Question about Singer Deluxe 57825 Mechanical Sewing Machine
Handwheel spring? I pressed on the inner part of the handwheel to disengage the needle, and a "W" shaped spring popped out.  Does anyone know how to get the handwheel apart so I can put the spring back in?  There are no obvious screws anywhere, even after taking the top and side panels off to expose the inner workings. Thanks!
yalmer
  • 552 Answers
SOURCE: clutch actuating spring fell out of handwheel
http://www.singerco.com/accessories/manuals.htmlSinger
There is a manual and some helps here.
Posted on Mar 13, 2008
SewExpress
  • 41 Answers
SOURCE: Handwheel doesn't move needle
Sounds like the connection between the handwheel and the needle as disconnected (needle bar). It appears from the picture that this is a version of a mass-market product geared for kids/very light duty sewing.
If so, you may be able to reconnect this by removing the side-cover or top-cover of the machine (if removable). The problem is going to be re-timing the needle with the hook/bobbin assembly.
If you are unable to reconnect or get the timing correct, a good local machine dealer/repair tech should be able to take care of it for you. Unfortunately, the cost of having a technician fix may be way more than you want to pay or the machine is worth.
Best of luck with your repair,
Kim & Linnette
Posted on Jul 31, 2008
SOURCE: Toyota RS2000-2D
If you or somebody else had used the bobbin retreading function and forgot to disengage the bobbin retreader, the handle will not moved.
This is a simple solution, just disengage the bobbin retreader and it will be OK.
Otherwise it could be a jammed bobbin or any other mechanical part or simple no current is passing thorough the machine.
Posted on Nov 01, 2008
bargainbox
  • 1388 Answers
SOURCE: janome 5700 handwheel stuck/inside pulley stuck
The error message relates to the motor sensing that it is working unusually hard.........the extra strain will have a physical cause, generally in the hook and bobbin region.......something blocking or slowing things down, so.......
Remove needleplate and bobbin case.
You will probably find an accumulation of lint in and around this area, also possibly in the feeddog channels.
Use a small brush and vacuum with crevice tool to remove the lint and wipe the hookrace with a tissue moistened with methylated (denatured) spirit to remove any dirt deposits.
Also check that the bobbin case is not damaged on the top surface by needle strikes or on the underside rim by the hook gouging as it spins.
If damage is present but mild, you can use very fine emery paper to smooth surface, if more severe, replace the bobbin case. Don't forget to change needles regularly too.
Best of ......
 www.bargainbox.com.au
Posted on Nov 21, 2008
  • 3 Answers
SOURCE: Handwheel on Sewing machine no longer moves needle.
Actually you should have a "set screw" in the hand wheel. The set screw is usally locked down tight to keep the hand wheel from spinning freely. I f you can run the machine slowly and hold the hand wheel in one place but the machine continues running, then you do need to replace the "set screw". If you replace it you will find that you can offset some of the machines vibration by where you lock the wheel down. Trial and error is the only way to achive this adjustment, kind of like balancing the tires on your car.
Posted on Feb 13, 2009
My singer hd110c handwheel seems loose and it just stopped moving the needle up and down. how do i fix it?
Does it have an inner wheel that disengages the machine to wind the bobbin? If it has been turned counter clockwise, it has disengaged the machine so all you need to do is turn it clockwise to engage the machine.
Nov 11, 2017 | Singer Sewing Machines
WhenI turn the inside nob the needle works but not when I turn the outer nob, it just turns and nothing happens WhenI use the peddle the outernob spins but again the needle doesnt work (nob=handwheel)
On most machines, when the inner wheel is turned counter clockwise, it engages the bobbin winder and disengages the needle movement.
To disengage the bobbin winder and sew, turn the inner wheel clockwise as far as it will go. This should engage the sewing capability and it should work either by hand rotating the large wheel (always counter clockwise!) or with the foot pedal. If it does not, then you most likely need to have your machine serviced.
