Question about HP Officejet 9110 All-In-One InkJet Printer
Leaving space at top of page
My 9110 All in One is leaving about a 2" space at the top. The settings are set at .50 and it is still doing this.........any solutions
  • 2 more comments
  • JIGP Dec 09, 2007
    same for my officejet 9120
  • mbk77 Apr 28, 2008
    Yes, my 9110 is no leaving about 2" or more at the top and it is also giving me spacer pages but not between every page.
    Got any suggestions?
  • allen smitty
    allen smitty Apr 30, 2008
    Same problem, I have a suspicion that it's something to do with the paper sensor on the carriage.
    In my case, it only happens when printing black only documents and will also sometimes give me a paper stall error (i belive to be related)
    No problems in color printing at all.
  • taifusm Sep 25, 2008
    My HP 9110 printer starting doing this also - with all kinds of documents, and even when copying. The solution to clean the encoder disc helped and I also vaguely cleaned the rotating carriage. Thanks so very much!
I too had this prints would not feed properly. the same for fast print qualities.
also, color prints at normal quality wouldnt align perfectly (there would be gaps - white lines - in the print.) the only mode that would work with no problem was color prints at best quality. too slow. recently, the problem became worse and all black printing would immediately cause a paper jam / stall. i had to fix this prob, and found this page.
i just cleaned the encoder disc as suggested by zozo and everything works perfect now.
the disc is a clear wheel with some black alignment figures on it. there is a sensor mounted to read these figures. i wiped both sides of the disc with a slightly moist swab, just to see how dirty it was, and woah, problem solved.
thank you.
Posted on Nov 14, 2008
You might try cleaning (or replacing if it's really bad) the encoder disc all the way on the left side of the carriage bar. The encoder strip on the back controls horizontal movement while the disc (wheel) controls vertical movement. An alcohol swab is your best bet, though you must have small arms and hands in order to clean it without taking the machine apart.
Posted on Jul 03, 2008
I have another machine that is doing it as well.
Posted on Dec 27, 2007
I want to set time of my KC 9110
Go here and see if this helps. It's a 90 page .pdf file. If it's what you need, you can save it to your computer.
Mar 28, 2014 | Kenneth Cole Kc9110 Touch Mens Watch
On a page that I am following others are able to leave comments but I cannot.
Maybe only registered users can leave comments? It's a bit difficult to help you without visiting the page
Jan 11, 2014 | Computers & Internet
Despite loading a new cartige print quality is very light
You are maybe printing in "draft" mode which uses 50% of ink by leaving spaces in printout. Go to print driver and set all to default or disable draft mode.
Jul 19, 2011 | Office Equipment & Supplies
The thread in the bobin isn't comming up too the needle. I have removed the face plate and cleaned it out, but it still isn't working. What could this be?
Make sure the needle is facing in the correct direction
Put the bobbin in the bobbin case leaving a
2 to 3 tail.
Thread the top of the machine correctly, leaving a 3 to 4 inch
tail after threading the needle.
Hang on to the end of the upper thread and use the handwheel to drop the needle.
continue to turn the handwheel to raise the needle. Pull on the end of the needle thread and a loop of bobbin thread should come up.
make sure there is no lint or loose thread in the bobbin area
Jul 30, 2010 | Euro-Pro Shark 9110 Sewing Machine
Why when using word have I double line spacing which I cannot amend. If taken down to the correct level it takes the top of the lettering, very frustrating, please help.
Check the line spacing setting on the page setup menu. I probably is currently set to 1.5 or 2 lines -- this will give you double-spacing between the lines of text.
Also, check the default page style you have. If you click on the page style menu option and view the default settings, you may find that the DEFAULT style has been set to double-space your lines. Make the change and then save the style back as your default.
Jan 08, 2010 | Acer Aspire 5315 Notebook
I have an elitegroup 945PL-A motherboard. When I installed an intel single core processor it works just fine. When I tried a dual core processor the computer would not boot up. Help me....
Ok, you need to clear the CMOS with your jumpers located on the motherboard. You should have a 3 pin jumper. To clear the CMOS place the cap over 1 and 2, leaving 3 open. Restart and go into BIOS settings page and "Load Optimal Settings". Save and exit. If it boots fully, you're good to go. You then need to shut down and put your jumper cap back to 2 and 3, leaving 1 open which is considered Normal Mode. Remember, system MUST be shut off when changing jumper cap settings. Also, here is a link to your Motherboards Manual. Reference page 8 for jumper setting instructions.
Mar 27, 2009 | Computers & Internet
Blank spots on page
How far apart are the blank spaces? If they are around 2 inches apart down the page, then it sounds as if it is the drum
Jan 23, 2009 | Konica Minolta magicolor 2400 Laser...
This problem is with the fuser. It needs to be replaced. They tend to burn out right in the center leaving a rolling smudge across the page as the unfused toner left on the roller gets printed on the next roll-over.
Jan 06, 2009 | HP LaserJet 4250n Printer
Printer switching orientation
Make sure that manual feed is set to letter, on the printer front panel. This is a tabloid printer, so letter size sheets are fed long edge. The cassette will print okay because the media size info for the cassette is read by the printer from the cassette cams.
Dec 21, 2006 | Xante 4G Printer
HP Officejet 9110 All-In-One InkJet Printer Logo
156 people viewed this question
Ben Johnson
