Servicing the Water Pump
Of
all washing machine parts, the water pump probably takes the most
punishment, because it is constantly in use. When the pump fails, you
can hear or see the trouble: a loud rumbling inside the machine, or a
failure of the water to drain out of the tub. Here's what you can do to
fix the problem:
©2006 Publications International, Ltd.
Take the pump apart and clean
away all debris inside the pump.
Also clear away debris from
the water tubes.Step 1:
Check the drain hoses to make sure they are draining properly. Remove
the water supply hoses from the back of the washer. With long-nosed
pliers, extract the filter screens from the valve ports in the washer
or from the hoses themselves. Wash the screens thoroughly. Then replace
them and reattach the hoses. If the machine still rumbles or doesn't
drain, examine the pump.
Step 2:
To access the pump, first bail and sponge out any water in the
machine's tub. Then tip the washer over on its front, using a heavy
blanket or pad to protect the washer's finish. Remove the back service
panel. The pump is usually located along the bottom of the machine, but
with the unit tipped on its front it's easier to remove the pump
through the back than through the bottom of the washer.
Step 3:
Locate the pump. It has two large hoses attached to it with spring or
strap clips. If the clips are the spring type, pinch the ends of the
clips together with pliers to release them, and slide the clips down
the hoses. If the clips are the strap type, unscrew the metal collar to
loosen the clamp. Disconnect the hoses by pulling them off the
connections. If the hoses are kinked or crimped at these connections,
straighten them as best you can and reconnect them. Then try the
machine again to see if this kinking was causing the problem. If the
machine still doesn't drain, you'll have to remove the water pump.
Step 4:
To remove the pump, loosen the bolt that holds the drive belt taut and
move the washer motor on the bracket to loosen the belt. Move the motor
out of the way and unbolt the pump; it's usually held by two or three
hex-head bolts located on the bottom of the pump housing. As you loosen
the last mounting bolt, support the pump with your hand. Then lift the
pump out of the washer.
Step 5:
You should take the pump apart if you can, because the trouble could be
lint, dirt, or pieces of cloth or paper clogging the pump impeller.
Clean away all debris inside the pump and clear any debris out of the
water tubes. Then reassemble the pump. Hook up the pump again and test
it. If cleaning the pump doesn't put it back into working order, or if
the pump housing can't be removed, replace the pump with a new one of
the same kind.
Step 6:
To install the new pump, set it into position and connect the mounting
bolts to the pump housing. Move the motor back into position. Tighten
the drive belt on the motor by prying it taut with a hammer handle or
pry bar; it should give about 1/2 inch when you press on it at the center point between the two pulleys.
Step 7: Reconnect the hoses leading to the pump.
