Question about Freezers
Freezer problem Ice cubes evaporate in a short time while still in trays. Frost on foods in a short time. Freezer seal tight.
  • good2 Mar 06, 2008
    freezer have buzzer noise and its not stopping
  • 126 Answers
If you have a fan in your freezer your ice will disappear eventually.the circulating air draws the moister out.
Posted on Dec 14, 2007
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
Ice cubes shrinking and crystalizing in freezer
what is heppening is the defrost circuit and compressor or trying to run at the same time! its either the timer itself or the limit switches inside the wall near the defrost heater coil are shorted closed
Jan 17, 2010 | Freezers
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
Small patch of ice if frost free freezer
Frost free does not mean no frost ever anywhere. It just means that there is a mechanism to defrost the evaporator on a regular basis. If there is a spot where frost is forming in the box it may just mean that a little bit of moisture that is not collected on the coil may be finding another cold spot to stick. The area where the fan blows into the cabinet is bound to be the coldest spot in the freezer therefore an ideal place to collect frost. Check the level of the unit and your door gasket to be sure the door is closing tight and true.
Jun 28, 2009 | Whirlpool 25.3 cu. ft. / 716 liter Upright...
Kenmore upright freezer not cold enough to freeze
Sounds like a door seal that isn't sealing all the way around. That would be my first replacement. Is the unit level back to front and side to side? Is it really full of food?
Call your local appliance parts house and get a magnetic door seal first. They aren't that expensive. But make sure you do not have the freezer overloaded, which could account for the lack of that vacuum sound.
Finally, is self defost? Even if it is, a lot of times the vent on the bottom in the back gets packed with ice. If it is, remove the food and use a hairdryer, being carefull to unplug the freezer first. Melt all that ice and empty your overflow tray at the bottom underneath.
Mar 07, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Thaw's. Turn-off for period of time it would freeze as normal
Make sure nothing is inhibiting air flow. I don't think it is advisable to store food in an ice machine however that is not likely the problem unless the food itself is inhibiting air flow. Most ice machine manufacturers recommend against storing any food in an ice machine. If there is a freezer component in you model the check to see if the evaporator coils are frosting up and the frost is blocking airflow causing the ice storage chamber to get warm. High humidity can cause frosting. Leaving a door to the ice maker open too long can cause frosting. A low refrigerant charge can do this although it seems logically like it should not. With a very slightly low charge one end of the evaporator gets super cold and the other end is not cold enough. Frosts starts collecting on the super cold end and accumulates across the evaporator coil to the other end eventually blocking all air flow. With too much humidity from open doors frost accumulates over the entire evaporator evenly but still blocks. You shut the unit down. It thaws out and works OK on restart until frost again builds up. If its not a frosting problem but it just stops making ice then the ice may not be releasing. Check the water supply and change any filters to insure good water flow. A good water supply is required for proper release and harvest of the ice in many ice machines. If the ice doesn't release it takes a shut down and thaw to clear the suspended ice out. Check for these things and write back if you need further assistance and can provide me with more details.
Jan 19, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Frost in the freezer
IS IT ICE OR FROST? IF IT IS ICE, THE DOOR MAY HAVE BEEN LEFT CRACKED OPEN.
IF IT IS FROST, IS THIS A FROST FREE FREEZER?
IF YES, IS THE FROST ON THE BACK WALL?
IF YES, THERE IS A DEFROST FAILURE AND YOU WILL NEED TO TROUBLESHOOT THE DEFROST CIRCUIT.
IF THE FROST IS ON THE FOOD OR AROUND THE DOOR OPENING, A SEAL LEAK HAS ALLOWED WARM MOIST AIR INTO THE FREEZER AND CREATED THE FROST. CHECK THE DOOR SEAL FOR A GAP WHEN CLOSED.
Mar 24, 2008 | Freezers
Freezers Logo
125 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
