Question about Garmin StreetPilot C330 GPS Receiver
All info in my GPS seems to have vanished...
When I go to put in an address, it says "Can't Unlock Maps". What do I do? None of my recently visited addresses are in there...it seems like it erased it's entire memory. HELP!
There is an issue with the pre-loaded maps that requires service. To arrange for factory service, submit a technical support request to Garmin using our online form at:
http://www.garmin.com/contactUs/techSupport.jsp
Be sure to complete all fields and write 'Can't Unlock Maps' in the question field. Garmin Product Support will create an RMA number and send it along with shipping instructions for warranty repair. Return Authorizations can also be received over the phone. Please click here for phone contact information.
solution = solution1description.innerHTML;
Posted on Dec 19, 2007
Ok so i have pressed the middle of the screen the message no detailed maps that support routing has gone have gone into address it now says no data available and still no maps
The original message of "No detailed maps to support routing" is typically caused by a missing or corrupted map file. It can also be caused by not having the proper map unlock key installed on the unit.
If that problem has been resolved and you can't obtain an address when setting a route, make sure that the map is turned on.
Go to settings, select the map icon and then the map info button. Make sure there is a check mark in the square next to the text that lists the map that you have installed on the unit.
If the map info button is grayed out, then you still have a map issue.
If the square does not have a check mark in it, press the square to place a check mark in the square. This will activate the map.
With this unit, you can put several maps on it and you can select which map will be active or inactive with the check mark.
More map issues are explained here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Jun 08, 2015 | Garmin nuvi 200W GPS Receiver
My Garmin doesn't find any address
check the map info screen. usually its settings, map, map info or tools setings map info or settings, my maps. if there is nothing there then get Garmin Express and get your maps back. otherwise you installed a region other than where you live.
Aug 05, 2014 | Garmin nuvi GPS
I recently downloaded updated maps for Europe and North America. Now every time I try to enter and address it asks me for the state/province although British English is selected as the locale.
Go To Tools..... Settings..... Map.....on bottom of screen you will see Map Info ....press it now make sure you want to use the map that has a checkmark in it..... if you have 2 maps there youcan only use 1 at a time
Nov 15, 2010 | Garmin Nuvi 370 Car GPS Receiver
My Garmin Nuvi 205w with USA maps wouldn't let me enter the State of California when I recently visited there. Every time I got as far as entering Ca in the state/province section, it would instantly go to...
If you are using the USA maps make sure its the City Navigator North American NT
Seem to me it is still working with your map from the Carribean, this would have to be changed in the map area located on you nuvi, it will only give you one map of that country at a time.
When you visit you must change it here..... Tools.... Settings...Maps...on bottom of screen press Map Info
when in the USA always have City Navigator North American NT checked and uncheck your area
Nov 01, 2010 | Garmin nuvi 205W GPS Receiver
Unable to unlock new maps
Where did you download the Australian maps from? If from Garmin, contact Garmin for the unlock code. Maps have to be unlocked to a specific unit.
If you downloaded the maps from the internet, you will still need to contact Garmin for an unlock code.
Jun 14, 2009 | Garmin StreetPilot c340 GPS Receiver
My Garmin nuvi says ''maps unavailable''
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The "No Detailed Maps Found That Support Routing" message may appear for the following reasons:
The GPS device is missing it's unlock code
The maps on the GPS device have been disabled
To determine the cause of the message, touch the screen until the message "No Detailed Maps Found That Support Routing" disappears.
  • If you see a "Can't Unlock Maps" message following this error, remove any microSD / SD cards in the device and follow the instructions below for Retrieving your unlock codes followed by the instructions for Creating an unlock file
  • If you do not get the Can't Unlock Maps message then skip to the instructions for Enabling maps on the GPS device
Retrieving your unlock codes:
  1. Log into your myGarmin account
  2. Select myMaps
  3. Select Manage Maps
  4. Select the device from the drop down menu
  5. The unlock code is located under the "Maps installed on this device" section
    /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Enabling maps on the GPS device:
    1. Touch the wrench icon on the Where to/View map screen
    2. Touch Settings
    3. Touch Map
    4. Touch Map Info
    5. Select the checkbox next to the maps to be enabled on the device
Mar 21, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 255, no maps intstalled, shows unlocked in detailed info
This error is caused by a corrupt or missing map unlock code. Please email me @ sharcnet-usa@sharc.net and I will talk you through on how to fix the problem.
- Jim
SHARCNET-USA
Mar 20, 2009 | Garmin nuvi 200W GPS Receiver
Adding Multiple Maps On Garmin GPS'
If you install the cards
go to settings--maps--map info
tick the box there
you will need your unit I.D.
tools-settings--system--about.
and serial number off the sticker to unlock them
For the disc/online method
http://www.fixya.com/support/t1891815-garmin_seems_lost_all_its_maps
Hope this helps
Regards
Richard.
Nov 20, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 350 Unlock
Did you buy the unlock key from garmin? You need this key to be able to use the maps on a specific gps (serial number) so when you update maps, you type in this unlock key and the maps are unlocked on the gps. There is a page about this on the garmin website
Feb 24, 2008 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
61 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
