Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Dvd plays fine sound/picture...No sound or picture with cable input
Cable checks out fine plugged other tv into it cable repair was here no problem with cable....DVD plays fine with sound...Normal TV,no picture or sound....Had a lightning strike 3 houses away on pole Question,Is there a fuse associated with the input of the cable signal to the TV thru the input jack?
  • 934 Answers
John,
To answer your question no, there are no fuses associated with the tuner input - through the "F" connector jack.
You have there a V26 chassis which has, among other things, standard digital and analog signal inputs. If one works but not the other - and you've verified it's not the cable then the only alternative is the signal board, Mitsubishi p/n# 930b923002...
But don't rush out and buy this puppy, it's a fairly expensive board and there are alternatives to replacing it new or used - PTS Electronics can rebuild this board for half the cost of a new one and most techs use PTS for that reason.
My best advice is to have a qualified shop estimate the repair and if they decide that the signal board needs to be replaced and quotes you a price ask them then about having it rebuilt.
Also take the unit to them to save the pickup/delivery charges and ask for your estimate in writing...
Hope this helps!
Bill
Posted on Dec 06, 2007
Nothing on screen when DVD inputs are plugged into our Aquos.
Check that the input you are plugging the DVD into on the TV is actually selected as the TVs input. Try using a different input and also different input types/cables. Most DVD players will have HDMI and also either component or composite type outputs. Try the different cable type and make sure the TV is looking at the correct input. Do you have sound?
Feb 11, 2015 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My Insignia Blu-ray DVD player and our Panasonic DVD player are playing only the sound with no picture. We put the correct imputs on the TV. They were playing fine a few days ago. We have Charter cable....
Sounds like the input board on the tv fried. (45-65$ fix if that's it)
Try the same two devices on different inputs , ie change from hdmi to component , or just use hdmi 2 instead of one, you get the idea.
Make sure the devices dont work on other inputs on the tv.
Then take a different device , like a 3rd dvd player and try it.
If nothing works in that input but works in other inputs the tv input board might (likely) need replacing.
If the third fresh device does work in that input , it is both dvd players or the cable you are using. (try to use a different cable in the tests than the one you have already used. )
Feb 13, 2018 | Zenith DVB312 DVD Player
I have no picture on DVD with scart lead on AV1 and no picture or sound on separate player on HDMI connections. both players work fine on other televisions.
Is the same HDMI cable you use in other TV.Will you properly check the plug of HDMI cable at the HDMI input of your TV and check the setting.
Jul 11, 2011 | Televison & Video
My 27" Sanyo DS27800 when
U using the RCA AV cable Y,R,W plug into those tv video input holes wright?Tries another RCA Y,R,W AV cable,see if it work?U have tools like a soldering iron,a roll of solders,also can u do basic soldering?Tries take some alchahol clean the Yellow input hole and take the tv aparts resolders it connections joints,now the video out it should work again,if not yellow input hole might be shorted require replacing.
Jan 27, 2011 | Sanyo DS27800 27" TV
No Picture on HDMI using Philips DVP5992.
You can try out by connecting the CVBS (Yello) out from player to TV and connect HDMI out from Player to TV. Goto CVBS input on Sony TV. Select set up and you should get the HDMI Video options availble. Try to change the resulution and check for Video on HDMI source.
Which disc you were playing PAL or NTSC? PAL should work for Europe.
Feb 08, 2009 | Philips DVP5990 DVD Player
How do I hook up my magnavox 510 700watt DVD player and sorund sound system. My TV does not have a S-Video plug in the back it is a 27" symphoinc tv. I just have the cable plug in screw on and the 3 plugs...
you will need an rca type cable to go from your dvd player to the tv. you should be a able to find one at your local walmart for around $5
simply connect the cable to the yellow input on the tv and the yellow output on the dvd player, then change the input to your auxillary source.
Feb 02, 2009 | Televison & Video
Proscan tv surround sound hook up
This depends on whether you have digital cable box or not. If you have a Digi Cable Box look for the red/white RCA output and connect this via RCA cable to the Red/White Audio input on your surround.
If just Basic Cable look for a red/white audio output on the back of your televison. connect this to the Red/white in on your surround. Could be called tv in or auxillary.
Jan 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Vizio liquid crystal tv l32hdtv
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
I suspect either the VCR or the cables.
Apr 22, 2008 | Vizio L32 32 in. LCD HDTV
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
