Question about Logitech Express (967407-0403) (DB9674070403)
Keyboard never works mouse works fine
Keyboard does not work correctly. As regular process need to press tthe connector button then the connect button on the back of the keyboard and mouse for both the devices to work.
Problem:
Everytime needs to press the connect button on the back of the keyboard for the letters typed on the keyboard to be displayed on screen. Mouse works perfectly fine.
Downloaded setpoint for Vista from logitech site...still the same problem.
Please provide any solution.
  • lompockathy Mar 10, 2008
    Have had keyboard and mouse for several years. Mouse works fine but keyboard is unable to connect. I have changed batteries and tried several new batteries. Changed USB ports, Moved power source further away from keyboard and computer.
  • Anonymous Mar 27, 2014
    The mouse is working fine in all other ways except that the back button has stopped working
Have you tried changing the batteries? My mouse has an issue just like that when the batteries get low.
Posted on Feb 20, 2008
Keyboard won't operate
This may or may not help. did you press the connect button on the usb reciever (the device that connects to the computer) then press the connect button on the keyboard. They have to be pressed in that order. you may have already done this but just in case maybe it will help you.
thanks
Steven.
Apr 21, 2010 | Logitech Wireless Access Duo Optical...
Logitech ex 100 mouse doesn't work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Jan 22, 2009 | Logitech Cordless EX 100 Mouse
Keyboard will not connect!?!
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard.
Hope this helps. Bud
Dec 31, 2008 | Logitech Cordless Desktop MX3200...
LX 500 Keyboard not working mouse fine
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Dec 29, 2008 | Logitech LX 700 9674180101
Trying to get a Logitec Keyboard and wireless mouse to work on D6
Hi
check it your bluetooth device connecter your loptop and go to the control panel --> add hardware wizard click next it will show the all hardware drivers in your loptop select your wireless mouse than click it.
it will work good.. and one power button is there please press the button it will show one blink  ofter you will check it..
Nov 16, 2008 | Dell Latitude D600 Notebook
I have a nx2 nexxtech remote mouse. I replaced the 2 batteries (AAA) and it lights up, but does not work on the laptop. Any ideas what is wrong?
First, put charged batteries into your keyboard and/or mouse. Then, plug the adapter into the USB port. Then, press the big, round button on top of the adapter and the CONNECT button on the bottom of the mouse (not simultaneously). Then, press the big, round button on the adapter, and the connect button on the bottom of the keyboard (not simultaneously). Once the computer is on, click the mouse once, and everything should be working fine. If the mouse and/or keyboard do stop working, then either click the mouse once, try the connection process above again, or change your batteries.
P.S. The connection process is only meant for whichever part is not working (i.e. If the keyboard works, but the mouse doesn't, then only do it for the mouse.)
Jul 20, 2008 | Computers & Internet
My mouse is stuck...
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
May 31, 2008 | Logitech Cordless MouseMan Optical Wheel...
Mouse and keyboard not working
  1. Remove the batteries from the keyboard.
  2. Make sure you have the mouse synchronized. To do this, press the connect button on the receiver, then press the connect button on the mouse.
  3. Open the iTouch Configuration Panel by double clicking the iTouch icon in the Systray.
  4. Click the Cordless tab.
  5. Click the Connect button in the Control Panel. A dialog box will appear instructing you to press the connect button. Before you do, you should re-insert the batteries.
  6. After inserting the batteries, press the connect button on the keyboard.
  7. Verify both devices function correctly.
If this does not work, please try the steps below:
  1. Remove the batteries from the keyboard and press keys on the keyboard repeatedly (as if typing) for approximately one minute. This will clear out the capacitors.
  2. Press the Connect button on the receiver.
  3. Press the Connect button on the mouse. NOTE: You may need a pencil tip or other small tip to press the connect button.
  4. Press the Connect button on the receiver.
  5. Insert the batteries back into the keyboard.
  6. Press the Connect button on the keyboard.
Jan 09, 2008 | Logitech Cordless Desktop EX110
Connecting wireless keyboard for L3600
There is a button on the bluetooth dongle that needs pressing to get the mouse & keyboard operating, I think I got them to work when the little long blue light on the dongle (there is one) it flashes for a brief time when pressed. I think if the mouse or keyboard button is pressed while its flashing it picks them up. Good luck, it was very tedious, I agree.
Nov 09, 2007 | Acer Wireless WIL-152 91.84R07.152...
Microsoft wireless multimedia keyboard 1.0A
I suppose you should reset the keyboard and mouse and maybe the access point itself. Try find small buttons on each devise and press them AT THE TIME. You may need somebody's help. Those buttos can by hidden under mouse and keyboard and should be on the top of the access point. This depend on the model, so please reffer to a manual.
Oct 21, 2007 | Computers & Internet
Logitech Express (967407-0403) (DB9674070403) Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
