Question about Samsung TV Remote Control
Samsung hitron how to control vertical and horizontal adjustment???? pls. give the code # of the remote control. thanks>......
  • 3 more comments
  • Anonymous Dec 08, 2007
    i have locked my Samsung hitron tv and its all functions and setup is not working. What should i do?
  • Pathania Dec 12, 2007
    screen is horizontally sqeezed.
  • TAPOLA Apr 03, 2008
  • aaditendra03 Apr 13, 2009
    I HAVE SAMSUNG HITRON ,MY SCREEN IS SCATERED HORIZONTALY
  • Anonymous Mar 22, 2014
    How to adjust the color on the screen
The tv is an old electronic device that i dont fancy as the best.
Posted on Oct 11, 2011
I have an old solo tv - visa electronic remote that i would like to set up for my Hitron tv (samsung), but i lost the my book to help me set it.
Posted on Apr 03, 2008
How can I go to av mode without remote control in samsung hitron tv
Yes, you change your channel to '00' or go up to '101' and then press up button on tv then it will automatically comes to '00'
Nov 08, 2012 | Samsung Televison & Video
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    I have samsung Hitron TV. My remote is not working. I want to buy new Remote. I want code for Remote control
    hiThere is nothing special as a code for it. in 6your remote itself you ll see a model code in it. just say that code to the local electronics store you ll get a remote for it. hope it helps
    Nov 07, 2010 | Samsung Televison & Video
    How do I get the code for my samsung TV remote control?
    Please check the bellow link related to your issue:-
    http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?PG_ID=-1&AT_ID=5716&PROD_SUB_ID=0&PROD_ID=41
    However these are the Remote Control Codes for different Samsung Models:
    With the TV in standby, press the
    {DISPLAY} {P.STD} {MUTE} {POWER} on the remote.
    • With the TV in standby, press the
      {P.STD} {HELP} {SLEEP} {POWER} buttons on the remote.
      or
      {P.STD} {MENU} {SLEEP} {POWER} buttons on the remote.
      {SLEEP} {P.STD} {MUTE} {POWER} on the remote.
    To exit, simply Power Off the TV.
    Well i tried these codes on my SAMSUNG HITRON 21" CRT TV but did not worked. however at last i tried :
    {DISPLAY}{MENU}{MUTE}{POWER}
    Please get back to us if you have any further query or else accept the solution.
    Thanks for contacting fixya.com
    Nov 01, 2010 | Samsung TV Remote Control
    Hi. My AKAI CT 2985 is out of sync in horizontal & Vertical .Now plese tell me how can solve this problem?
    sir pls help me. i need akai ct2985 remote control model no. i lost my remote in transit and without it i'm not able to use the tv. my mail id : jayaram_b4u@yahoo.co.in pls help. thanks & regard's. jayaram
    Nov 01, 2010 | Akai Televison & Video
    One horizontal line center on the screen
    The vertical deflection circuit has failed, or has been shut down by a service code entered from the remote control*. Usually you can get out of service mode by turning the set off and on again.
    *Normally, you have to enter a special combination of front panel and remote control codes to get into service mode, then enter another code on the remote control to get the horizontal line. The horizontal line is used for adjusting the screen controls for each color so you get proper color in the dark areas of the picture.
    Oct 27, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    Samsung hitron Remote
    If Samsung 00026B remote is compatible with 0026b remote, any one tell me
    Feb 24, 2009 | Samsung TV Remote Control
    Samsung TV Remote Control Logo
    1,221 people viewed this question
    Jerry Greenberg
    Jerry Greenberg
