Question about Whirlpool Calypso GVW9959K Top Load Washer
Code CE Have code CE
  • Patty K Jan 10, 2008
    I have been having problems with my calypso top load washer for several months. I had a service technician out to fix it 3 times and finally it was ok to use but only for a few months. At the time of the first error displayed on the machine it showed a LD, SD(saying it was a suds problem) and another display that I don't remember which it was. It would switch between them all. The technician put in a new switch board and replaced something else as well but it continued to display errors. Not to mention my machine had standing water for quite some time. STINKY!!!! My clothes still have a funny smell to them. Now the display is flashing CE after they put in a new switch board only months ago. Apparently whirlpool will be getting a call from me once again. Maybe this time they will stand behind their product. Good Luck to all who has these problems like myself. The problems apparently do not go away and are likely to come back several times.
Had code ce , perform all troubleshotting, no problem found, closed all panel and moved the machine back and code ce returned, so suspected I have a broken wire somewhere.
Removed harness from circuit board to the drive motor, check resistance from all wires, found white/red broken, you may have move the wires to find the open circuit.
Posted on Jan 01, 2008
CE stands for Communication error. The Calypso has 2 circuit boards inside that touchpad area. One is the motor control board and the other is the machine control board. They are not "talking" to each other for some reason. The boards are warranted for 5 years on most machines. This machine is the subject of a class action lawsuit. Just Google Whirlpool Calypso sit back and start reading.
Posted on Dec 12, 2007
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
I have LG CE 0168 and i forgot my security code. My IMEI is (354052-03-797462-6) and my S/N is (002KPSL797462)
I have LG ce 0168 and I forgot my security code my IMEI is 359933-03-935624-0 and my S/N is 009FCAS935624
Jul 02, 2011 | Cell Phones
I can'y unlock my alcatel CE 1588 phone, Please help me!
My phone ALCATEL CE 1588, help me with my portable ALCATEL CE 1588, i don't know what to make now, i need to use my phone now, i'm living in Haiti, when u get my message.
Give me this code just unlock my phone ALCATEL CE 1588.
I'm waiting this code unlock my phone.
Thank's for your KIndness and your Comprehension.
Nov 28, 2010 | Computers & Internet
Hi i have huawei ce 0682 with IMEI 353474029755857 i want to unlock this modem. pls pls pls send me its unlock code its IDEA NET SETTER
i have huawei ce 0682 with IMEI 356755030038656
plz plz plz send me its unlock code
Sep 03, 2010 | Cell Phones
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Need new codes for eurovoxmax need new codes dublin
codes for eurovox 5a01 6/5/09 aa b7 d1 d9 ce 8e 83 af a1 38 06 29 24 29 8d 2b should work ok bristol area
Jan 02, 2009 | Televison & Video
Eurovox codes
hit menu
go to system information
hit ok
type 1969
go to navigation
bring up provider
if you are with chorus then
the codes are: PROVIDER ID 5E 01
KEY NUMBER 00
key data: CE 19 23 87 80 61 74 90
KEY NUMBER 01
key data: 62 FA 09 F3 CE 05 F4 79
make sure your provider name at the top is reading CHORUS if not go to the provider id and right arrow until 5E 01 appears and when you have changed the codes store and exit you should be laughing!!!
best of luck HAPPY CHRISTMAS!
chorus
00:CE 19 2E 87 80 61 74 90
01:62 FA D9 F3 CE 05 FA 79
Dec 21, 2008 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX TX NO CODES AND HOW TO INPUT CODES
scanned channels and all i get is data bein updated
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
Security Code Of LG ce 0168
how to cancel the atmt setting in lg 0168 mobile?
Mar 27, 2008 | Computers & Internet
Whirlpool Calypso GVW9959K Top Load Washer Logo
429 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
