Question about Kodak EasyShare CX7530 Digital Camera
New Batterys and camera indicates batterys low then shuts off.
When I turn on my camera, the battery low indicator displays, then the camera shuts off. I try it several times, then it works. When I shut it off, it does the same thing next time I turn it on. Can you help me with this problem? Thank you very much. domlepore@earthlink.net
Did the batteries come with the camera? If not, they might not be a high enough mah rating. Some batteries, even though brand new, may not be strong enough to power a camera.
Posted on Dec 13, 2007
Why is the camera turning on then right back off
That is a sign of two things one a low power fault indicator or a logic problem. Logic problems are rare in new cameras so the first check is a battery test. there are several battery failures that will cause a shut down which is why it is best to try another battery, logic problems and dirt can drain batterys and cause a shutdown too.
Feb 20, 2011 | Fuji FinePix E500 Digital Camera
Toshiba PDR-3300 Digital Camera
Hi this is common problem if your sure that these batterys are new and you have used that make and type of battery before than the problem will be on the board of the camera itself.
If these batterys are ones you have not used in your camera before then the chances are these batterys are just not powerfull enough so you can by a recharge pack for your camera ok so let me know if its new batterys and if you have used this type before.
Also insted of using the lcd can you turn the screen of then try taking picture using normal view finder as you would on a none digital cam
It could just be that the batterys you brought are faulty and might be worth trying another set before giving up.
These camera usuall wont switch on with normal batterys so just try another set or if you have let me know.
If the battery says low bat then goes off then these batterys will not work if tryed again but if you can get camera on turn off the screen then try taking picture ok get back to me and let me know ok
Apr 06, 2008 | Toshiba PDR-3300 Digital Camera
PMP-120 Battery Discharges too quickly
Yes,
you will have power through the usb port, so leave it plugged in.
Even when it is shut down it can drain batteries.
Feb 25, 2008 | iRiver PMP-120 Digital Media Player
Battery low indicator comes on even after new battery installed
I also have this problem. I put freshly recharged batteries in the DX3900 and the camera starts to turn on and reads the memory card (the green LED blinks) and then I notice that the in CAPTURE mode the lens does not extend out of the body housing. The top display shows a flashing low battery warning and after approx. 15 seconds, the camera shuts off with no function.
I have determined that the camera appears to have changed its low battery sense level as I have verified that the batteries are indeed fully charged by using a volt meter. If I have the camera in a warm environment, and do not have the LCD display on (removes a major power drain) the camera can be made to work for a short while. If I select the LCD to turn on, the extra drain seems to cause the camera's battery monitor to think that the battery voltage is too low and the camera shut down. I have yet to resolve this issue.
Aug 18, 2009 | Kodak EasyShare DX3900 Zoom Digital Camera
Battery Problem
The batteries u r using for your camera are of very low rating or low ampere output, you should use atleast 2100mAhr rating batteries and you will be very much satisfied with the performance.
Regards,
Manoj Joseph
+91 9352008418
Jun 16, 2008 | Canon PowerShot A640 Digital Camera
Wont switch on
Some cameras have a bettery setting in the menu. You need to make sure this setting is set to the type of batteries you are using. Usually when you use akaline batteries and even if you put in fresh batteries but still get the low battery indication then your camera is set to rechargable (Ni-Mh). Ni-Mh has more power to it then alkaline so this is why you get the low indication.
Feb 11, 2008 | Samsung S1030 Digital Camera
Low Battery when using screen
cudgegong said in another forum:
To resolve the annoying "change the batteries" problem. Goto menu, choose yellow menu, select
file No. reset to ON. Turn camera off and back on.
Voila fixed.
Oct 21, 2006 | Canon PowerShot G2 Digital Camera
Wont speed up even with new batterys
The shutter button features a two-stage action. shutter_button.gif Pressing Halfway Pressing halfway automatically sets the exposure, focus and white balance.
The indicators light or blink as follows.
Upper Indicator
" Green: Metering complete (two beeps sound)
" Orange: Flash will fire
" Blinking Orange: Camera shake warning / Insufficient exposure
Lower Indicator
" Yellow: Macro Mode / Manual Focus
" Blinking Yellow: Focusing difficulty* (single beep sounds)
* When the indicator blinks yellow, lock the focus before shooting.
Sep 24, 2006 | Canon PowerShot A400 Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Sony Cyber-shot DSC-U10 low battery indication.
possible short circuit that is draining battery at a speed. get your camera tested at some good repair shop,
Jul 02, 2006 | Sony Cyber-Shot DSC-U10 Digital Camera
Kodak EasyShare CX7530 Digital Camera Logo
454 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
