Question about SuperMicro X7DAL-E Motherboard
Can not find Serial ATA II 1TB HDD
How to set BIOS to use Serial ATA II HDD
  • zhangbl Dec 09, 2007
    Thank you.
    I set Serial ATA enchaced
    Raid disabled
    ACHI abled
    Reinstalled the OS.
    This process works.
    Genius:
  • 1,601 Answers
Page 62 will show you to set up your sata harddrive. It looks like you set it to auto, and let the BIOS find it
http://www.supermicro.com/manuals/motherboard/5000X/MNL-0876.pdf
Let me know how you make out.
Posted on Dec 08, 2007
  • Thomas Christopher
    Thomas Christopher Dec 09, 2007
    I am glad it worked for you. Please rate this as a FIXYA. Thanks for the update.
I have a HTS721010G9SA00 hard drive on my laptop. It is constantly clicking even when I have minimum apps loaded i.e. desktop wall paper showing apps.\r\n Laptop works OK but the bios battery has gone so...
hi, your HDD is starting to fail. there are many replacement available in the market. but i recommend seagate sata hdd 2.5 its not so expensive 500gb more or less $60 in peso 2.5k
Aug 23, 2011 | Hitachi Travelstar 7K100 HTS721010G9SA00...
I want to upgrade the HDD of a Toshiba Satellite P200-156 to 500GB/640GB/750GB or more if possible but I'm not sure which specifications must be compatible. The 250GB HDD is a Fujitsu MHX2250BT Serial...
I think its okay to upgrade your HDD till 1TB, just make sure that HDD have serial ATA port to connect. my little advice is when you want to upgrade your HDD is look your mainboard specification, because HDD is work when it can recognized by mainboard. hope this useful, regard riyan.
Jun 08, 2011 | Toshiba Computers & Internet
I have a HP Asterope Motherboard The Sata HDD or the Sata CD/DVD cannot in not detected in the BIOS and the computer can not boot-up When I use a IDE drive on the Ide port, It works But I have a...
Reasons a sata device might not be recognized in BIOS:
(1)Serial ATA disabled, enter bios and enable SATA.
(2)Serial ATA cable defective
(3)Serial ATA drive defective
(4)Serial ATA cable defective
(5)Serial ATA device not plugged into power.
(6)Serial ATA power adapter defective.
Feb 26, 2011 | Computers & Internet
Hdd password
If you forgot your computer password
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Oct 05, 2010 | Hitachi Deskstar T7K250 HDT722516DLA380...
Trying to locate a HDD caddy/Connector
In normal circumstances it would be a USB 2.0 but I don't know what you are connecting it to.
Jul 29, 2009 | Computers & Internet
Mobo doesn't recognize hdd
Your board shows serial ATA compatibility, I'm pretty sure the Seagate 1.5TB HDD is a serial ATA II device. These are not backwards compatible. Sorry. Hope this helps.
Dec 23, 2008 | Abit VT7 (MBABITVT7) Motherboard
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Sata Port Connector is not avtivating
I had the similar problem with the K8MM-V Motherboard. I has been using a PATA HDD. I need to intall a 250Gig Seagate SATA HDD. Despit all the Bios Configs the PC Could not detec the HDD. Untill i Put a Jumper on the HDD  limiting the SATA HDD to 1.5gig of OS instead of 3gig. Look at the Label of your HDD
Oct 28, 2008 | MSI K8MM-V Motherboard
BIOS PROBLEM
I don't think you have a problem with the BIOS version but more likely with the settings.
Please enter in the BIOS and be sure that under: main menu, ide configuration, Parallel ATA IDE controller is set up as Primary. Then you go under advance menu, Serial ATA IDE controller and be sure you don't have RAID.
Copy of the manual can be find here http://dlsvr.asus.com/pub/ASUS/mb/sock754/k8v_vm_ultra/e2476_k8v-vm_ultra.pdf
Let's start with this checks and then let me know.
Sep 28, 2008 | Ultra (31624) (ULT31624)
Wd800jd sata hard drive not recognized in bios on boot up
Hi, A couple of ideas: 1. There are 3 versions of this motherboard: Dragon Plus, V1.0 & V2.0, perhaps your BIOS needs an update to be able to recognize the new HD. This of course would require flashing; 2. There are two variations of a WD SATA hard drive: Serial ATA amd Serial ATA II; 3. Re Jumper settings: the eight-pin jumper block is only used to enable power management on the drive. There are no master/slave settings since there is only one drive per cable; 4. If you are fresh installing Windows on it, you need to press F6 when asked by the Windows Installer and follow on-screen instructions. Hope this be of some help/idea. Post back how things turn up or should you need further information.
Sep 17, 2007 | Western Digital Caviar SE WD800JD SATA...
SuperMicro X7DAL-E Motherboard Logo
176 people viewed this question
Top SuperMicro Computers & Internet Experts
David
David
Victorman
Victorman
Joseph Hoffmann
Are you a SuperMicro Computer and Internet Expert? Answer questions, earn points and help others
