bad Power Supply, power button, and/or power board or inverter If, after following the above sections, your computer still receives no power, it is likely that a hardware component in the computer has failed. It is most likely that the power supply has failed. If you do not plan on replacing the power supply yourself or if you have a portable computer, we recommend having the computer serviced by your computer manufacturer or a local computer repair shop. If you have a desktop computer and plan on trying to repair the computer yourself, we recommend you replace the components in your computer in the below order.
  1. First open the computer and verify the power connections. You may also wish to consider disconnecting the main power cable and reconnecting the power cable to make sure it has not become loose. Also verify the power button cable is correctly connected to the Motherboard.
  2. Replace the power supply with a new power supply.
  3. Replace the motherboard.
Index
question.hp lap top will not reboot, restart nor retore - dot.gifass= dot.gif
hp lap top will not reboot, restart nor retore - dot.gifesolved
Posted on Dec 06, 2007
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
I cannot restore my acer aspire 3630 lap top
hi you need to press the FN and F8,9 or 10 repetedly to restore it to default settings.
May 04, 2009 | Computers & Internet
Shutting Down my LAP TOP
Check in your bios for the power settings - your laptop is likely set to wake on lan or some other hardware. Also, check in the windows power management for the settings in there.
Feb 12, 2009 | HP Compaq Presario v3000z Notebook
Need 2 reboot
If you don't mean retore and just reboot. just click restart when you shut dow
Jan 04, 2009 | Computers & Internet
SL300-129 Toshiba
Remove the battery from the laptop. Wait a minute then reinstall. It should reset, if not then hold down the start button for 10 seconds and it should reboot, if it reboots sooner remove your finger from the botton. That is the quick fix to a simple problem, hopefully it will work for you otherwise it will require moe work, good luck, Gym
Dec 26, 2008 | Toshiba Satellite A135-S2276 Notebook
My computer won't shut down it just keeps restarting
The most common shut down problem is that the system will reboot rather than shutting down. In most cases, the reboot is triggered because Windows XP is designed to reboot after a critical failure. To stop windows from rebooting in case of a failure, you need to take the following steps:
Right click on My Computer, Select Properties, Click on advance tab, Click on Settings under Startup and Recovery, Uncheck the option Automatically Restart under System failure, Click Ok twice and try to shutdown the pc. If it shows any error code then let me know
Nov 24, 2008 | Toshiba Satellite M65-S809 Notebook
Network adpter malfunction
try this
Uninstall any drivers for card shut down remove card restart then shut down reinsert card reboot on reboot it should come up with message new ??? found and go into finding drivers follow instructions to install them from where the driver folder is
when installed reboot normally this will fix problem
Jul 27, 2008 | ASUS Computers & Internet
HP DV 5000
Are you sure you didn't make an error while recovering. The c-a-del doesn't always work with reboot.
Jul 11, 2008 | HP Pavilion dv4000 Notebook
Sounds like a power supply issue.. Check the mother board for a light when the power is on (some mobos will not have this light). If there is a light, but it does not go on when the power is connected, replace your power supply.
Also, please post the model number of your computer.
Mar 26, 2008 | Computers & Internet
Deleting-S error HELP
Try to stop and restart the print spooler (right click on My Computer and then select Manage. At the bottom of the Computer Management window, expand Services and Applications. Click on Services, and on the right side of the window look for Print Spooler. Right click on it and select restart). Even if this procedure does not fix your OADP file problem, consider it in the future and avoid restarting the computer every time you want to get rid of spooling printing documents.
Jul 25, 2007 | HP DeskJet 1280 InkJet Printer
HP Pavilion dv4000 Notebook Logo
313 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
