Question about LG Flatron F700B 17" CRT Monitor
Monitor screen appears yellowish
Hi .. my monitor screen apears yellowish every time i turn on my pc...please help with a solution
  • hitalj Dec 06, 2007
    but is there some other way out....?///
  • 749 Answers
Resolder components on the CRT neck circuit! the color ICs or Transistor connections migth have loosen up!
Posted on Dec 06, 2007
Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Yellowish screen from boot up.
Once you press the menu button which is on the monitor if you get menu button then try giving reset or restore factory settings in it.
This solves your problem if your RGB colour settings is not configured correctly.
If your problem still persists then there will be problem in the monitor .
As you have mentioned (YOU HAD IT FOR A WHILE) in your problem if you have manufacture warranty then make use of it.
There is no problem with your CPU,motherboard and any other hardware part except the monitor.
-Dileep Bradley
Rate my solution
Mar 18, 2009 | LG Flatron F700B 17" CRT Monitor
When turn on the gateway screen apear, but the monitor turn off or black and not apear nothing my computer is gateway profile 4 all in one
Your power settings may need to be changed, it appears to be going into sleep mode or power saving mode.
If you are using Vista, Click Start> Control Panel > Power Options > "choose when to turn off display" (in the left hand pane) and check that it says at least 10 minutes. Click apply and then ok.
Alternatively, right click on your desktop, select "personalise" and click on screen saver - then select "change power settings" to bring you to the same thing.
If you have xp, right click on your desktop and select "properties" then "screensaver| > "Power" and change it to turn off the monitor after 10 minutes. Click apply then ok.
If your monitor is going to sleep, either press a key or wiggle the mouse to wake it up.
Mar 13, 2009 | Gateway Profile 4 All In One (MPN...
Date not appear on screen
Your internal back-up battery is empty, please replace the internal battery and date will apear.
Feb 08, 2009 | Panasonic Lumix DMC-FX3 Digital Camera
My screen keeps apearing "Contrast 100"
Check all cords and cables from PC to monitor. Also make sure the graphics card is properly seated into its slot in the motherboard. That is how I would start. If this doesn't help it might be the graphics card or monitor. Need more info.
Dec 29, 2008 | Dell Dimension 2400 PC Desktop
My Benq monitor model V772 turn yellowish occasionally
To solve the problem on my monitor i did a thorough inspection on the pcb which is fixed on the tube and i solder components which looked suspicious for dry joints.
Dec 27, 2008 | BenQ Value V772 17" CRT Monitor
My monitor displays yellowish color instead of original color
yes please take the power on self test means disconnect signal cable and monitor will give
display without cpu if display appears then monitor ok fault is in cpu if not then fault is in monitor move signal cable and look display changes or not if changes then cable faulty replace it
Nov 11, 2008 | SAMTRON 55V 15" CRT Monitor
My friends acer laptop has a blank/black screen on start up, its still running but nothing appears on the screen. can anybody help?
can you hook it to an external monitor if so then boot in with the external monitor ans see if the screen apears with operating system then look for the monitor icon on the laptop if found then press the fn+the monitor key together and see if this swaps back to laptop lcd but if you have not got the option of uotput to a second monitor then get it repaired
Aug 25, 2008 | Acer Computers & Internet
Screen Gone "Yellowish" Colour, Appears that Blue colour is not working
your problem is in blue color cathode circuit. as you say that it becomes ok tha5t means 1 cable wire is loose from computer to monitor. 2 crt base loose. 3 loose contact in blue video ckt. 4 signal processor cable to crt board connector loose.(blue wire)
Oct 14, 2006 | LG Flatron F700B 17" CRT Monitor
LG Flatron F700B 17" CRT Monitor Logo
145 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
