Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer projection tv model sd-p404
I cant figure out a way to program the channels on the tv. it's missing a few channels and i cant add or subtract them from memory. how do i get all the channels
  • chillefreeze Apr 06, 2008
    i cant get to main menu because the buttons on the set don't work the remote does but has no menu option just picture and sound control
  • Pioneer Master
  • 5,138 Answers
In menu go to cable/then press auto programming see if this fixes your set.
Posted on Jan 31, 2008
  • ladywinn
    ladywinn Apr 07, 2008
    Go on line type in make and model then order hand unit that org, went to set or see if any pawn shops sell their hand units to set took in on pawn that went out.
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Lost the remote control, how to i add in cable channels? it will only pick up 2-12 - when we had the remote i could add them in, now that it is gone, how do i do it? when i change channels manually or type...
The replacement for model indicated is rather expensive. What you will find is all Hitachi remotes made from 1999 to date will operate that set.
2-12 means the set is in the Air band and not the cable band. A lot of these remotes are readily available on EBAY and other places, I have several Hitachi remotes and all codes for all their regular tvs, projection, LCD, and Plasma use the same codes.
All you need is a remote that will go into the menu and allow you to select Cable and then go and do auto program.
I have a Hitachi remote for a 1991 projection set and it works on all later sets, only a few features are missing for certain models.
It is either this or try a universal, but I suspect a Universal will not do what you want.
Let me know if you have questions.
SD TECH
Jan 15, 2011 | Hitachi 13GA1B 13" TV
I can't get my dish system to work with this TV. I'm only getting 2 chanels. How do I program new chanels to this TV? I need chanel 60.
It depends on the TV a bit. Which model of Broksonic TV do you have? Do you have the original remote? (remotes.com has replacement remotes for many TVs.) Look at the TV (or the original remote) for a menu or channel add subtract option. (The TV is probably programmed to skip the channels that didn't have a signal in the past so you need to reprogram this.) If the TV is a really simple TV (with just the channel and volume controls on the TV), you'll need the original or a direct substitute remote (or a higher end programmable remote). Most basic universal remotes will control power, channel and volume but not the reprogram channels option (in my experience). If you can program the add/remove channels, press 60 on the remote, wait for the TV to go to that channel and then press the Add Channel button. Alternately, with the satellite receiver on, press the combination to search all channels and program the skip to channels with signal.
I hope this helps.
(I had a really old Emerson TV; when the original remote started to fail, the cheap universal remote didn't handle the channel programming. Fortunately, the original remote would usually still work for that.)
Jul 07, 2010 | Broksonic TV
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
I have a model number sd-p503p-k i dont know how to add channels after channel 65?
You probibally need to re-scan your available channels. The TV goes through and grabs all of the available channels that it sees so you don't get any all static channels while your surfing the tube. The manual is actually about 35 megs so I cannot post it here, but here's what it says; - Hit Menu
- Select Setup
- Select Channel Setup
- Select Auto Channel Preset
- Select Antenna and change it to A or B, whichever one your using.
This should fix your problems, unless your area doesn't have channels past 65. If that's true then everything I just wrote is irrelevant, but there ya go!
Oct 28, 2009 | Pioneer SD-532HD5 53" Rear Projection...
TV comes on with snow and clears up after 10-15 mins
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Pioneer SD-P62A3-K 62" Rear Projection...
Input for Ipod??
remember those cd kits that came with a tape to insert to the (stero)pioneer fh-p404 and the output jack to the cd player? well instead of plugging into cd player plug it to your ipod....my pioneer fh-p404 has a tape deck and i'm able to hear all of my music without cds or tapes and i found the tape kit without the cd player for 6 bucks at walmart go figure!
Dec 09, 2008 | Pioneer FH-P404
Pioneer projection tv SD-p5oa3
only codes for pioneer tv are 0166 0679 otherwise
Mar 11, 2008 | Pioneer SD-P50A3-K TV
Hooking up my cable
You will need to go into the menu and do a channel scan. Until the tv scans through all of the channels and finds them you will not get them. This is also where you would switch between air and cable. If you go through the menu untill you see this you will fix your tv.
Feb 06, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
303 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
