Hi
I had a mattet when install Ubuntu 9.04. Error : input/output
I don't know it. Help me solve this matter.
THanks you
Nguyen hoang Thuong
Comments:
Sep 01, 2009
- Hi
THis matter still it. Because, I using Notebook Asus Eee PC 4G, It has webcam, micro built itself, can't unpluge. So, I have some question using Lnux.
1. I install Ubuntu 9.04 version laptop & desktop but can't install Yahoo messenger, I would like chat voice by YM. Pignt can not do it (only chat).
2. I lost Origine driver Linux for this notebook (Asus-Eee PC 4G).
3. Why it operating Linux, it has temperature higherthan normal ?
Thanks help these matter.
Regards.
Nguyen hoang Thuong
Most software problems are solved by uninstalling the product, rebooting and reinstalling. if the cam is built in the you can't unplug it. if its not then unplug before you install software.
If your system errors out when uninstalling then you have to install it first again and repair if you get the option, then must uninstall. the software should be removed then. reboot and reinstall. the problem should resolve itsself.
if not check out my other solution to clearing/checking your system for malware or viruses first.
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM...
(More)
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM WIN XP Pro disk. I have changed boot priority so that CD is first device however it goes to HDD. I just want to get it started in recovery or DOS so tat I can manually fix registry and run chkdsk /p/r. F9 does not work!
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a...
(More)
wont allow facebbook access , have set all the interbet settings to factory settings, cant do a restore as not enough memory, taken of AVG as was told thats the porb, trying to sort out a friends one and its just not having it
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to...
(More)
I have an asus eepc and a few months back I installed Windowz xp in it. However, I cannot connect to the internet. How can I fix this problem?
