Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
D link cd
Hi, i try to launch the cd installer for d link router with Mac, but cannot open the files, can you help?
    Novelist:
  • 173 Answers
  1. Then u have to setup ur router first
  2. Turn off the power on your computer.
  3. Securely connect an end of an Ethernet cable to your computer, as shown.
  4. Securely connect the other end to any of the router's four LAN ports.
  5. Connect a second Ethernet cable from the router's single WAN port to the modem.
  6. Make sure the modem is connected to the jack or cable to the Internet that was set up by your ISP.
    1. Start your network in this order:
      1. Turn the modem power off.
      2. Turn the router power off.
      3. Turn the modem power back on. Wait two minutes until the lights are stable.
      4. Turn the router power back on. Wait one minute until the lights are stable.
      5. Turn the computer power back on.
    2. Open an Internet browser, and type http://192.168.0.1. If a "Configuration Assistant" appears immediately, then do not follow the rest of these instructions. Follow the Configuration Assistant instructions, instead. Once you are finished, test your Internet connection by browing online,
    3. Type admin for User Name, and password is blank. (do no type any thing for password.)
    4. Click OK. This logs you into the router.
    5. Click the Home tab and click the WAN button. Dynamic IP Address is the default value, however, if Dynamic IP Address is not selected as the WAN type, select Dynamic IP Address by clicking on the radio button. Click Clone Mac Address. Click on Apply and then Continue to save the changes.
    6. Power cycle the cable modem and router:
      • Turn the cable modem off (first)
      • Turn the router off
      • Leave them off for 2 minutes**
      • Turn the cable modem on (first)
      • Wait until you get a solid cable light on the cable modem
      • Turn the router on
      • Wait 30 seconds
      that would fix your problem..
      in case if yoy have any problem revert back with your internet service providers name.(isp).
Posted on Dec 06, 2007
Is it possible to recover corrupted PDF?
You can try to recover it with PDF Open File Tool http://www.pdf.openfiletool.com/ This tool should help you with it. Good luck!
Feb 24, 2015 | Adobe Acrobat v.X Pro - PDF Application -...
Tip
HOW TO CHANGE FONTS OF N73
HI BUDDIES,
TODAY I AM GOING TO TELL YOU A GREAT TIP ON HOW TO CHANGE FONTS OF N73.FOR THIS YOU NEED 4 THINGS
1)A SOFTWARE CALLED SECMAN(DOWNLOAD IT FROM usefullsoftz.xtgem.com)
2)Y FILE VIEWER(usefullsoftz.xtgem.com)
3)FONT ROUTER.INI FILE(usefullsoftz.xtgem.com)
4)FONTS
A) FIRST OF ALL TAKE A FONT FILE ANT MEKE ITS 4 COPIES IN PC NAMED AS
NOSNR60.TTF
NSSB60.TTF
NSTSB60.TTF
S60ZDIGI.TTF
AND TRANSFER THEM TO UR PHONE
B)INSTALL SECMAN IN UR PHONE AND LAUNCH IT.WHEN LAUNCH IT,IT WILL RESTART UR PHONE.DONT WORRY ITS NORMAL.AFTER THIS AGAIN LAUNCH SECMAN AND PRESS OPTIONS AND CLICK ON
"TURN SYSTEM CAPS OFF"
C)NOW INSTALL Y FILE VIEWER.NOW LAUNCH IT AND OPEN C DRIVE THEN SYSTEM FOLDER,THEN RESOURCE FOLDER AND THERE U WILL SEE A FOLDER NAMED AS "Fonts"(if not then create it)
D)IN FONTS FOLDER COPY PASTE THE FONT ROUTER FILE AND FONT FILES AND EXIT THE Y FILE VIEWER
RESTART UR PHONE AND SEE THE CHANGED FONTS
ENJOY
on Apr 14, 2010 | Nokia N73 Cellular Phone
How to run REader Rabbit without CD-Rom? I can copy the disk contents to the HDD... but then all it does is error.. is there any way to use my software on my ePC when travelling without taking the CD's...
I have a (partial & ugly) solution here.
First, copy the entire cd contents into a folder on the computer. e.g. "C:\Program Files\The Learning Company\Reader Rabbit Reading 6-8 full cd copy" Then run the installer from \INSTALL\SETUP32.EXE
DO NOT delete the files which you copied off the cd.
What this does is it installs the program as if it installed off the cd, and creates initialization files which look to check that a certain file exists **in the location that you installed from** - You have fooled the launcher into thinking that the cd is in place.
However I am still not completely satisfied, because every time you launch the program, Windows 7 requires administrator privileges (so my kids have to come and ask me for my password every time).
Jan 03, 2011 | The Learning Company Reader Rabbit's...
I can see the drivers CD, but can´t install
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router ad the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 14, 2010 | D-Link AirPlus® G DI-524 Wireless Router
I have a laptop with windows 7 pro I'm trying to install a wireless g router netgear wgr614 with the cd. It is telling me that I need windows xp or 2000 to install. It wont let me install it with windows 7...
You really don't need to use the cd. Below is a link to the setup procedure:
You'll need to connect a PC with a cable to the router. Open browser and type in http://192.168.1.1 in the address bar. Input username as admin, the password is password. If you need more help, let me know. I'm leaving a link to the setup manual for your router below:
ftp://downloads.netgear.com/files/WGR614v9_SM_26Oct07.pdf
Dec 30, 2009 | NetGear WGR614 Wireless Router
Launching problem - Reason4
try this forum :
http://www.reason4tutorial.com/Forum/tabid/256/Default.aspx
or try to "contact" them
hope thats help
Aug 24, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
Wireless-B BroadBandRouter BEFW11S4 driversfor mac os x &win xp
Just connect the computer wired on the computer your mac and no need to run the disc because it will not read it because the cd for linksys is good only for windows. You may OPEN safarri or IE browser, then try type on the address bar 192.168.1.1 - nothing for username and password is admin.
from there you may configure the router on what type of internet connection you have from you ISP, don't forget to save settings...
thank you
Jun 15, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Need help installing my router
For mac computer there is not need to use the Cd assistance.
With the router connected to the router and modem, open the internet explorer. On the address field of your IE type 192.168.2.1.
- Click on Connection Type in the left hand column under Internet WAN heading. If asked to log in, live it blank and
- Select PPoE if you have a dsl connection. Enter your password and click Submit
-Select Dynamic, then click on Next,
- Select MAc adress in the left hand column .
- Click on Clon Mac Address then Aplly Changes.Wait 25 seconds.
-Close the windows.
-Unplg the cable from the green port for about 1 minute then plug it back in.
Now you should be able to connet to internet.
Oct 23, 2008 | Dynex DX-E401 Router
Error message when installing CD
simply dont install disk on mac configure router from desktop and connect to network from laptop(MAC).
Aug 25, 2008 | Belkin (F5D7230-4) Router (587009)
How to install D-link DIR 300 for MACBOOK
You shouldn't need to install anything off the CD. Simply plug your Macbook into the DIR-300 via ethernet (making sure you manually set your Macbook's IP to 192.168.0.x (where x is anything from 2-254). Then open up your web browser and type 192.168.0.1 into the address bar. This will log you into the DIR-300 (I think the default login is "admin" with no password).
Refer to the manual for the configuration for the rest of your setup.
Jul 20, 2008 | Computers & Internet
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
116 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
