Question about SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 1.0 GB
My SanDisk Sansa m240 won't come on and when i put a new battery in it and it still won't come on and when i plug up my mp3 player to the computer it will come on but when i unplug it, it cuts of right after it is unpluged. What do i do?
  • 2 more comments
  • fix ya Dec 06, 2007
    i just took it apart and it was really dusty inside so i blew it out and put it back together and now it works just fine
  • Anonymous May 05, 2008
    How do i take it apart?
  • pjolley Jun 05, 2008
    I can turn my Sansa on but it stays on the main screen and will not do anything else? What to do?????
  • Joshua Dragon Sep 10, 2008
    How do I take the cover off from my sansa.
I cant erase songs on it
Posted on Jan 03, 2008
Will my mp3 player (sandisk sansa m230) charge
Assuming the computer puts out enough juice, yes. Not all USB ports do.
Plug it in, and the Sansa should say "Charging" if it is charging. If it doesn't, try a different USB port if possible. If your computer has ports on the front/side and on the back, the back ones are more likely to put out sufficient power.
Apr 29, 2010 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa e260 (4 GB) MP3 Player MP3 and Digital Media i have a e260 sansa mp3. when i plug it into my Answer i have a e260 sansa mp3. when i plug it into my computer it wont charge what should i do
There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jan 30, 2010 | SanDisk Sansa e260 MP3 Player
I have a sansa sandisk mp3 player. when i bought it it was working excellent.but all of a sudden it stopped working.this mp3 has no reset button i do not know how to fix the problem. sansa sandisk...
1. Are you able to turn it on ?
If so, press the the "power on" button the second time to activate the menu.
Still no luck ! Try putting in a new battery and try again.
2. You cannot "reset" anything.
3. Open up "windows explorer"
4. Scroll down the left pane of the window till you see the "sansa" removable disk
5. Right click it and select "format"
6. After formatting, try adding your files back again.
7. Use the >= button on the player tp play the songs.
Hope this has been helpful to you.
Aug 29, 2008 | SanDisk Sansa m240 MP3 Player
My SanDisk Sansa 4.0 GB does not power on @ charge.
Make sure that your sansa lock switch is in the unlocked position.
Aug 14, 2008 | SanDisk Sansa e200 MP3 Player
MP3 SANDISK SANSA
does your computer recognize it when you plug it in?
May 20, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk, 2 GB Sansa mp3 player won't charge
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
Jan 16, 2008 | SanDisk Sansa m250 MP3 Player
Sansa USB and Charger Problem
hi ya, ok one of the solution is checking out the trouble of litium battery, i guess has been out of base, i had the same siptom with sansa e250r 2-g, put in right the battery. In back of sansa there are 4 screws that u have to loose it
Aug 09, 2007 | SanDisk Sansa e260 MP3 Player
My mp3 screen keeps going on anf off!
what i would say to you bud is put ur sansa into recovery mode then download the recovery program off the internet that will reset it
http://www.sandisk.com/Retail/Default.aspx?CatID=1532
Mar 28, 2007 | SanDisk Sansa e250 MP3 Player
R u holding the holding the Menu button down for about 3 seconds?
Dec 24, 2006 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
841 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
