Question about Kitchen Ranges
Frigidaire FEFL79HS Element won't shut off
Front left element won't turn off. It stays at the same temp I last cooked on it at. I can turn the temp up, but it wont turn temp down. tried unplugging and left for a few hours - didn't fix the problem.
5 Suggested Answers
  • 5911 Answers
SOURCE: Dual cooking zone burner not working
Okay...what you have is a dual element with the 6 inch coil burned out. Yes, this is repairable, but unfortunately, since this is a dual element, it is sold as one assembly. The part number for a replacement is WB30T10044, and you can find it at for about $90 (repairclinic item number 824238). I know it isn't cheap, but it beats having to pay for a service call, or buying a new appliance.
If you wish to repair this yourself, you can do so by following these steps:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
3.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, unplug the wire harness from the connector and follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the affected surface element. Take note of the numbered positions where the mounting screws are located and locations of the wires. You may want to write down the numbered positions and the wire color codes. HINT: A good digital camera can save you time if you have one. You will need to install the new element in the same manner.
d. Install new element (upside down). Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
e. Re-install the cook top back on the range and you are DONE.
NOTE: If your range does NOT have a disconnect plug on the wiring harness you will need to perform the repairs with the cooktop propped up, and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the element secure until you have it screwed back into place. Don't forget to remove the duct tape when completed. Once completed, lower the cook top and secure with screws.
I hope you find this information helpful. Let me know if you have require additional assistance.
Posted on Sep 09, 2008
  • 160 Answers
SOURCE: Creda C461E Cooker
the control thermostat may also have been burned out. check it.
repair manuals can be located from here.
Posted on Dec 05, 2008
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
  • 10865 Answers
SOURCE: Element on light won't turn off when stovetop is cool
You have a burner sensor that is stuck in the open position sending the signal that the glass top is hot. This is not a safety concern but if you want the light working properly you will have to replace that sensor. Perhaps you can now call around and tell the various repair people what you need to have changed and they will be able to tell you how much it will cost.
Posted on May 12, 2009
  • 55 Answers
SOURCE: Front left dual element on a Frigidaire ceramic
open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
0 characters
1 Points
Element light stays on after all power control knobs are in off position?
Good Afternoon Cindy,
I see that you are having trouble with the element light staying on after all power control knobs have been put into the off position on your Frigidaire range, model# FEF366EC. The Element ON indicator lights will glow when one or more of the surface elements are turned ON. A quick glance at these indicator lights when cooking is finished is an easy check to be sure all control knobs are turned OFF. The Hot Surface indicator light will continue to glow AFTER the control knob is turned to the OFF position and will glow until the heating surface area has cooled sufficiently. I suggest resetting your appliance by shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "clock" button, and then you will press and hold down either the up or down arrows until the correct time appears. Try turning the burner on that the indicator light stays on the most. When you turn it off if you are still having trouble with the element light staying on, I suggest contacting a local authorized technician. Hope this helps.
-Best Regards-
Apr 27, 2014 | Frigidaire FEF366EC 30" Freestanding...
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
Frigidaire model FEC30S6ABF front burner wont turn off
Hi - From what you have described the range could possibly be experiencing a faulty element/sensor or the communication to the element from the control board is now compromised. If you are referring to the left front element, the part number is 318178110/MSRP: $65.86. Right front element, part number 316224201/MSRP: $89.60. I would suggest contacting a professional to move forward accurately and properly diagnose the range.
Oct 18, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Element stay on hot when switch is off
I have the same problem. I was cooking at 180°. After a while the element went full on with the digital readout still at 180°. Inside temperature hit 550°. Oven would not turn off. I had to trip circuit breaker to shut off oven. After Resetting breakers oven works normal but randomly will jump to full on high. I can't trust it and cannot figure out what problem is. Anyone know how to fix?
Nov 27, 2010 | Frigidaire PLEF398AC Electric Kitchen...
The right front element will not heat properly on my Frigidaire electric stove. If you turn the knob to a low number it barely heats. It is very frustrating because you cannot keep something warm or cook...
Without a proper model number I would say you need to replace the element or the infinite switch for the element. Best off to call a reliable repair company such as Sears.
Jan 31, 2010 | Frigidaire Kitchen Ranges
Frigidaire range model #FEFLFSA, is the top element
When you say Top Element, I assume you mean the TOP OVEN ELEMENT, correct? You have bake, and broil? Bake is usually on the bottom, and broil is the top. In order to have the oven operate correctly, the top and bottom elements may come on at start, in order to do as you just said, "Preheat the oven". This will insure an even distribution of the heat in the oven box and result in better cooking expierences. I would not be alarmed or concerned if the top element came on for a short period to pre-heat in preparation for cooking. This is normal. If the top element stayed on, and did not shut off on bake after the pre-heat period, then I would say you have a control board problem. However, if it comes on and then goes out, except when you are broiling, then I would say that this is normal for your stove, and the pre-heat mode of operations. Your owners manual should advise you of this very process in the guide section to how to use the oven. I hope this helps and that all your cakes, pies, souffle's and the like are......delicious. I'm sure they are. I hope this helps and eases your concerns. Kindest regards, Slats.
Sep 25, 2009 | Frigidaire Kitchen Ranges
Broiling and Baking Element Stopped working
the thermostat is bad that's the one that turns bake and broiler elements,but before you replace anything check for power on wires connecting to the elements.
Dec 09, 2008 | Frigidaire PLES389D Electric Kitchen Range
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
Burners won't stay heated
if you are using the range to do general ever day cooking then if the units are cutting of you could have and infinate control that is bad cutting the element off before the temp heats up the element, you also could have an element sensor that is turning off the element before it gets to the temp that you are wanting.
a volt meter and a wiring diagram is a must to find out what is wrong
Apr 16, 2008 | Frigidaire FES367 Electric Kitchen Range
Doubel element
If only the outer ring of the element is getting hot then the element is bad. The elements should have a 5 yr warranty that covers the part only so check your owners manual.
Oct 06, 2007 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
179 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
