Question about Motorola Mobility RAZR V3
The usual button problem!!
I have a motorola v3 and all but the off buttons stopped working yesterday. I tried to clean it and now i have the menu key and numbers 1,2,3 and 4?! I have tried to read up on this (very common) problem and i have also tried to find out what this keypad flex file is but to no avail. Can you give me some advice on where to go or what to do next as i have mounting recieved messages that i don't really wanna lose. Thankyou, Tara xXx
  • 181 Answers
Re: The usual button problem!!
On a RAZR, there is a problem in the joint or hinge where the phone opens, and the flex cable that connects the two often comes loose. This can usually be fixed short term by pushing the halves of the phone together firmly, and then opening and closing the phone. Do this while the battery is out.
For a long term fix (or if that doesn't work), you have to take the phone apart. It would be best to take it to a repair shop for this.
You can access your data through the Motorola Phone Tools, so you should still be able to backup the data you are concerned with.
Posted on Dec 06, 2007
0 characters
3 Points
Motorola v3 problem
looks like you need a clean of the unit and replace the keypad.
refer to here for intructions
Jul 21, 2009 | Motorola Mobility RAZR V3
I can't remember my unlock code on my sms
sometimes it defaults to the manufacturer security code "000000" or "1234"
also try the last 4 digits of your phone number.
Mar 18, 2009 | AT&T Motorola RAZR V3 Cell Phone - Black
Master reset on motorola rzr 2
HI again,
1st let me tell u. U have to give a frequent try to it.
Its a tricky.
1) The two buttons work as menu buttons. One is in the center of directional keys and second is above the directional keys. U hv to press the second menu button above the directional keys.
2) While holding menu button, a message appears "shortcut not allowed for this item". The change of 4-digits slot to 6-digits slot may be after u do it also. At this time, type 000000 (six zero). Anyway, try it holding menu for 3-4 seconds or by holding it for a little long time.
Looking for ur kind feedback. Dont forget to Rate my solution too.
Be sure to post a clarification request after ur problem is solved.
May 08, 2008 | Motorola Mobility RAZR V3
Backlight display not working
Hey Dannes1956,
The Motorola V3m has a light sensor, which is visible just above the right soft key -- the key above the CLR button. This light sensor turns the backlight on when you press a key in the dark and disables the keypad backlight when you are in a well-lit area.
Your phone sounds like it's operating normally. I believe they disabled the option to activate or deactivate that feature.
Hope this helps,
Mar 17, 2008 | Motorola Mobility RAZR V3
well dirt under key pad or water ect would need t4 t5 star tools take it apart clean it well ok thx nick
Feb 06, 2008 | Motorola Mobility RAZR V3
Motorola razr v3 keypad....!!!
This is usually caused by one button being stuck down, and the volume control buttons on the left of the main display, and the voice button on the right of the main display are the usual culprits. Try squeezing them and making sure they move normally. Then power down the phone, pop out the battery, and give it another shot.
Dec 15, 2007 | Motorola Mobility RAZR V3
The buttons on my phone won't work
what you should do first is have the firmware on the phone reflash , then if that does not work then you can buy a new phone.
Nov 08, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Keypad troubleshooting
when I open my phone it seems to be stuck on the right arrow button so it goes to "IM account". I was really confused this morning because even if I click exit, it goes back to the same thing on its own. when I get a chance to press menu, it just whirls around as if I'm pressing the arrow over to choose a category but I'm not.. its weird.. probably the weirdest phone I've ever had
Sep 23, 2007 | Motorola Mobility RAZR V3
Motorola Razr - Keypad Doesn't Work
My phone developed the same trouble............ Removed battery and SIM and blew dry air into anyhole I could find, put it back together and has worked ever since.
Thanks for the tip
Jun 25, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
22 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Chris Hunt
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