Jun 29, 2016 | Sewing Machines
How to fill the bobbin
sorry no make nor model we don't know who to ask
Mar 15, 2015 | Sewing Machines
How do I engage the bobbin winding gear for Pfaff 7570?
To disengage the needle while winding a bobbin do the following: the handwheel on the right end of the machine has an inner knob. hold the outer rim of the handwheel stationary as you rotate the inner knob counterclockwise. Also make sure the bobbin winding peg is pushed over to the right and the bobbin is seated on the peg.
Jul 27, 2014 | PfaFF Creative 7570
Have a singer 3221/3232 cannot disengage handwheel to fill bobbin what am I doing wrong
Are you sure you have to pull or push? It looks to me like you just slide the bobbin winder spindle to the right to engage.
Here's a manual for your machine... I'm sure more specific info is in there.
http://www.singerco.com/uploads/download/e06cb85928ace9753f1a7124f4a2df6168ffecf0.pdf
Nov 08, 2012 | Singer 2263 Mechanical Sewing Machine
Model no. 158.17741. the belt is moving, the motor is running, but the part that goes up and down with the thread is not, the belt seems to be tight enough
Check the centre of the handwheel, there will either be A) an inner wheel or B) push/pull device to disengage the needle arm when bobbin winding....it needs to be A) tight, or B) pressed in to re-engage the clutch for sewing......your manual will probably have a diagram,
I could not find a picture of this model, so unsure of the exact mechanism, but it is in the middle of the handwheel
Mar 11, 2011 | Kenmore Sewing Machines
Belts intact, press on pedal, motion in belts, but not on needle end
does the needle go up and down when you turn the handwheel by hand? if so, one of the belts may be slipping - tighten it enough to make it grab.
if the handwheel does not make the needle go up and down, is the handwheel lock for bobbin winding un-locked? if so tighten the handwheel lock inside the handwheel. if the handwheel lock is tightened and the handwheel spins when motor runs the handwheel lock is asembled incorrectly. if this is the case, undo screw in handwhhel lock nut and spin lock nut off machine, then remove pronged washer and turn 1/3 turn and re-install.
scott
Jul 23, 2009 | Brother LS-1217 Mechanical Sewing Machine
Sticky clutch older pfaff 7570
To fix this yourself you need to remove the handwheel screw and cover. Warning: the mechanism may explode and only an experienced technician can help you put it back together.
Ready?
1. Remove with a small screwdriver or any small prying instrument the small cover on the middle of the handwheel (it is about the size of a quarter). You will see a silver phillips head screw that is really wide for its size.
2. With a phillips screwdriver remove the screw you see, do not let plastic part underneath move, hold it in so only the screw and washer are removed. (There is a fiber washer underneath that may stick to is or stay behind, remove it with the screw.) It will take a little effort to break it loose and you need to hold onto the handwheel or block the needle bar with something. (remove the needle and place a piece of wood or a book or anything that is about 1" tall under the needle bar and turn the handwheel in the sewing direction until motion stops).
3. Tricky part: You have now removed the screw and washer and hopefully nothing else has come out or sprung across the room. Gengly pull the entire handwheel assembly away from the machine only a fraction of an inch. Pull on the outer part of the handwheel NOT! the inner part (see above re: springs landing on the other side of the room). You are looking at the upper shaft in the center of the assembly, apply a couple of drops of oil to the interface between the plastic handwheel and the shaft (tri-flow is best, but any light weight oil will do, even WD40 if you can stand the smell).
4. Reset the assembly and install the screw/washer/cover.
5. You may still need to block the needle bar and run the machine to work in the oil.
Notes: If you have not have your machine serviced in awhile this may be red flag telling you that it is time. I have worked on Pfaffs for 10 yrs. they are awsome machines but need a little tlc now and then to perform to maximum
Have fun!
Jan 28, 2009 | PfaFF Creative 7570
Singer Deluxe 57825 Mechanical Sewing Machine Logo
105 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
