Question about Microsoft Windows XP Professional for PC
DISKETTE NOT WORKING
My system is running Microsoft 2000, the diskette is not working. I checked the wires inside the box, they are all connected.
    Champion:
  • 209 Answers
Check if your diskette is still working, try an old diskette which is working then if all your diskette are not working it is the floppy drive problem. replace your floppy drive. now a days diskette can easily damage if you use this for 3times by erasing then copying it has short life span. try replacing your floppy drive if you have spare
Posted on Dec 06, 2007
2000 chevy blazer horn doesnt work
check fuse box inside of car also fuse box under hood too..find ur horns and if possible u can reach the wire thats plugged into each one disconnect them 1 at a time get another wire long enough too reach ur battery connect 1 end to horn with other end of wire gentl touch battery positive terminal horn should sound if bothe horns sound u have a fuse blown..
Aug 16, 2013 | 2000 Chevrolet Blazer
My computer lost ( ntlpd is missing) plus said press ctrl alt del it's not coming up.
Sounds like you've got some corrupted files. If you have your Windows disc, try a reinstall/repair or try to drop back to a previous restore point.
If those don't work, you might try to reformat/re-install your software. (backup your data if you can beforehand as reformatting will wipe all data from the drive).
This can even be a hardware problem, like the HD controller bad, which caused the file problem in the first place. Or a virus can cause such issues, which would make reformatting/reinstalling a good idea as well.
Make sure you have a defragment task running every month, if not every week. You can schedule to run at night or during the day, whenever you're not at the computer. If you turn it off when you're not using it, just leave it on that one day (or night) that the defragment needs to run... or start it manually before you go to sleep and unless it's a large drive, it should be done when you get up.
Good Luck!
8^)
Jan 02, 2011 | E-Machines eMachines Desktop PC
My pc was dislpaying''DISK BOOT FAILUER, INSERT DISK AND PRESS ENTER'' but I did not install any new hardware neither do I have any cd on any drive.
I'm afraid you need to reinstall your windows/linux again. That or check if your harddrive is connected and working properly.
Oct 20, 2010 | Computers & Internet
Can't Open a Diskette
Have you tried booting up in safe mode and testing the drive access?
Apr 14, 2010 | Microsoft Windows XP Home Edition
Ntldr missing, trigem dreambook, windows2000 P3 600Mhz
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive.
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)WINNT
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)WINNT="Microsoft Windows 2000 Professional" /fastdetect
Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the rootdirectory of the primary hard disk drive. For example, C:NTLDR andC:NTDETECT.COM should be the locations of these files on manycomputers.
  • Please keep in mind thatthese files are hidden system files, if you need additional help withviewing hidden files in Windows please see document CH000516.
Oncethese files have been copied to a floppy diskette reboot the computerand copy the NTLDR and NTDETECT.COM files to the root directory of theprimary hard disk drive. Below is an example of what commonly should beperformed from the A:> drive.
copy ntldr c:
copy ntdetect.com c:
After the above two files have been copied, remove the floppy diskette and reboot the computer.
Jan 13, 2010 | Microsoft Computers & Internet
I have an E-Machine desktop PC that is failing to boot. It is running on windows 2000. When it starts booting, it says that one of the files needed for booting is missing. It further tells me to run a...
Windows 2000mag-glass_10x10.gif boot disks allow you to by-pass damaged Windows 2000 operating system files to get your computer up and running in a solid, stable configuration. You simply tell the computer to access the Windows 2000 codes necessary for start-up from your floppy disk drive rather than the hard drive. Creating the set of four boot disks is specific to this version of the operating system
  1. Step 1 Insert the Windows 2000 Professional CD into your computer's CD-ROM drive. Insert a formatted, blank diskette into the floppy disk drive. Have three additional formatted, blank diskettes standing by.
  2. Step 2 Click "Start" at the bottom left corner of your computer screen to open the start-up menu. This lists the start-up actions available for Windows 2000. Select "Run." The program then asks you to designate the drive, program, folder or file you want to open by either typing the destination or clicking "Browse," to select the destination from the Windows 2000 directory.
  3. Step 3 Click the "Browse" button at the bottom of the pop-up window. The PC's hard drivemag-glass_10x10.gif directory window appears.
  4. Step 4 Browse the computer's hard drive directory and select the CD-ROM drive to designate it as the destination you want to open. Click "OK" to open the CD-Rom drive. The folders and files saved on the Windows 2000 CD now appear in the directory format.
  5. Step 5 Select the "Bootdisk" folder. A directory of files appears.
  6. Step 6 Double-click the program file "Makeboot.exe," then click "OK" to launch the Windows 2000 boot disk maker program. The program checks that you have a formatted diskette in the floppy disk drive and then begins to make the boot disk.
  7. Step 7 Watch your screen as the process of making the boot disk progresses. The boot disk for Windows 2000 requires four diskettes. The program cues you to remove the first diskette and insert the second, and so on until all four diskettes are created and the boot disk making process is finished.
Nov 15, 2009 | E-Machines eMachines Desktop PC
1 TB HD of Samsng is not recognized
some motherboards and processors are compatiable with certain hd's only. Here is a list:
Pentium: 2GB through 5GB
Pentium 2:5GB through 20GB
Pentium 3: 20GB through 40GB
Pentium 4: 40GB through 500GB
Pentium D: 40GB through 1TB
Celeron: 2GB through 500GB
All AMD's: 300MB to whatever.
so, that's probably your problem. I suggest
Jun 05, 2008 | Asrock K7VT4A-Pro Motherboard
Hard drive backup
This seems to be a good article on ASR backup and how to eliminate your error message.
See Link
Dec 16, 2007 | Dell Latitude D600 Notebook
Considerations for Windows 2000 - WorkPad c500/505
The WorkPad c500 and c505 can be used only with PCs running Microsoft Windows 98 or Microsoft Windows 2000 operating systems. NOTE: Microsoft Windows 95 and Microsoft NT 4.0, or serial connectivity, require a serial HotSync cradle or cable, available separately from Palm, Inc. The WorkPad HotSync utility will not sync via IR when the host PC is running Windows 2000.
Sep 14, 2005 | IBM WorkPad c505
Sep 14, 2005 | IBM WorkPad c500
Microsoft Windows XP Professional for PC Logo
46 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
